Question about AKG K-77 Headphones
Left headphone isn't working
The problem doesnt seem to be in the cable or plug, theres no "noise" when I move them trying to find a spot where it works. Is there anything I can try?
I can only hear out of the left side of the headphones. They are only 1 month old and they worked fine at first.
Hi Terry,
if the headphones have removable cable, try another cable to check the cable connection to ensure it is ok, also check your headphones in another device to ensure it is not the device is causing the problem. also check your balance settings are central on stereo devices the balance can be set left and right. if the cable is fixed try moving the cable over the whole length with music playing to see if the speaker makes any noise at all this indicates the cable is broken, as your headphones are only 1 month old you have full garantee from the maker, as long as you can show they have not been damaged through rough handling or overloading with too loud sound. it can happen that new headphones fail shortly after purchase due to component failure or weak connections.
I hope this was useful.
Feb 25, 2015 | Audio Players & Recorders
Headphone Port
try a new set of headphones.. if that doesnt work then i would see if you can see any dust in the headphone socket.. maybe try putting a coctail stick in and see if anything comes out.. please be gentle though. if nothing comes out you could need the headphone socket repairing
Apr 06, 2014 | LG G2 Black D802 Factory Unlocked 5.2"...
Only 1 side of my dr dre detox is working
THE INTERNAL WIRE CONNECTING BOTH HEADPHONES IS BROKEN. THIS PROBABLY HAPPENED WHEN TWISTING ONE OF THE HEADPHONES TO HEAR ONLY THROUGH ONE OF THEM. TRY FEEDING EEACH HEADPHONE INDEPENDENTLY WITH ITS OWN CABLE USING ONE OF THOSE PLUGS TO SHARE MUSIC FROM SAME SOURCE.
Jun 22, 2012 | Beats By Dr Dre Beats By Dre Detox
My Samson C01U microphone doesnt seem to be working. the green light doesnt turn on when i plug it into the usb port of my computer. I have windows vista. Is it not compatible?? The computer says the...
Sorry this isn't a solution but just letting you know I'm having the same trouble, the funny thing is mine was working a couple of months back and now its not, it's driving me crazy.
May 19, 2011 | Samson C01U Consumer Microphone
My left channel in sennheiser hd 465 is not working and will not play any sounds. please help!
As long as it is NOT a wireless or noise cancel type, try looking at my tip on headphones dodgy cable/plug problems.
Aug 09, 2010 | Sennheiser HD 465 Headphones
Colors of the wires for CX 400 headphones
yellow and red-green are most likely grounds. red is normally the right channel and green is normally the left channel. quick question though, why on earth would you cut the plug off of a pair of 75-90$ headphones?
Apr 15, 2010 | Sennheiser CX 400 Headphones
On the right side of me JBL headphone doesnt work pulled the cord by accident
You must have broken the cable somewhere. If you move it around you might get it to come on, try it all over to determine where the break is. If very close to the headshell you might want to consider a new cable. If in the middle you can cutt it off before the break and fit a new plug. Then get an extension cable to complete the length.
If at the plug end follow what follows:
Cutt the old ******** and buy a new plug. Cutt it off 10cm before the plug end if the break is the plug section. Most hadphones are fitted with a 3.5mm jack. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
Mar 20, 2010 | JBL Reference 410 Headphones (Black)
Headphones: only left speaker works
yes if you have a multimiter and a soler iron, just check the cable where is moving allot, for example for the headphones near the volume controler, near connector or near you eyers is more likely to brake
Aug 20, 2009 | Audio Players & Recorders
Operating manual
After connecting all cables.... try channel 1 at the receiver... then move tuner up and down until the green light on the left headphone lights up and you can hear whatever you are listening to. If channel 1 doesnt work, try 2 and 3...... mine is set on CH3.
Good luck
Oct 31, 2007 | Acoustic Research AW-721 Consumer...
AKG K-77 Headphones Logo
87 people viewed this question
Top AKG Audio Players & Recorders Experts
Vito Vacirca Jr.
Ben Armstrong
Edward Carrington...
Level 1 Expert
Are you an AKG Audio Player and Recorder Expert? Answer questions, earn points and help others
