Question about Vizio All-in-One CA24-A2 24-Inch Desktop
Why is my all-in-one powering down?
My All-in-One will power down unexpectedly with no warning. I'm running antiviral that is kept up to date so I don't think its infected. Any thoughts?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 74 Answers
Heat. Plain and simple. Check ALL air vents
Posted on Oct 27, 2013
My Dell windows 10 will not log off circle keeps spinning
Usually, this means that something either running in the background, or an app, or an update trying to install is keeping the pc from shutting down. Wait about an hour if it is still just sitting there spinning you may want to do a hard power down.
WARNING forcing your pc to power off may have unexpected results not limited to unable to power up and lost data.
To force the pc down press and hold the power button until the unit switches off. Immediately restart the unit and do a thourough review to ensure proper operation.
Aug 20, 2016 | Dell Inspiron Computers & Internet
Why is my acer aspire shutting down
If you're running Windows go into Control Panel and check Event Viewer. Look under Windows, System, and look at any Warnings (Yellow triangles with exclamation marks) If you're seeing error codes you can look those up; if "unexpected shutdown" shows up a lot your laptop could be overheating or it may be a power issue.
Aug 27, 2014 | Computers & Internet
MY COMPUTER SHUT DOWN UNEXPECTEDLY AND WON'T TURN ON AGAIN
I usually try to hold the power button for >5 seconds to reset it. No lights even when plugged in?
Jan 01, 2013 | Computers & Internet
My lenovo G460 shuts down unexpectedly
http://ct.download.com/clicks?t=1141982088-ce770fd4fbc57664a08aea1a8f03b80d-bf&brand=DOWNLOAD&s=5
avg free 2012
http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html
microsoft security essentials your operating system must be registered
Win7/Vista/XP 64 bit
http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7
http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information
malware protection
http://100-downloads.com/download.php?p=615
windows xp microsoft security essentials
http://100-downloads.com/download.php?p=614
windows 7 microsoft security essentials
If you believe a virus may be the cause of your laptop's shutdown problem, run a virus scan on the system to find out if any exist.
if your laptop keeps shutting off
If your laptop suddenly shuts itself off for no apparent reason, there are several factors that can contribute to the problem.
When you troubleshoot the laptop, remember that it is also possible for a combination of causes to be at work.
Excessive Heat
Keep Cool
All newer laptops have built-in heat sensors that shut the computer off when it exceeds a pre-set temperature threshold. Install and run a temperature monitoring utility to determine whether the laptop is overheating.
might be getting hot
check you CPU make sure its securely seated and has thermal grease
http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490
Hardware Issues
If you replaced or installed new hardware in your laptop, use the device management utility to review if there are any resource conflict or failure reports. You can also remove unnecessary hardware and run the laptop to see if the problem persists. If it doesn't, reinstall each hardware component and re-test until the laptop fails.
Operating System Issues
The operating system start-up controls can affect how the laptop performs.
Follow the operating system developer's instructions for entering the start-up program, and confirm that the settings are what your laptop requires.
Power Supply
If your laptop is not getting the correct power it requires, it will shut down completely. Test the current of any outlets you use with your computer, employ a surge protector to ensure steady current, and confirm that the power supply itself is not defective.
Battery
Failing batteries can produce unexpected laptop shutdowns.
Use a battery monitoring utility to determine whether or not the battery is healthy and replace it if it isn't.
Malware
Unfortunately, rootkits and viruses can cause your laptop to shut down without warning.
You will probably have to take the hard drive out of the laptop to be able to scan it fully and remove any malware that is installed, or the laptop will shut down before the scan and repair can finish.
http://www.malwarebytes.org/mbam.php
Malwarebytes is as the name says, a Malware Remover!
Download the Free Version from the link above.
Download, install, update and scan once a fortnight.
http://www.spybot.info/en/index.html
Spybot Search & Destroy 1.6.2 is a very good, FREE Anti-Spyware Program.
Download, install and update it.
Then SCAN with it.
Update it, and scan your System once a fortnight.
Hope this helps
Oct 29, 2012 | Lenovo G460 Laptop Computer - 06777TU...
Asus u52 shut down unexpectedly
When the CPU overheats then it will shut down (i.e. thermaloverload) and won't boot up again until it has cooled down. If this is theproblem is not fixed then the CPU will eventually fail.
A faulty fan causes the problem or the fan and heat sink assembly are cloggedwith dust.
Check the CPU fan to see if it spins freely, if not replace the fan.
If the fan and heat sink is clogged with dust the remove the dust and make surethe vents are clear and dust free. Use a small brush and can of compressed airto do this.
Jun 17, 2012 | ASUS U52F-BBL9 Laptop
My Sony Dream Machine won't save the correct time. When I set the date, it defaults back to 2009, and even when I get the correct time set, the clock won't advance. It's been 8:52 PM for...
My wife's unit has the same issue - tried the firmware update (from Sony's website) and their suggested fix with no luck. Still works as a digital picture frame, but wrong date and stuck time kind of disappoint.
FYI - Suggested fix for stuck date/time:
Unplug unit.
Remove backup battery.
Leave for 30 seconds.
Plug back in and then put battery back.
Set date and time.
Didn't work for me, but maybe you'll have better luck.
Sep 07, 2011 | Sony Dream Machine FMAM radio with...
My laptop shut off after about 10 seconds
check the cooling fan if not running for if not the comouter will shut off
Dec 19, 2010 | HP Pavilion zd8000 Notebook
Acer aspire 5000 unexpected shutdowns, random, fan running.
Hello
Thank you for using FixYa.
Have you cleaned out the airvents and fan area. these build up with dust and if the unit gets too hot it will shut down unexpected
Also always use on a hard surface so the airvents are kept clear
thanks
Richard
Nov 17, 2009 | Acer Aspire 5100-3357 Notebook
Acer 5520 power shutdown
Possible heat issue. Check the cooling fans and see if theyre running. Usually one on the bottom, back or side of the laptop. Make sure that the cooling vents arent blocked during use.
Apr 04, 2009 | Acer Aspire 5520-5908 Notebook
Vizio All-in-One CA24-A2 24-Inch Desktop Logo
60 people viewed this question
Top Vizio Computers & Internet Experts
justwinwin
Are you a Vizio Computer and Internet Expert? Answer questions, earn points and help others
