Question about Vehicle Parts & Accessories
Rewire 1955 ford - Vehicle Parts & Accessories
    Top Expert:
  • 80,417 Answers
What part of it?
Posted on Jul 22, 2013
How do you wire a solenoid on a 1955 thunderbird 6 v
Hello Jacqueline Iannuzzi,
The actual solenoid on that car is on the side of the fender ...
Large lugs are for the BATTERY & STARTER Cables.
The small terminals If one comes directly from the "S" terminal of your IGNITION SWITCH...
In a simpler time the "other" terminal was the "B" power to the ignition switch
(you should NOT have the 2 wire solenoid (I don't think)).
Hope this helps
http://www.rockauto.com/en/catalog/ford,1955,thunderbird,4.8l+292cid+v8,1435048,electrical,starter+solenoid,4188?a=Ad+Code+msn-Ford
More Information for ACDELCO U945
Dec 08, 2016 | Ford Thunderbird Cars & Trucks
Where is the neutral saftey switch on a 1955 thunderbird 6 volt
On the floor end of the shift column
before it goes through the fire-wall.
(standing on your head)
Big CAUTION ... DISCONNECT THE Battery
lest you be driving around... upside down
(like I did... (no accidents... but that not in my hands)).
Hope this helps
Could not see it here..http://www.rockauto.com/en/catalog/ford,1955,thunderbird,4.8l+292cid+v8,1435048,electrical?a=Ad+Code+msn-Ford
Looks like
https://www.bing.com/search?q=55+thunderbird+neutral+safety+switch&FORM=EDGENA&PC=DCTE
Where can I get a service repair manual on a 1955 Pontiac A.M. radio.
You'll be amazed the things you can find in eBay. I found an electrical schematic for my1979 Ford e250 van
Jul 06, 2016 | Pontiac Cars & Trucks
1955 olds 88 hei ignition wiring to key and ignition system
Original system has a resistor wire between coil + and ignition key, to reduce voltage and thus increase amps to give fatter spark and increase fuel mileage. For HEI system, this resistor wire must not be used, so run new primary wire straight from switch "run" to coil +. There should already be a wire from the starter solenoid to the coil + to supply full 12 volts when cranking to give higher voltage spark to plugs to help jump the gap better for use while starting. The MSD web site has much more info.
Jul 05, 2016 | Cars & Trucks
Will 2001 Ford F150 front suspension adapt to 1955 Chevy 3100 pickup?
not as a bolt in will need to fabricate a few parts and brackets
Aug 13, 2015 | Ford Cars & Trucks
Need a exsploded view of a oilpump assembly on a 1955 ford customline 272 engine
Your question may have been mis-categorized under Homelite chainsaws. It maybe should be under engines.
Sep 15, 2014 | Homelite 240, 245 Oil Pump Cover
1955 Ford Crwn Vic neutral switch will permit start in any gear not just neut or park. Is this a 2 or 3 speed auto transmission? will start in drive selection and only shift once witn no kickdown gear at...
A 1955 Ford would have a Ford-o-matic transmission which has three speeds forward. The transmission starts out in second gear unless you shift into low.
I am not aware of these transmissions having a neutral safety switch.
The 3 speed automatic transmissions that started in low and had a downshift to second under load were first used in the mid 1960s.
Apr 09, 2013 | 1991 Ford Ranger Supercab
Need wiring diagram for 1955 ford
1955 ford what ?? a E93A 6v system or a ford zephyr ,ford pilot thames van or thames trader truck
Aug 01, 2012 | Mercury Montclair Cars & Trucks
Looking for a 1955 ford f100 manual
http://cgi.ebay.com/ebaymotors/1955-F100-F250-COURIER-FORD-TRUCK-FACTS-MANUAL-_W0QQcmdZViewItemQQhashZitem255b5f59d5QQitemZ160446765525QQptZMotorsQ5fManualsQ5fLiterature
http://cgi.ebay.com/ebaymotors/1955-Ford-Truck-Owners-Manual-F100-F250-F350-F-100-_W0QQcmdZViewItemQQhashZitem230f79bf74QQitemZ150583492468QQptZMotorsQ5fManualsQ5fLiterature
always check ebay and do a google search first
Jun 22, 2011 | Ford F-100 Cars & Trucks
Vehicle Parts & Accessories Logo
14 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
