Question about Dryers
Noisy/shaking dryer Started in last couple of weeks and getting worse. Obviously turns and heats (for now). LG model DLE0442W and is 3 years old. Thank you!
  • Dryers Master
  • 17,093 Answers
There is a bearing on the drum and guides at the front of the drum. You will have to remove the top of the machine to see the drum parts. Unplug it first. The top then pops off. Look at the back of the drum to see if the bearing is bad.
Posted on Jul 23, 2013
I have a LG Tromm dle0442w doesn't heat blow out cold air
It is caused by three possible candidates:
(1) The thermal fuse
(2) Heating element
(3) High limit thermostat.
Have these devices checked out and replace the faulty part.
Feb 28, 2015 | LG Dryers
Need to remove front panel of dle0442w to get to heat limit switch
unplug the dryer,remove the top panel,remove the control panel,usually a couple of screws on the top right and left side,when you get the control panel off there are like 4 screws on the top front panel then open the door and remove 2 more screws,disconnect door switch.go here this will help you out i'm trying to go by memory and it's harder to remember how to do it,when i'm in front of it i can pull it apart no problem but this should help you out.
http://www.youtube.com/watch?v=RvbJn61d9hQ
Nov 08, 2013 | LG Home Applaince LG DLE0442W 7.3 Cu. Ft....
Dryer not heating
Hello Krazy
If your dryer tumbles, but there is no heat. You need to check this following:
Check for proper air flow
Test the safety fuse
Test the thermostats
Test the centrifugal switch
Test the timer motor
Test the heating element
Best Regards
Neciforo Llanto
Sep 30, 2013 | LG Home Applaince LG DLE0442W 7.3 Cu. Ft....
LG DLe0442W Dryer working but no heat at all.
Check the heating element. That is were the fault is coming from.
Jan 09, 2012 | LG DLE2532W Electric Dryer
Hello, I have an LG DLE0442W electric dryer. It is about 2 years old. It started to take a long time to dry so I checked the venting and it seems fine. I also checked the breaker and it had not tripped....
Hello Mrs. Noble- I would ask if you have gone to the outside of the house and felt the air flow out of the dryer vent where it exits the exterior wall, if you have, and it is blowing strong then you may have a problem with a thermostat or thermal fuse. You should probably have an LG Tech out to diagnose the issue if the venting is not an issue. Good luck and best regards.
Sep 27, 2010 | Dryers
Fisher and paykel dryer works but very noisy
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Dec 27, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Shutting off and on...
the problem may be due to dry soldering in the power supply stage if it was with the lamp there would be red or green light showing the presence of the power to the tv after making it own some of the components get hot and it will make the the soldering point conectionless and after some time the heat sink get cooled and the soldering point gets connected and u will see the picture again it is a simple problem if u have a soldering iron u make it hot and re solder all the components in the first part of the circuit board and the problem if rectified
Jul 03, 2007 | LG RU52SZ30 52" Television
Dryers Logo
Top Dryers Experts
