Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Old magnavox no picture only snow - Philips Magnavox 9P6034C 60" Rear Projection Television
    New Friend:
What was the solution to the snowy picture?
Posted on Oct 08, 2013
How can I get a picture and sound on my Magnavox RX4030 WA01 TV?
Just make an auto tune finction after connecting the antenna, after select the input selection to TV.
Apr 30, 2012 | Televison & Video
My magnavox hdtv makes snow noise
Hello
Check its antenna connection for firmness. It should be tight to an extent. If it got loose, the snow [video noise] will be there on picture. If it tight and still there is snow, check for any connection break at the antenna mast over the roof. If all are found OK, and still the problem perists, the tuner to your TV is defective and should be replaced.
Feb 10, 2012 | Televison & Video
Old Magnavox 1994, model #27tsc6 2102 serial # 38834731 I have an old magnavox television that turns on without any picture. When you turn this television on the green power light turns...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 15, 2017 | Magnavox Televison & Video
42'' Magnavox 42MF231D/17 with picture/sound problem
Hi my name is Roety,
I can help you with your issue ,
Sounds like a bad SSB small signal board
login as a guest and check price and availability at
encompass.com
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Oct 31, 2009 | Philips Magnavox 42MF521D/37 Television
VHS picture won't work but DVD is fine
VHS part of your machine got video head dirty / clogged. use good quality VHS head cleaning cassette to see picture again.
Sep 30, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips magnavox 9P6040C104
i just found out why, turn on ur tv and remove back look directly into 3 lenses, if the picture is not nice and clear or looks snowy in all 3 u will not get good color or brightness. I removed my blue tube assembly and took it apart WHILE OUT OF TV. there is cooling fluid between lense and tube, this fluid over time will build a film on the face of the tube and get thick enough to block the tube from projecting picture. (MARK EDGES IT GOES BACK TO GETHERE THE SAME WAY IT CAME APART).Find some new fluid then carefully dissasemble and clean interior of lense, housing and tube thouroughly. Reassemble and fill with new fluid. Do not use old fluid it will be cloudy and snow globe effect. Only do 1 tube at a time this will allow u to realign cross manually as close as possible before u perform convergence. Leave the green for last that is the center and the red and blue are moved to match green. Also be sure to clean mirror and back of screen. Pete
Aug 31, 2008 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox(model 9P6034C102 )
This is any easy fix. Goto www.magnavoxhelp.com to get a repair kit. Its a common problem on some of the older Magnavox projection TV sets.
Jul 30, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox DVD.VCR player.
The remote code for magnavox dvd/vcr dual player is, 21593. It work for me..
Jan 21, 2008 | Philips Magnavox DVD/VCR Dual Player
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
