Sony T.V will not come on
I have a Sony T.v modell # KF60WE610. had T.V on while when the temp was hot outside. T.V went to a blinking green like with know pictuer but sond. Turn T.V off now I just get 6 blinking red lights.
  • 4 Answers
It sounds like you have a problem with your power supply.
Posted on Jul 24, 2013
SOURCE: Sony LCD television will not power on.
I get 5 blinking red lights for about a minute or so before it powers back down. The Sony TV has a specific light that i presume is supposed to light up when the bulb is out. I'm unsure if this is what it is.
no picture, no sound. tries to boot with green light blinking a few times. then goes to red blinking light, six in all, then waits a few moments, then another 6 blinking red light.
Bulb was already replaced several months ago but we do have the TV on for long periods of time.
Posted on Nov 26, 2008
SOURCE: kdf-60xbr950 - red light blinks 3 times for a minute and tv turns off
same problem as others 3 blinking green lights then orangey colors then 3 red blinking lights afterwards shuts down fan runs for about 2 mins solution check your door cover for warpage or deformed just a bit under set screw there is a push in switch try and push it in with q tip while holding turn on tv if it works then that door is deformed and defective change it
thanks for solving my issue tv works again very helpfull thanks
Posted on Jan 07, 2009
rockitman187
  • 2559 Answers
SOURCE: kdf-60xs955 red continous blinking lamp light
It's in standby mode.
Do a reset and see what happens
While holding down the reset button on the remote
Press the power button on the tv
(The tv will turn itself off the back on)
Now release the reset button
It sounds like the lamp needs replaced.
Please rate this a fixya
Posted on Jan 30, 2009
coolfixya
  • 82 Answers
SOURCE: red light 6 times blinking on sony model kdf60xs955
Six blinks=no horizontal (H STOP), no raster, goes to the blinking self diagnosis function immediately. check the horizontal circuits, not sure what the repair will cost you.
you can try this to reset the tv to manufacturer defaults, but there is no guarantee it will clear the problem. to do this, with the tv in standby, quickly press "display", channel "5", volume "+", then power. once the service menu is up, press 8 and then enter, and lastly the power button.
this should reset to factory defaults. once again, no guarantee this will help, but the no horizontal (h-stop) diagnosis should give you something to ask the repair techs about over the phone to get a rough estimate of repair cost.
Posted on Mar 01, 2009
  • 380 Answers
SOURCE: I have Sony tv model KDF-42WE655 which stopped
Its not the green light that you should be count but the red. How many times is it blinking? Here is a quick update of the errors that are most common.
3x - Lamp switch not engaged
4x - Fans issue
5x - Lamp
6x - Thermal fuse
Posted on Dec 15, 2009
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
Screen black
Its a fail code of sorts which might mean a fuse is blown or other problems.
Jan 23, 2010 | Sony Grand WEGA KF60WE610 60" Rear...
Does the lamp needs programing after replacement.
No programming is required - the set should come on if the lamp is good and installed correctly. You may have another problem (ballast) or a defective lamp. Was the old lamp visibly bad?
Sep 18, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Sony Grand Vega green light blinks on and then blinks red
Please intimate exact model of your Sony TV and also mention how many times red light blinks as there would be pause of 3 seconds in blinks so count pause to pause and let me know to find out problem.
How old is this TV and did you replaced its lamp?
Thanks.
Sep 14, 2009 | Sony Grand WEGA KF60WE610 60" Rear...
Tv blinks and turns off
You likely have an open thermal fuse. There is a whole procedure for replacing the thermal fuse and some adjustments that should be done when you replace it. If you feel like you are reasoonably technical and can handle the job, I'll try and walk you through it. If not, your best bet is to find a qualified Sony tech in your area. If you contact Sony at 800-222-SONY and they can recommend one in your area
Nov 14, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Electro Med Services...
