Question about Dryers
It seems that my heat is still on how do I turn it off for sure I have the 41110 model thermostat
    Problem Solver:
  • 13 Answers
I think its the motor switch check it first
Posted on Jul 24, 2013
Check the thermostat On thin twin model LTD5243DQO
It seems most likely heating element is defective
Feb 26, 2015 | Dryers
Model TWEO36C140A1 blower will come on if I throw the breaker switch...but thermostat doesn't seem to be in sync. Fan will run in "on" position and once blower is running, in auto. ...
If no relay I'm assuming this is an x13 motor. Try swapping speed taps 4 and 5. It's possible the winding is over heating. Tough one to diagnose without being there. With power off take pic of tstat wiring and remove all wires. Be sure to spread wires apart to prevent blowing fuse. Turn power back on. Red and white together should bring on heat and fan. Red green and yellow should bring on fan and compressor. Try this several times each way making sure the blower comes to a complete stop every time. If everything seems to work by bypassing tstat you likely have a bad stat. Provided swapping your speed taps was unsuccessful. Good Luck!!
May 06, 2017 | Heating & Cooling
I have a Trane heat pump, model #TWP060C300A and a Trane air handler, model #TWE065E130A. Heat pump is 5.0 ton, split system. Air handler has a variable speed motor and a 20Kw 3-phase auxiliary heat strip....
Honeywell Chronotherm thermostats have always had a great reputation for longevity and reliability. They are also much more user-friendly than the other types of programmable thermostats out there. Make sure you get one that states 2-stage heat, heat pump. T8611G will offer that for you. There are many out there that claim to be suitable for heat pumps; however, they do not have the ability to utilize your auxiliary heat strips (2nd stage of heat).
Before you attempt to replace, be sure to write the wire colors and their corresponding terminal marking on a sheet of paper........of your old thermostat. This is very important to make it easier to hook up the new thermostat. Also, before you disconnect the wires, be sure to shut off the circuit breaker to your air handling unit. You can ensure you have the right one by putting the fan switch in "ON". When you turn off the right breaker, the fan will stop running. :-)
I hope you find this information to be very helpful to you. Please don't forget to leave a rating.
May 09, 2010 | Honeywell Programmable Thermostat Heater
My heater doesn't work properly. Honewell Thermostat
Does the temp satisfy on the tstat or does the unit turn off but the tstat says it should still be heating?
Jul 01, 2017 | Honeywell Programmable Thermostat Heater
Honey friedrich replaced with a honeywell RCT 8100
on some of the older models you must go into the installers program to make sure it is set for heating and cooling. also possibly gas or electric heat. and fan on during call for electric heat. these are all sellections in the installers program and usually they have one or more options for each sellection. see the installers guide for your tstat.
Nov 23, 2009 | Honeywell Electronic Programmable...
Heater running continuously
Sounds like you have a problem with your heat pump. Your aux heat is a electric coil. how old is the unit when was the last time it was serviced? How cold is it out side?
Jan 15, 2009 | Honeywell Programmable Thermostat Heater
Open Questions:
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
