Question about Home Security
CIF Resolution What does CIF, D1, HD-SDI, CCD CCTV mean?
Trying to set up system 1080 p. TV is 720. In setup said was incompatible. Now we have no screen to change it
You have two options: upgrade to 1080 TV's or monitors, or downgrade your security system to one compatible with your 720 screen. For security purposes, the 1080 system will offer a clearer picture when details may be of utmost importance. With that in mind, the first option would be the best.
May 15, 2016 | GW Security Complete Professional 16...
How do i re set my qvis cctv system
Open the case. There is a button cell inside. Remove that for about 12 hours with the CCTV disconnected from the mains. The password should be reset.
Feb 20, 2015 | Sharp Qvis Apollo Hd 16 Channel Security...
Can i connect to my laptop with that cctv view where i can see all camera on same screen?
you will need a multiplexer to connect all your cameras into and out to laptop on the front of the multiplexer you can use the buttons to see one or all the cameras you have installed.
May 24, 2014 | Astak Wireless 2.4ghz Night Vision Color...
What does CIF, D1, HD- SDI mean?
These are all resolution settings. CIF is very low resolution to HD-SDI which is very high resolution. The concern is bandwidth. The higher the resolution the more information you have to transmit and store.
Jul 22, 2013 | Home Security
No picture on monitor but still plays tape green trigger light not working when remoter is used.
Try using normal operations and see if the camera is working fine. Else it seems like a faulty ccd. You need to exchange under warranty.
Cheers
TeaCii
If you own website, add live support almost free
Let real security guard watch your cam for $1/day
Jan 21, 2010 | Ktl Cctv CFB2056IR Black and White...
Hi I would like know how can i zoom in to get
If you are downloading the Video from a Panasonic DVR then you should have the option to zoon in from the player. This option onexists on some of the cameras.
If you are recornding analogue in 2 cif then you will loose detail in the picture when trying to aoom in. If you are recording in 4 cif then you will still loose some sdetail if you have the ability to zoom in with the Panasonic viewer software.
This software download is available right from the Panasonic DVR through the user GUI
Sep 15, 2009 | Panasonic WV-CP280 CCTV Camera
Installed wireless cctv in horse stables 4 mt x 6mt dont seem to
the gain is turned up to much this is washing out the camera
another possible cause is the auto iris lens is either not set properly or stuck open.
if you are using a "bullet" camera that may not be adjustable without opening it up and removing the camera from the aluminum housing.
its usually a tiny screw that you turn up or down. could also be that the CCD or cmos image chip is dying
Mar 11, 2009 | Ktl Cctv CFB2056IR Black and White...
Philips pc camera
you can manually turn the cameras round thingy until you get the desired picture.
Mar 13, 2008 | Philips J44414
Home Security Logo
14 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
