Question about Cisco Linksys E1000 WirelessN Broadband Router Network Routers
How do i access my port forwarding if my cisco router cant even log me in? are there preset defaults?
No matter how many times i typed user names and passwords like the username or what ever...doesnt let me in
  • 49 Answers
You can do a reset on your router. After the reset, the password goes back to the default, which is admin
Posted on May 01, 2014
  • 21 Answers
SOURCE: I forget to change the
http://www.cisco.com/en/US/products/hw/switches/ps607/products_tech_note09186a00800c4546.shtml
Posted on Dec 25, 2010
melvinlpeter
  • 30 Answers
SOURCE: Hi i have 1841 router what is the default user
  • Follow these steps in order to recover your password:
    1. Attach a terminal or PC with terminal emulation to the console port of the router.
      Use these terminal settings:
      • 9600 baud rate
      • No parity
      • 8 data bits
      • 1 stop bit
      • No flow control
    2. If you can access the router, type show version at the prompt, and record the configuration register setting.
      Note: The configuration register is usually set to 0x2102 or 0x102. If you can no longer access the router (because of a lost login or TACACS password), you can safely assume that your configuration register is set to 0x2102.
    3. Use the power switch in order to turn off the router, and then turn the router back on.
      Important Notes:
      • In order to simulate this step on a Cisco 6400, pull out and then plug in the Node Route Processor (NRP) or Node Switch Processor (NSP) card.
      • In order to simulate this step on a Cisco 6x00 with NI-2, pull out and then plug in the NI-2 card.
    4. Press Break on the terminal keyboard within 60 seconds of power up in order to put the router into ROMMON.
      If the break sequence does not work, refer to Standard Break Key Sequence Combinations During Password Recovery for other key combinations.
    5. Type confreg 0x2142 at the rommon 1> prompt in order to boot from Flash.
      This step bypasses the startup configuration where the passwords are stored.
    6. Type reset at the rommon 2> prompt.
      The router reboots, but ignores the saved configuration.
    7. Type no after each setup question, or press Ctrl-C in order to skip the initial setup procedure.
    8. Type enable at the Router> prompt.
      You are in enable mode and should see the Router# prompt.
    9. Type configure memory or copy startup-config running-config in order to copy the nonvolatile RAM (NVRAM) into memory.
      Important: Do not type copy running-config startup-config or write. These commands erase your startup configuration.
    10. Type show running-config.
      The show running-config command shows the configuration of the router. In this configuration, the shutdown command appears under all interfaces, which indicates all interfaces are currently shut down. In addition, the passwords (enable password, enable secret, vty, console passwords) are in either an encrypted or unencrypted format. You can reuse unencrypted passwords. You must change encrypted passwords to a new password.
    11. Type configure terminal.
      The hostname(config)# prompt appears.
    12. Type enable secret password> in order to change the enable secret password. For example:
      hostname(config)#enable secret cisco
    13. Issue the no shutdown command on every interface that you use.
      If you issue a show ip interface brief command in privilege EXEC mode, every interface that you want to use should display up up. For example:
      Router#show ip interface brief
    14. Type config-register configuration_register_setting>. Where configuration_register_setting is either the value you recorded in step 2 or0x2102 . For example:
      hostname(config)#config-register 0x2102
    15. Press Ctrl-z or end in order to leave the configuration mode.
      The hostname# prompt appears.
    16. Type write memory or copy running-config startup-config in order to commit the changes.
Posted on Mar 01, 2011
bunnydawg
  • 5158 Answers
SOURCE: Hi when i reset cisco srp521
The default username is admin.
