Pioneer SC-1522-K I disconnected my Pioneer SC-1522-K to move it into a cabinet. When I reconnected it, all I'm getting from my DVD and DVR devices is the audio, no video. I reconnected the unit up the same way I had it when it was working (I'm using HDMI cables from the DVD and DVR players). Any suggestions? I won't swear to this but I believe when I had it connecterd originally to my SONY LCD, I had it connected to the HDMI 1 port, and when selected, it had an icon next to it signifying that it was connected. There is no icon next to the HDMI 1 setting this time around.
  • Audio Player... Master
  • 5,348 Answers
Apart from the obvious one of a dodgy cable or socket. Is there any option on the receiver for assigning devices to any of the ports? Or some king of setting on the receiver to say what that port can be used for? The same to for the device(s) outputting signals to the receiver.
Posted on Jul 24, 2013
SOURCE: No sound from digital cable thru AVR3200 after adding HDTV - DVD plays fine
you need a digital coax cable and then connect it to 6.1 also the digital cable type is not a coomon type so check that also
Posted on Jan 23, 2008
The Machine
  • 788 Answers
SOURCE: How to Connect HDMI Components with AVR 3805 as Hub
In reference to the comment you added to our chat session:
Just connect your receiver to your TV using the same cable your receiver is currently using to connect to your TV, be it Composite, S-Video, or Component. Just switch your TV to that input when you need to set-up something on the receiver.
Posted on Jul 09, 2008
honeybaked74
SOURCE: the HDMI "input" ports damage output ports of connecting devices
i know this sounds stupid, but have you "toggled" or "played" with the HDMI cables? are they the same manufacturer? HDMI channel connections are very fickle. If just one connection is not exactly correct, they go to a limp, no go status. Since they run at such a minimal voltage, i can't see them "blowing" the outputs on the devices.however....if your cable has a serial type output for video only, I would connect the hdmi convertor to it and see if it works.
Posted on Jan 10, 2009
taran_2005
  • 10515 Answers
SOURCE: No surround sound from my PS3 through the Onkyo 5100. Video OK
Unfortunately only the higher end Onkyo Reciever pass audio over HDMI for sound. 605,705,805,905 exc. Your reciever will carry Video over HDMI but you will need a digital optical cable for sound.
thanks.
Posted on Jan 24, 2009
SOURCE: Onkyo TX-SR606 getting no sound from HDMI sources
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Posted on Apr 05, 2009
System won't allow me to delete below entry HKEY_LOCAL_MACHINESYSTEMCurrentControlSetControlClass{4D36E965-E325-11CE-BFC1-08002BE10318 in order to get pioneer dvd drive going again what do I do now thanks
Disconnect the drive from the PC or disable it through BIOS, then boot, remove the entry and, if you disabled the drive reboot the PC and enable it through BIOS, if you disconnected it then turn off PC, reconnect it and Boot.
Nov 18, 2009 | Pioneer DVD Burners DVR-K13 Burner
My pioneer dvr-k17b ata device failed instalation error code 39 could not load driver
1) uninstall your dvr from device manager
2) write REGEDIT at RUN
3) look for UPPERFILTER using search in the edit menu. After you have found it, delete this registry
4) repeat the same for LOWERFILTER
5) Go to the device manager, scan for hardware changes. Win Vista will now successfully install your DVR
Dec 26, 2008 | Pioneer DVR-212DBK 18X SATA DOUBLE LAYER...
Pioneeer DVDRW-K17B ATA Device
hello
i'm having HP PAVILLION DV6000 and OS is VISTA HOME PREMIUM .My problem is that my system does'nt show any dvd drive in MY COMPUTER. I am having PIONEER DVDRW DVR-K17B ATA Device .device manager show a yellow icon and tells that it needs driver. It was working properly before.
thank u in advance
Oct 30, 2008 | Pioneer DVR-107D DVD±RW Burner
Audio Problem on a Pionneer DVR-810H Recorder
Thinking the problem might be the cable box..I bypassed the Tivo and hooked the cable box direct...there was audio on ch. 3 ....reconnected the Tivo and the audio was fine...strange?
Thank you.
Ken Havel
Greenville,WI
Oct 10, 2008 | Pioneer DVR-810H DVD Recorder
Pioneer dvd-rw dvr-k17a
I fixed it my self, redownloaded my Windows and repaired it.
Sep 08, 2008 | Pioneer DVR-107D DVD±RW Burner
I just installed a Pioneer DVR-115DBK cd/dvd writer (burner). My computer recognizes it, it says it's working properly, but the little green light on the front of the burner keeps flashing. Whenever I...
disconnect the dvd rw and again reconnect the cables then try once again and check the device is in master mode or slave.if again not solved then Contact the dealer from where you purchase dvd writer.
Jun 25, 2008 | Pioneer Computers & Internet
Pioneer dvd-rw dvr-k17 ata device
no issue shut down the laptop reset the dvd i mean reconnect it and restart it will automaticaly pick up and if not then thee is a prob wd win they might be corrupted
May 20, 2008 | Computers & Internet
77 people viewed this question
 Grubhead
Grubhead
