Question about Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7
Hayward super pump C48K2N143B1 White wire with Black stripe is detached.
The White wire with the black stripe became detached on my pump. it has a square clip to go on one of the terminals but I dont know which. Help.
    Top Expert:
  • Hayward Master
  • 5,673 Answers
Look on side of motor it has a schematic should go to L2
Posted on Mar 05, 2016
  • 323 Answers
SOURCE: Wiring Hayward pool pump
John what you have is a 240 volt motor on that pump. It will not connect to a 120 volt cord. You'll have to get a different pump.
Sirwriter
Posted on May 15, 2009
john224
  • 1378 Answers
SOURCE: wire Hayward Super Pump for 115
If you look closely, you should see a small arrow on the black plastic piece on the terminal block(jumper). That arrow lines up with either the 115 or 230 mark on the white terminal board. Make sure it is aligned with the 115.
Then put you two line wires on. It does not matter which wire goes to line 1 and line 2, just be sure you DO NOT put them both on the same terminal. A plastic divider usually seperates the two line connection terminals.
Posted on Jun 13, 2009
MNfisherman
  • 11896 Answers
SOURCE: my hayward super pump has a wiring diagram but it
Is one screw silver and one brass? Or are they both silver or both brass?
Posted on Aug 20, 2009
  • 990 Answers
SOURCE: I have a Hayward Max-Flo Pump model no. C48K2N143B1!!
To the motor housing. This will be a green screw on the top of the wire box in the back of the motor. It will be inside the wire box but on the outside edge of the housing.
Posted on Jul 19, 2010
  • 366 Answers
SOURCE: I have a 1 hp
If you've never done it before, it can be a bid deal. You will need to get the exact replacement motor (1hp square flange), a shaft seal, impeller wrench, and be prepared to replace o-rings and rewire the new motor. If you're not comfortable dealing with electrical/mechanical, you're better off getting a service tech to help you out.
Posted on Sep 16, 2010
I have a new C48K2N143B1 that I'm replacing the same model that has quit. It came configured for 230 and I switched the tab for 120. Wired everything the same as the old motor and it keeps tripping the...
make sure you have clean source voltage coming in like a knicked wire touching the case, also make sure you dont have the hot wire leads touching the frame or something else
Jun 19, 2014 | Hayward 3/4hp Super Pump Inground Pool...
I am replacing a 230V single speed AO Smith with a hayward super pump 230V two speed of proper size. Out of the super pump are two purple wires, a black wire and the green ground wire. The superpump has...
It sounds like you need to purchase a 2-speed switch for the rear of your super pump. With your current set-up, you will only be able to connect either a low speed, or a high speed and not both.
If you confiirm this via my e-mail, I can further guide you as to what you need to do next. If you just want to connect the high speed for now I can also help with that. By the way, are both purple wires solid in color, or does one have a black stripe on it?
If this post has helped you, please take the time to vote positively for me after reading this.
Thanks,
Adam
Oct 26, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
I have a 1 hp hayward super pump. the model # of the motor is C48K2n143B1. I need to replace the motor only. is it a big deal?
Sep 15, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Jul 18, 2010 | Hayward 3/4hp Super Pump Inground Pool...
If you are replacing a 2 hp pump with a Hayward 2 hp super pump on a 220 line is L1 white and L2 black
Shouldn't be a white line on a 220 circuit but some people use them. Red and Black is the standard. If you are sure they supply 220 VAC, which I would verify, it doesn't matter which one goes to which terminal. 120 or 3 phase matters. If you have a multi meter, put the red lead on the black wire and the black lead on the white wire. If you read 220, good. If you read 120, it will make a difference.
Jun 26, 2010 | Hayward SUPERPUMP 2.0 HP, 115/230V
Wire Hayward Super Pump for 115
Jun 13, 2009 | Hayward SUPERPUMP 2.0 HP, 115/230V
Hayward 3/4hp Super Pump Inground Pool Pump 115/230 Volt # Sp2605x7 Logo
139 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