The default password is admin.
that's the default passwords. it does depend on the type of reset whether you will still have the old passwords or not. be that as it may i'm also including the user manual for you
http://www.cisco.com/en/US/docs/routers/srp520_series/srp521w/administration/srp500_admin.pdf
i do hope this solution helps you
thanks
robert
Posted on Mar 03, 2011
steve_hillin
  • 44 Answers
SOURCE: I forgot to change the
Here is a cisco page that goes over the password recovery procedure. Once you reset the credentials, you can make any configuration changes needed. You will also have the option to keep the existing configuration in place but change the password, if the configuration has any use to you.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00801746e6.shtml
Posted on Mar 14, 2011
  • 40 Answers
SOURCE: I can't log in to the user based utility. Need a valid user name and password to access.
Is this your computer? If so, why not reset the windows password?
The easiest way to reset a forgotten Windows password I ever use is to use Windows Password Reset ,just a few steps:
Step 1: Download and install Windows Password Reset
Step 2: Burn Windows Password Reset Std ISO file to CD/DVD
Step 3: Put in your newly created CD and remove your Windows Password.
Hope it can help you.
Posted on Mar 27, 2012
How do I reset WAP4410N router back to factory defaults ?
There should be a reset button to the right (the back facing you) of the antennas on the back, press that for 10 seconds to restore back to factory default. You may also go into the the web based control panel of the router and set it back to default.
Dec 06, 2010 | Linksys Cisco Small Business WAP4410N...
Tip
How to enable or disable remote access on a VersaLink 7500 wireless router
Remote access is a way for you to log in to your router's settings from any computer that has Internet access, even if it's not on your local network. You can configure your VersaLink 7500 Wireless Gateway for remote access by following the steps below.
To enable remote access:
- Open up a web browser on any computer that's on the same network as your router.
- Type your router's IP address (by default, it is 192.168.1.1) into the browser's address bar and hit Enter.
- Click the Advanced link at the top of the screen.
- Click Yes when asked if you're sure you want to proceed.
- Click Remote Administration.
- If you are asked to log in, enter the user name and password for your router.
- Click the box next to Enable Remote Access.
- Write down the URL shown on the next line; that is the IP address and port number you'll use to access your router remotely.
- Click Apply to save the change.
To disable remote access:
- Follow the steps above to get to the Remote Administration page.
- Remove the check mark next to Enable Remote Access.
- Click Apply.
If you haven't already changed the router's user name and password from the preset ones, you should do that now to prevent other people from being able to access your router over the Internet. You can set up a new name and/or password by clicking Users on the Advanced page. If you don't regularly use remote access, you should leave it disabled as an added security measure.
on Jan 27, 2011 | Computers & Internet
CANT ACCRS WIRELESS ROUTER WRT110 BY LINKSYS CISCO
Sounds like the router needs to be reset..
Before you do a reset try to login to the router by typing 192.168.1.1 in the webrowser ..
If that fails then look on the back or under the router and there is a reset button. Press and hold for 10 sec ... The let sit for a min or 2 then try logging into it..
Note: That the router will have to be setup again. Default login admin for the password .. don't enter any usernames
Jul 22, 2010 | Linksys RangePlus Wireless Router WRT110 -...
How do I change my SSID?
You log into your router and change it there in your setup. The SSID, is just the "Name" you give your "Connection"
Mar 01, 2010 | Linksys -Cisco Wireless-G VPN Broadband...
I would like to configure port fowarding on the Cisco 857 router using the http interface rather than via any coding. Is it possible and what do I need to do? In my scenario, the router must be configured...
It is possible to configure your router via a web browser. Although it’s disabled by default, your router has its own mini HTTP server built in. This provides another way to gain access to the router for the purpose of issuing commands. To enable the HTTP server, you have to use the command "ip http server" from the global configuration mode.
cisco(config)#ip http server
cisco(config)#
Then open a web browser and point it to one of your router’s IP addresses. The interface is not really nice, but you can issue commands using hyperlinks.
For security reasons I still suggest that you keep the HTTP server turned off, since it offers just another point of access for potential hacking.
What is so bad about the command line? Configuring port forwarding is actually pretty easy, once you know the commands.
Type show ip interface to find the name of the interface you want to set port forwarding for.
