Try this:
If you forget your password
If you forget your password, you can clear it using the
following steps:
1. Press SETUP to display the Setup menu.
2. Input the 6-digit number "210499" and press
ENTER/OK. The password is cleared.
OR
1. Press DVD on the remote control.
2. Press SETUP.
The Setup menu appears.
3. Use v / V to select the desired option then press B
to move to the second level.
LOCK (Parental Control)
Rating
Blocks playback of rated DVDs based on their content.
Not all discs are rated.
1. Select "Rating" on the LOCK menu then press B.
2. To access the LOCK options, you must input the
password you have created. If you have not yet
entered password, you are prompted to do so.
Input a password and press ENTER/OK. Enter it
again and press ENTER/OK to verify. If you make a
mistake before pressing ENTER/OK, press CLEAR.
3. Select a rating from 1 to 8 using the v / V buttons.
Rating 1-8: Rating one (1) has the most restrictions
and rating eight (8) is the least restrictive.
Unlock: If you select unlock, parental control is not
active and the disc plays in full.
4. Press ENTER/OK to confirm your rating selection,
then press SETUP to exit the menu
Unlock
New
DG
AU
Move
Select
this sounds like a typical security question for a web site usually used for when you forget your password
it is asking for the name of your oldest child so when you forget your password and ask to be reminded of your password they can ask a question you should only know the answer for.
If you did forget the code to release V-chip to this TV, there is no other way than contact its authorised service center. If you want to unlock the child-lock to certain channels:
1 Press or to display the password entering mode. Press MENU, then press or to display the (LOCKS) menu. 2 Use the number buttons (0-9) to enter your password, then press ENTER. The LOCKS menu appears. 3 Press or to highlight CH LOCK and press or to display the CH LOCK menu. 4 Press or to highlight CLEAR and clear all channels from the list of locked channels. Press ENTER. 5 6 Press EXIT to return to normal viewing.
default code is 0000.
If you forget your password you can reset it.
Simultaneously press the VOL+ on the remote and
the CH+ button on the front of the TV. The display
the CH+ button on the front of the TV. The display to reset, simultaneously press the vol+ button on the REMOTE, while pressing the chan+ button on the front of the TV. Reset Pass Display will appear. Thanks if this helps, please give a good rating
If the front buttons don't work, it is usually caused by the TV being set in CHILD LOCK..
Try this;
so got into menu and turn child lock to OFF.If you dont have a remote,then unplug at electrical outlet for 5 hours then plug back in and turn back on; box will then reset...
Hope this may help you;
Regards,
VOTIT
DON'T FORGET TO RATE
