Question about EnGenius Computers & Internet
My ens200ext engenius works fine with a windows laptop ; my iphone sees the network; i give in the password but the phone does not connect. Ipad neither. i have wpa2-psk on.
SOURCE: Will not automatically connect to network. Must reconnect manually each time.
Hi Bear001,
I do not understand what you mean. The only entry that is asked for is the security code, the length of which varies depending on whether we try WPA or WEP. We are not working on a network, only using the router to broadcast a signal for the satellite laptop to use to access the web.
Thanks.
Mark F
Posted on Dec 25, 2007
Joed911
  • 4338 Answers
SOURCE: Need security option
The security code is set in the wireless section of the router. You need to access the router's setup page and go to wireless. Under security you will see the encryption key which you need for your adapter.
The setup page is at 192.168.0.1. Put that in your browser.
It will open to the router's setup page.
You should see a box prompting you for your username and password. Enter your username and password now. By default the username is admin, and the password is password. Click the Ok button to log in to your router. Then go to wireless tab, then security.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Oct 19, 2008
tanvierahmed
  • 118 Answers
SOURCE: Wi-fi WPA2 Support?
Try doing the following:
1.) Go to Start -> Control Panel -> Performance and Maintenance -> Administrative Tools -> Services.
2.) Scroll down to Wireless Zero Configuration, and double-click Wireless Zero Configuration.
3.) On the General tab, after Startup type, change the startup type to Automatic.
4.) Start the service by clicking Start.
Let us know if this works, and good luck!
Posted on Dec 03, 2008
marketex
  • 371 Answers
SOURCE: Apple Extreme Network not picked up by Windows XP laptop.
it's a matter of who did what with whom and when they did it.
Vista came along when Apple and Microsoft had agreed to allow each other OS's to operate in each other's platforms with Intel performing the Core Duo marriage, but XP is the child from a previous generation when the two did not get along, though they knew of each other.
I know some actual marriages like that.
Didn't mean to be flippant, but XP is better than Vista in some respects and worse in this case.
Posted on Mar 27, 2009
  • 11 Answers
SOURCE: passphrase required by wireless network how to
first if you wire to the router, you can 'talk' to the router to find out the password.
Once wired open internet explorer.
go to the address, (not a search bar, the address bar at the very top. http:// etc.)
type 192.168.2.1 and go, or enter on your keyboard. password is blank by default. go to the wireless section and read or change the pass phrase for the wireless.
Posted on Aug 02, 2009
How do i reset my iPad that's currently disabled and won't let me connect with iTunes?
You connect your iPad to a COMPUTER with iTunes on it. That is the only way to load the Operating System if you can't do it from Settings on the iPad.
Also, iTunes will give you the option to back everything first. Then after the Reset, you Restore to the back up and all your App, music, mail and everything come back.
If you can get into Settings on the iPad, reply back as a COMMENT below this post.
Jan 23, 2017 | Tablets & eReaders
HOW do i use wps on my ipad with WNR2000
Depending on your browser, download or display the pdf of the WNR2000 manual ( http://documentation.netgear.com/wnr2000/enu/202-10397-01/pdfs/FullManual.pdf ). The manual might also be found on the CD that came with the router.Follow instructions Chapter 2 Page 7 to enable/setup WPA2-PSK (AES).Make sure you SAVE/APPLY the settings before proceeding. Follow instructions Chapter 2 Page 17 to Disable Router's PIN. When you do, make sure you leave the box checked to "Keep Existing Wireless Settings".Make sure you SAVE/APPLY the settings before proceeding.Here's a work-around ff the above doesn't fix the issue for you. Sorry I don't have iPad-specific instructions, but I don't have access to an iPad/iPhone at the moment. I've done the following on iPads, iPhones, Android phones and tablets, Windows phones and PC's - it works on virtually all Wi-Fi-capable devices..:
Instead of letting your iPad find the network and trying to connect with the password, try manually creating a new Wi-Fi network connection by typing in your Wi-Fi network name (SSID), selecting WPA2 (AES) encryption and entering the Wi-Fi password your configured in STEP 2 above.Please note: You'll have to forget the Wi-Fi network in your iPad's settings if you keep your Wi-Fi network name (SSID) the same as it is currently.
May 25, 2016 | NetGear WNR2000 Wireless Router
How can i get passcode
Unfortunately there is no way to get your pass-code back.
You can reset your iPhone using your i-tunes on your computer. Unless you have a restore date that is before the pass-code existed you will have to reset your phone.
You could also try to reset your pass code through find my iPhone on icloud.com but this may result in a temporary unusable phone.
you can follow this link to reset your phone:
https://support.apple.com/en-us/HT204306
Hoped this helped my best wishes to ya.
May 24, 2016 | Apple iPad (16 GB) WiFi Tablet PC
My iphone 4's power button is broke. How do I reboot?
An easy way to reboot iPhone without power button or home button is to reset your network settings. Note that by doing this, your iPhone or iPad will forget your Wi-Fi passwords, Bluetooth preferences etc.
  1. Go to Settings app and go to "General" and then to "Reset".
  2. Locate "Reset Network Settings" and select it, enter your passcode if asked, then tap to confirm and reboot the iPhone, iPad, or iPod touch.
iphone-4s-power-button-broke-oxaxc0rwhkhzilrwacqreyis-5-0.jpg While this works to restart all iPhone, iPad, and iPod touch devices when power button is broken, you will lose wireless settings, like Wi-Fi passwords, VPN details, and Bluetooth connections.Therefore be ready for that and jot down any complex logins or details beforehand.
How to Restart iPhone without Power Button
Dec 17, 2014 | Cell Phones
Hp laptop compaq nc6120 sees wifi hotspot for my iPhone, but will not connect. iPhone hotspot works fine on iPad. Hp laptop operating with win 7.
this sounds like your windows laptop is not compatible with an apple wifi connection, i've heard of this happening before, you may need to find another wifi connection for that laptop
Jan 17, 2013 | HP Compaq nc6120 Notebook
My ipad and iphone will not work on wifi
clear the wifi password if any and try again, this way you can isolate the problem weather its the wireless network or its encryption.
other idea came across my mind if the clearance of the encryption key did not solve the problem, degrade the used wifi standard, since the router is capable of supporting 802.11n, perhaps your ipad/phone does not. So degrade the wireless mode of the router to 802.11g and try
good luck,
Majdi
Dec 28, 2011 | Linksys WRT120N Router
My N1 vison keep losing on wireless connection when i used 2-3 wireless devices in same time. My connection is wired to my Desktop PC & wirelessly to 1 laptop, 1 iPhone and newly 1 iPad. I noticed that...
If you have a 3G phone in the house, It operates at the same frequency and is a nono.
If not I would suggest you completley rest modem and re-enter U/N, P/W etc and set up secure network also. If still a problem, maybe faulty modem.
May 10, 2010 | Belkin N1 Vision Router
Iphone doesn't work with router Dell 1184 broadband router in my house works with windows laptops but not Apple iPhone or iTouch. I have had the router/software installed for 5 years, is there new software...
you said the laptop is connected to the network.
when you try to connect to the wireless network on the i-touch or i-phone, do you see your network.
if your network is secured then you must enter the correct password for the wireless. If you are not sure about the wireless key or the password then you will need to open the router set up page and check the wireless settings.
you can also try to upgrade the firmware ( software) of the router.
Click Here to know more about router and network
Jan 10, 2010 | Dell TrueMobile 1184 Wireless Broadband...
Computers & Internet Logo
82 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