The show ip nat translations command shows you the current port forwards on Router.
Type configure to enter the configuration mode
The command for port forwarding is: ip nat inside source static (TCPorUDP) (YourComputersIP) (PortToForward) interface (name)(PortToForward)
in you case:
ip nat inside source static tcp 192.168.0.1 5900 interface (name) 5900
and
ip nat inside source static tcp 192.168.0.2 5901 interface (name) 5901
replace (name) with the interface name you got from the first command.
Then press CTRL-Z to end the Configure Session
Type copy run start once you tested your settings and press ENTER for the question Destination filename [startup-config]?
I have heard of some commercial tools that let you configure your router via web interface, but they are very expensive (around 1400$).
You can try it out for 14 days. Go here.
If you want to play with a free one, go to Cisco (link) and check it out. (You have to be a member though.)
If you have any more questions, just come back here and leave a comment - I'm happy to help.
Oct 24, 2009 | Cisco 857 Router (CISCO857K9)
How do i log in to the router to port forward for cctv please regards Gary
click start click run, type cmd, click ok, when black box appears type
ipconfig /all , then click enter
when results come back, look for the entry titled default gateway, shoud be a list of numbers and periods, something like 192.168.1.1 or similar. write down the number.
open an internet explorer window go to the address bar and type this number in with no www or anything like that, it should ask for a name and password, these you either set up when you bought the router, or they are set up as a default, which you would have to get from the router manufacturer. once you type them in and click ok, you should be into the routers setup pages, from here, every router is different and you need to look for the port forwarding section.
Oct 11, 2009 | Cisco Computers & Internet
Need to forward two UDP ports
Your going to have to get in to the administration portion of the router to setup port forwarding.....without this access you can't do anything to forward the ports....
There should be someone who has this access as it sounds like your in a dorm/apartment environment....
Sep 11, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Hi. I got a MEGA105WR ADSL Router and SAMSUNG camera system SHR-5040 DVR. I need help setting my router for my DYNDNS account. So I can link remotely by software and webb browers.
These instructions will work on any windows computer version 2000 and up.
In order to open ports you need to gain access to your router's control panel. To do this we go to Start>Programs>Accessories>Command Prompt. From here type in: ipconfig
Press ENTER to execute the command. A list should be returned listing some IP Addresses. Look for the one associated with, "Default Gatewaty."
Here is a picture.
Afterward open your Internet Browser (Internet Explorer, Firefox, etc...) and type the IP Address associated with the default gateway into the address field of the browser. DO NOT add www. or .com. Afterward press ENTER or click GO as if you wanted to visit a website.
Here is a picture.
Once you're at the control panel you will probably be asked to log in. If you do not know your login details you can always try the default. To find these you can either search your router's user manual or head to the online search engines entering your router's manufacturer's name, the router's model #, and the words, "default password" into the same search request to bring up the default login credentials. For example:
Linksys WRT54G default password
Here is a picture.
If you still can't manage to log in to your router's control panel you will have to contact the technical support department of your router's manufacturer asking them for assistance in resetting the login user ID and password of the router.
Once you manage to log in to your router's control panel, locate areas hinting anything in port-forwarding. Such as:
Port Forwarding
Firewall
NAT
Virtual Servers
Applications
You're trying to find a panel similar to the one depicted in this screenshot. Please note that the panel will probably not be alike. However in order to forward ports the router needs this information:
Ports to forward, on which protocol, and where to forward the ports.
Once you manage to find the appropriate screen for port-forwarding you will have to check with SAMSUNG to determine which ports need to be opened to allow remote access to your DVR.
Jan 28, 2009 | Computers & Internet
Cisco Linksys E1000 WirelessN Broadband Router Network Routers Logo
27 people viewed this question
Top Cisco Computers & Internet Experts
Gopi Venkatesan
Gopi Venkatesan
Prashant M
Prashant M
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
