D-Link AirPremier DWL-8200AP 802.11a, 802.11g/b (DWL8200AP) Wireless Access Point Logo
Anonymous Posted on Jul 22, 2013
I cant access my Router's configuration...
I have tried over and over with the login window and i cant seem to access it, i use the 192.168.#.# stuff and it wont let me in.
Anonymous
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 72 Answers
  • Posted on Aug 01, 2013
Anonymous
Expert
Level 2:
New Friend:
Cheetah:
Answers
72
Questions
Helped
4770
Points
187
Just see on the back side of the router. There would be a button of "Reset". Press it. Now try to access . It would work.
2answers
Cant access 192.168.0.1
To RESET the Netgear, power up the Netgear then press andhold the RESET button at the back of the router until all the LEDs flash.Connect a LAN cable from the Netgear to the LAN port on yourcomputer, open a browser and enter the Netgear configuration URL -
http://192.168.0.1
The default login = admin
The default PW = passwordYou can now change the default admin password and configurethe wireless settings.
Go to the wireless configuration and set up the SSID and WPA or WPA2encryption.
Now apply these settings to the wireless card in your laptop/computer.
To secure your wireless network from unauthorized access, please click on thislink and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
1helpful
2answers
Hi, I am trying to get a security password for my dlink -dir615 model through the internet by using the default gateway 192.168.0.1 but it doesn't seem to work. the one that comes up is not the usual...
cant login ... i configured router with the wizard no problem can ping router go to main router login but i get " Enter the correct password above and then type the characters you see in the picture below. auth.bmp
as you can see the characters are not visible!
never had this problem with windows xp but unfortunately all my computers are windows 7 now ... could this be a brower issue because i tried them all.
4helpful
2answers
I cant login to D-link-i have forgotten my password and i have tried 'admin' as username & 'password, admin' for the password and also tried leaving it blank, as well as the pin on the bottom of the...
The default D-link router login is admin with no password. With that said, you probably cannot login to your router because D-link requires you to change this default login the very first time you login to set it up. If you have a router you setup a long time ago and have forgotten its password and settings, you will likely have to reset D-link router password.
If you look at the back of your D-link router, you will see a pin-hole. Inside that hole is a button that resets the router. To perform the reset, insert the end of a paperclip in the hole and depress the button for about ten seconds. Leave the router on during this time. It will reboot by itself and the WAN light will begin flashing on the front.
When it stops, the router is reset and you can login to it using your web browser. Just type http://192.168.0.1 and click enter. You should see the D-link login window. Type admin without a password and you will be presented with the default d-link settings again. Configure a new password and wireless settings and your router will now be accessible again
Netgear wireless router wgr614?
If you cannot login to the router's configuration URL, then you can reset the Netgear back to the factory defaults by powering up the router and press the pinhole RESET button at the back of the router until the LEDs turn on, then release the RESET button and wait for the router to reboot.
Then connect a LAN cable from the computer to the router open an Internet Browser and enter the router's configuration URL
http://192.168.0.1
The default password = password.
You can now configure the wireless settings, Eg. SSID, encryption etc.
To secure your wireless from unauthorized access, please click on this link and follow my instructions :-
I have problem setting up my wireless network and redirecting my wireless client to my local webpages before they can access to internet.   see this diagram below :...
you need to replace your modem with a router that is capable of running Network Address Translation. You are trying to route private IP's (192,168.x.x) over the public IP (internet) network.
Cant put a lcok on my smc router
Manual for WBR14-G2 router [6.2 MB] in pdf format:
http://www.smc.com/files/AG/MN_SMCWBR14-G2.pdf
Keeping others from connecting to your router:
1. Have an "wired only" router login access or for this router "change and disable your SSID". This way you avoid that others can login to
to the router changing your settings: See page 48 of the manual.
1.1 Wireless Network Name (SSID): change the default name SMC
to "any private name" ( and remember for later login )
1.2 Broadcast Wireless Network Name: change from default ENABLE
to DISABLE .
2. Make a secure wireless encryption key for your connection:
see page 87.
2.1 For most secure key select WPA / WPA2 only and SAVE SETTINGS .
2.2 See page 91 for entering and saving your secure key: the password
that must be entered to get access to the router.
Cannot login to wbr-2310 router's config page
Disable firewall on your computer. It seems that it's blocking you from getting in the setup page. you may also try using another computer to login just to isolate your problem
Need To Configurate To Host A Bnt game
You need to log on to your router. Go to Start>Run>type http://192.168.1.1. then a login window appears. Leave username blank and admin for password. There you will find the port-forwarding, DMZ stuff that gamers use. Here is the link for Linksys info for your router http://www.linksysbycisco.com/US/en/support/WRT160N Steve Medley
Need help
Is your laptop working completely -- including to the internet to access web pages with its current router attachment?
Is the laptop connected wirelessly or by a wire?
Is the desktop connected with a wire or wirelessly?
Was the desktop connected to another device before?
Was the desktop configured to login before especially if it was not connected to the router before?
Did you configure the router to do the login that used to be done by the desktop before, if that was the case?
If the router is now doing the login did you configure the desktop not to login if it is no longer needed?
Did you configure IP addresses, subnet masks, gateway addresses or DNS addresses into the router before?
Does having the router mean these should be removed and the desktop switched to accept dymanic addressing from the router?
These are quite a few questions and you may not be able to answer them all. Answer what you can in a comment to this issue and I will attempt to determine a plan to get your desktop connected.
Top D-Link Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Grand Canyon Tech
Grand Canyon Tech
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
