Question about E-Machines GM5260 (1009304) PC Desktop
How do i take the cover of the PC desktop.
I've mange to remove the screws to take off the cover. Only problem is, that the cover will not come off as it seem to be lock or clip on to something else. Any idea if i'm missing something here??
  • baron 1 May 27, 2008
    Same problem as above. Sony users manual does not show how this is done. Talks about upgrgading but no assistance as to how to get inside the computer
  • Anonymous Nov 02, 2008
    remove cover on dell 3000
  • 42 Answers
Hi No but you do need to be forceful when removing the cover just place the palm of your hand on the side panel and slide the side panel towards you and that should release it
Posted on Aug 29, 2007
OK, but how do I take off the rest of the cover? I need to change out the DVD. I unscrewed the screws, but could not remove it. Is there a trick to pop the front plastic cover off, then maybe a screw behind that?
Posted on Jan 25, 2008
These systems sometimes have a cover lock inside connected to the bios which can lock the lids in place.
Posted on Dec 20, 2007
SOURCE:
How to Replace a Gateway PC power supply
Just open the cover, find the four screws in the back of the computer that hold the power supply, remove those screws, unplug all the cables making note of what goes where and what needs to be pluged in. replace the power supply, plug all the cables like before and screw the four screws back, replace cover and you should be done.
Jun 08, 2014 | Gateway 550GR PC Desktop
How to replace hard drive in compaq presario desktop S4020WM
the green plastic "panel" as you call it...may have a clip that's securing the hard drive in it. see if there is a tab you can pull up (gently) with a finger that may release the drive
Feb 21, 2013 | Compaq Computers & Internet
Nee to get the cover off my optiplex 745 desktop
Screws? I don't think that was necessary on an Optiplex GX745. If you face the front of the desktop then look at the back on top and you will see a latch to push and the cover pops open on one side.
See the photos below:
Jun 02, 2012 | Dell Computers & Internet
How do i remove the internal CD drive in my Acer Aspire RC500 ?
I assume you are talking about the cd drive into a desktop aspire ...The procedure is to remove the side cover and have access inside teh desktop ..(the left one ) ..after that locate the drive ,.,remove the power source cable and the ide controller...and after that it will have 2 screws on each side (repeat procedure by removing the other cover-right one ) ..and after all 4 screws are removed..the cd drive will slide out ..in forward ..(it is mounted on a slide )
For some desktops it will not be held in place with screws ..but it have a locking mechanism and you need to pull aside or back ...and it will unblock the drive and will slide out toward front side ..
Jul 22, 2011 | Acer Aspire RC500 PC Desktop
I am tring to remove the hard drive from a gateway 610xl desktop system. Do you know where I can get instruction on how to remove the hard drive?
cosmetic screw covers that cover nothing
"remove this panel so you can remove that panel so you can slide the
carriage holder and unscrew the fenortnor rods."
"Flex the case in the middle and the undercarriage will drop out."
"Slide the front cover a couple inches left and remove screws, then
turn it around and lift the cover one inch to remove third screw."
"Stroke the front left corner lightly, singing a lullaby, then flip it
over and scratch at the furry spot in the middle."
Feb 25, 2011 | Gateway Media Center 610XL PC Desktop
How Do I remove the cover from a Gateway 500 series???
Like this Gateway SE?
http://support.gateway.com/s/PC/2800071/280007101.shtml
On the back of the computer remove the screw from the top middle.
Now remove the screw on each outside edge, down towards the bottom.
Hold the outside shell, or computer cover. Push the inside forward.
The computer cover comes off like a shell, or bonnet.
http://support.gateway.com/s/PC/2800050/280005003.shtml
If this is a reference to a Gateway 500X series, remove the thumb screw/s from the back of the computer, on the right side. (Right side as you are facing the back of the computer) Then slide this Side Panel towards the back of the computer.
Regards,
joecoolvette
Dec 19, 2010 | Gateway 500 X PC Desktop
How to fix driver's side door to 1995 chevy silverodo the handle's broke I usually have to lock from outside
open the cover by using screw driver. after removing the screws remove the cover then you can replace the defective part of your door handle cable or the handle
May 14, 2010 | HP Pavilion 533w (P9859AR#ABA) PC Desktop
Cover remover
check in cabinet you find 2 screw 1 on top and other on bottom thyn pull cover in forward direction.
Jul 10, 2009 | Dell Dimension E310 PC Desktop
Panasonic cf-28
Unlock BIOS by removing jumper on Motherboard. The jumper is a small plastic thing on two pins.
Jun 19, 2009 | Panasonic Toughbook 29 Touch (P/N...
Disassembly of Gateway 610
Found this - should help you
Dec 31, 2008 | Gateway Media Center 610XL PC Desktop
E-Machines GM5260 (1009304) PC Desktop Logo
1,082 people viewed this question
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
