Question about Vizio E322VL 32 in. LCD TV
Won't Turn On/No Link or Activity lights
The television will not turn on when the Link or Activity Lights aren't on (plugged into a router). My only option is to pull the power cord, wait 5 seconds, plug it back in, and if I don't see the lights within 5 seconds, I repeat the process. If I'm successful, the VIZIO light will flash orange and white before it's good to go. Occasionally it will stop flashing on white and the television is unusable. Could this be something I could fix? The TV isn't very old and it isn't used very much.
4 Suggested Answers
Raditronic
  • 196 Answers
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Posted on Apr 30, 2010
freetek
  • 5568 Answers
SOURCE: My vizio e420vl turned itself
There are at least two power supplies in any set with remote capabilities; one is on any time the set is plugged into AC and is supplying that indicator and the receiving circuit of the remote, otherwise it wouldn't turn on under normal conditions. The second power supply produces the needed service voltages used when the set is in use. This second supply is a common failure in many sets and it is generally traceable to poor design and the use of low-quality components of a certain type. Vizio may have a repair or exchange program through their service center. I would guess the cost will be between $50-$150 and you might remove the back panel of the set and look for a smaller board with larger-than-average parts on it and is related to the AC cord coming in. It should be fairly easy to remove and replace as these are often outsourced and just plugged into the rest of the set with dissimilar plugs making it simple to install and reinstall.
Posted on May 29, 2011
chesterpendi
  • 195 Answers
SOURCE: Vizio E550VL won't turn on. The vizio logo just flashes orange.
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Posted on Dec 07, 2011
Dashboard lights aren't working when the light
You don't indicate what kind of vehicle you have but my guess is you have a cross feed between the dash light circuit and the ignition circuit. You'll probably have to isolate these two circuits (not an easy task).
May 15, 2013 | Cars & Trucks
When i plug my dlink DSL-2640U router the lights start flashing and every time it flashs the wireless just drops down and i have to enable it from the settings .. then the router's lights flash an
The led always flash with activity. They are transmitting and receiving data. If they stop flashing your ISP signal has stopped. Could you explain this statement" the wireless just drops down and i have to enable it from the settings"?
Dec 20, 2012 | D-Link Computers & Internet
Won't turn on and no lights on when plugged in
Check and replace the back light inverter board.
Sep 29, 2012 | Sharp LC37SB24U 37 in. LCD TV
Why aren't my turn signals, brake lights, parking lights, dome lights and trunk light not working when the fuses are good?
A mechanic would check for power at the headlight switch and turn signal switch then go from there.
Might be a fuseable link in the engine compartment.
Jul 20, 2012 | Ford Cars & Trucks
Fuel gage quit, turn signals canceler quit, fuel pump quit, won't start
With the bike turned off, remove the TSM/TSSM. This is the security module. Make the sure these connections aren't wet. And quit powerwashing your bike!
May 19, 2012 | 2002 Harley Davidson FLSTF - FLSTFI Fat...
I have a Linksys E1000 wireless router. It has been working fine. The power cord it is on was unplugged briefly last night. Now when I plug it back in, all the blue lights are flashing and I can't get...
have you tryed turning off computer, router, and modem if you have one. then unplug all connections from router (phone line, ethernet net cable and power cord). Then wait 2 min then plug all back in, and turn on modem, router, then computer. We lost power yesterday for 3 hrs and I needed to actually turn in all off and unplug power cords then turn it all back on to rest and reboot them to get them working properly. Hope it helps.
Sep 25, 2011 | Cisco Linksys E1000 WirelessN Broadband...
I have used the Linksys CD to setup my wireless connection to e1000 wireless router; in diagnostics, I discover that I am connected to the router but not to the internet. I also try setting up ethernet to...
Make sure the Modem is plugged into the correct port on the E1000 (far left port labelled 'internet' on a yellow background). Unplug all the devices power cables and restart them in order from the wall (modem - router - PC/MAC) make sure the modem has link and activity lights flashing, if there is a light for 'internet' wait for it to be on before plugging in the router. You might want to call your ISP and confirm theres nothing funky with the line/modem.
Aug 22, 2011 | Linksys E1000 IEEE 80211bgn Wireless...
My 2006 1600 Vulcan Nomad will not start. I was riding on the freeway fine. got off stopped at a signal light and it stopped running, Checked battery its has plent of juice , but not lights light up when...
Check all the connections make sure they aren't loose. Check the ignitor module and make sure it is plugged in correctly. Your rectifier might be dead or dying.
Might even be your side stand lockout switch. If that is dead you won't be going anywhere.
Jul 31, 2011 | kawasaki KX 85 Motorcycles
Vizio E322VL 32 in. LCD TV Logo
32 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
