Question about Staples EPS611X (CrossCut) Shredder
Manual unit overheated when a jam occurred. Cleared jam but when unit was plugged back in it didn't start. If I push medal tab in back motor goes into reverse. When I release tab motor stops. Is there some sort of reset procedure to get unit up and running?
Paper jam in rear
Hi Linda,
1.Open the front cover.
2.Pull out the drum unit and toner cartridge assembly.
3.Open the back cover.
4.Pull the tab toward you to open the rear chute cover.
5.Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull out the paper with the other hand.
6. Close the back cover.
7. Put the drum unit and toner cartridge assembly back into the machine.
8.Close the front cover.
If the error is not cleared, turn the power off on your Brother machine.
If the problem still continues, please contact Brother Customer Service from "Contact Us".
9. Make a test copy. If the machine jams again, try the followings:
10. Make a test copy. If the machine jams again, use new paper from a fresh, unopened ream of paper. If the machine still jams, please contact Brother Customer Service from "Contact Us".
Still having Problem Then follow Us For
Brother Printer Support
Feb 19, 2014 | Brother MFC Office Equipment & Supplies
Gold medal 2404 won't heat
Double check that the kettle is plugged into cabinet.
Does the Switch light up? if not it is the switch is bad.
If it does, than either it is the kettle lead wires, or themostat, or the heat element that is bad. In that order.
Oct 06, 2012 | Gold Medal 2404 Funpop Popcorn Maker
Can't open the window or the tailgate,with the key or the electronic button
Sounds like a jam has occurred try to push the tailgate in and hold it as someone else tries to push the button.
Sep 17, 2012 | 1996 Chevrolet Blazer
Paper jam. Sheet printed but didn't pass through the rollers
  • Remove the paper tray completely by pulling it out towards you.
  • Now pull the jammed/stuck paper out gently.
  • If you cannot remove the paper by the above procedures,open the printers front cover to access the cartridges assembly.
  • Pull the cartridges assembly gently and slowly.This will come out together with the jammed paper.
  • If jam not cleared,open the back cover and pull the tab outwards to access the fuser unit.Remove the stuck papers here.
  • Hope this helps.Thanks!
Oct 31, 2011 | Brother HL-2040 Laser Printer
I have an HP OfficeJet G85xi, and it keeps displaying a "paper jam" error. There's not paper jammed, and the back rollers keep spinning every time I turn the machine on. I've wiped those...
I see you mentioned a Paper Jam Error occurs even if there is no paper Jam in the printer.
You also mentioned that the back Rollers keep on spinning when you turn the printer ON seems the printer still detects a piece of paper inside, if the sensor detects Jams inside the roller will spin trying to roll out the paper it detects, makes sure that all jams in the very inside of the printer is checked for any small piece of paper, it can some times tear and small pieces can be lodged on the sides or stuck somewhere.
Manual
Sep 04, 2011 | Office Equipment & Supplies
Ge dryer - buzzes when the start button is pushed but the dryer motor doesn't start or the dryer drum moves. could be a jam or the motor? Motor didn't seem to be a problem before today.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 16, 2011 | GE 5.8 Cu. Ft. 2-Cycle Extra-Large...
The covers are melting, sagging in the middle
From what you have described , the damage to the unit is rather advanced and I would suspect, unrepairable at this point. Just to many critical parts involved. Obviously, the heat overload sensor failed and allowed the unit to get grossly overheated. I'm surprised it didn't burst into flames. For now, disconnect the unit from it's power source and refrain from using it. Check your Owners Manual and hopefully it's still under warranty. If so, contact Sanyo about warranty replacement of the unit and any other occurring labor charges.
I'm sorry, I wish I had better news for you.
Apr 20, 2011 | Sanyo STW0923H2 Air Conditioner Heat Pump
The paper will jam when making a copy. I have cleared the paper from the door on the back of the machine. The paper dislodges in one piece. I do not see any more paper by lifting the top tray. Are they...
To answer your last question first, any copy machine or printer that uses toner, by design, will get very hot in the back of the machine. This radiant heat is coming from the fusing unit, when acts as an oven to burn the toner to the paper; and generally overheating problems will not cause jamming. More than likely you have a physical obstruction blocking the paper path, my suggestion to you would be to take a thick piece of cardstock and manually pass it through the paper transport section. This act will force out any small paper dust or debris in the transport section; also, I'd recommend spraying some canned air through the path as well. Out of curiosity, when the paper jammed, did it appear to be bent or torn in a particular area of the page?
Let me know.
-David.
Nov 07, 2010 | Samsung CLX-3170FN All-In-One Laser...
Printer jam
Title:
How do I clear paper jams?
Description:
If a paper jam occurs, the Paper LED will flash as shown below.
c_panel_cover_open.gif Caution
    After you have used the printer, some parts inside the printer are extremely hot. When you open the front cover or face-up output tray of the printer, never touch the shaded parts shown below.
  1. Remove the paper tray from the printer.
  1. Pull the jammed paper up and out of the printer.
  1. Open the front cover.
  1. Pull out the drum unit and toner cartridge assembly slowly. The jammed paper will be pulled out with the drum unit and toner cartridge assembly.
c_hl20_03221.gif Caution
    To prevent damage to the printer caused by static electricity, do not touch the electrodes shown below.
  1. Open the back cover.
  1. Pull the tab toward you to open the rear chute cover.
  1. Pull the jammed paper out of the fuser unit. If the jammed paper cannot be pulled out easily, push down the tab with one hand as you gently pull the paper out with other.
  1. Close the back cover.
  1. Push the lock lever down and take the toner cartridge out of the drum unit. Take out the jammed paper if there is any inside the drum unit.
  1. Put the toner cartridge into the drum unit until you hear it lock into place. If you put it in properly, the lock lever will lift automatically.
c_hl20_025121.gif Caution
    To avoid print quality problems, DO NOT touch the shaded part shown in the illustration.
    If you accidentaly touch the shaded part, wipe the surface with a dry lint-free soft cloth.
  1. Put the drum unit and toner cartridge assembly back in the printer.
  1. Put the paper tray firmly back in the printer.
  1. Close the front cover.
    Make sure that the Paper LED is now off and the printer is ready.
Apr 05, 2009 | Brother HL-2040 Laser Printer
BADGER GARBAGE DISPOSAL just humms. does not work.
It sounds like the disposer has something jamming it. Try using the breaker wrench supplied with the disposer (or a suitable-size hex wrench) fitted into the socket on the bottom. Rock the wrench back and forth to see if you can loosen the jam. Another trick is to use a wooden rod (end of a broom handle, for example) to push on the blade to try dislodging the jam. Look inside with a flashlight to see if there is something that is easily missed. (I have found drink can tabs, coins and a shelf clip that way.)
It's also possible the motor starting capacitor inside the disposer or the motor itself is bad, in which case you would probably spend less on a new disposer than on repairing this one. But a jam is more likely.
Jan 28, 2009 | Ace Hardware InSinkErator Badger 5, 1/2 HP...
Staples EPS611X (CrossCut) Shredder Logo
Top Staples Office Equipment & Supplies Experts
Saleem Baig
Saleem Baig
Randy Schumann
Randy Schumann
Are you a Staples Office Equipment and Supply Expert? Answer questions, earn points and help others
