Question about Garden
Fuel line replacement for Poulan Pro 25cc High output engine
The fuel line on our Poulan Pro 25 cc high output engine pole saw has deteriorated and come apart. How so we go about replacing the hose? Is there a diagram for this part?
  • 3 Answers
SOURCE: fuel lines
Line into tank isn't easy to pass. I made small hole in line near bottom, tied 30 pound fishing line to it (with knot inside of tube lumen), passed line through opening from above, and with fishing line pressure pulling gas line in, I squeezed tip of gas line entering tank from above with needle nose pliers until the line went into tank. Then i pulled excess through until i could trim tip (with knot) through gas tank opening, and then reversed line pull back into tank. Trim other end to fit onto primer exit port.
Posted on May 04, 2009
dontbother10
  • 2220 Answers
SOURCE: installing fuel lines for, poulan 2150 16''
Find the model of your saw and open the IPL and handle assembly drawing here:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
This is as good as fuel routing gets!!! If this isn't sufficient Find your nearest Poulan repair facility or try your friendly neighborhood chainsaw seller/mechanic. Resubmitting this question won't get any better answer. HTH
Lou
Posted on Sep 14, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Poulan Pro pole saw model sm446e. For
Without seeing the saw and pole we cannot answer your question.
Posted on Sep 23, 2009
dontbother10
  • 2220 Answers
SOURCE: fuel lines have rotted off. need to replace then
Mr Tittle;
It isn't good but it's all there is.
What little fuel system system detail there is can be found here:
Poulan.com
If it is a 2375 WildThing find 2375LE Gas Saw Type ?. The last digit of your serial number should be a -1 or -2, the type.
Fuel Line Replacement by SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
  • The filtered hose from the fuel tank connects directly to the carburetor input connection.
  • If the saw is equipped with a primer, the output line from the carburetor connects to the suction side of the primer bulb (once the bulb is collapsed it draws fuel from the tank through the carburetor to refill the bulb as the bulb reinflates).
  • The pressure side of the primer returns any excess fuel to the tank as it is depressed.
HTH
Lou
Posted on Oct 24, 2009
dontbother10
  • 2220 Answers
SOURCE: Poulan PP446T Pole Saw. Will run only if choke is
It is running lean. There is an air leak somewhere allowing to much air into the cylinder or crankcase. Continuing to operate lean may cause failure. If fuel delivery lines have no pin holes or cracks probably time for some professional help (pressure tests). Remove clean and reinstall the muffler (carbon fouling can also cause this). If the saw cannot exhale, it cannot inhale. HTH
Lou
Posted on Jan 23, 2010
The trimmer starts fine, but as soon as touching the trigger, it dies. Even if you wait, it runs fine until yu touch the trigger and it dies, every time.
Most symptoms and problems such as you report, are commonly resolved by the following, check, clean, or replace:
  • fuel filter - located in the gas tank
  • Spark plug
  • Spark Arrestor- screen at muffler. When clogged up with carbon build up, engine no longer operates well
  • Carburetor- may need a new rebuild kit
And watch this...
And this one..
Oct 09, 2014 | Poulan Garden
I NEED HELP WITH FUEL LINE ROUTING FOR POULAN 445 PRO.
I HAVE A POULAN PRO 445 POLE SAW AND NEED AN FUEL FILTER AND HOSES . IS THERE ANY WAY I CAN SEE PARTS # FOR THESE ITEMS AND ALSO A PIC OF PUTTING IT TOGETHER ? Thanks , Omar
Jul 13, 2011 | McCulloch 10" Electric Pole / Chain Saw
25 cc poulan pro gas blower idle screw setting. What is the correct settin for this blower?
If the carburetor is a Zama (and it probably is), then the manufacturer of the carb states these settings:
http://www.zamacarb.com/tipspage.html
Apr 04, 2011 | Poulan Pro 25CC 2Cycle Gas Blower
Gas/oil ratio for fuel in a poulan pro 46cc engine
The standard mix for most chain saws is 40:1 that's about 3-1/4 oz per gallon.
Jun 12, 2010 | Poulan Pro Chain Saw 46cc 20"
My Poulan Pro 32 cc high output engine (with either the small chain saw or weed eater attachment) is relatively easy to start but after a few minutes it stalls out. Restarts easy but continues to stall out...
hey its broblably a clogged up carburetor which is not letting your engine **** up gas from the main fuel line. my advice is to clean all the filters and passage ways inside the carburetor. Also you may have to replace the diaphram in the carb a diaphram is a thin piece of material that basically pumps the gas into the engine also with the help of the compresiion of the engine sucking it in
Mar 07, 2010 | Poulan Garden
I had to replace all my gas line on my Poulan 446t i need someone that knows how they hookup
Typical fuel system and a couple of tips. Leave the carburetor connections a little long so they can be swapped if need be. I think the upper most connection goes to the bleeder.
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
I think this is an IPL for your pole saw: (there are others, this may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP446T-Gas-Pole-Pruner/75.PP446T-Gas-Pole-Pruner.1.59.1.html
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
All Models:
Poulan.com
The dash number of your serial number is the type (true for chainsaw, my first pole saw. If uncertain try to contact them please.). HTH
Lou
Please reply back (below) with the final configuration. Help me provide better guidance to the next guy please.
Feb 09, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I need info on a Poulan Pro 445 fuel line routing
I'm so confused. This is reported as a Poulan and McCulloch pole saw, which one? Is it a pole saw? That is the only 445 Poulan I can find. It is reported as an electric but has a fuel routing problem.
If it is a Poulan Pro gas pole saw it is here: PP445 Gas Pole Pruner
The fuel system routing is terrible, but it is all there is.
Fuel Routing follows:
Tank to carburetor (hose in tank with filter on free end)
Carburetor to primer (primer draws fuel from the tank through the carb)
Primer to fuel tank (returns any excess fuel to tank when pushed) HTH
Lou
Oct 11, 2009 | McCulloch 10" Electric Pole / Chain Saw
Garden Logo
229 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
