Question about Home
Kenmore elite washer little amount of water fills washer
    New Friend:
If I am understanding the question, you have low water pressure/volumn when washer is filling? If so, unplug washer. Shut off water at valves. Remove water lines from rear water inlets on washer. Clean debris from screen filters in water inlets or in supply lines. Flush supply lines into bucket. Reconnect water, power, and test.
Posted on Jul 25, 2013
My kenmore elite HE3 fills up with water when it is not running.
Hi... if your Washer is filling and its not running... you need a new water valve
Mar 30, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore elite smartwash quiet pak 9 he4t the washer starts filing water when the washer is turned off.
This is symptomatic of a malfunctioning water control valve- not closing fully- the hot water one, if the washer is hot and cold fill, and the cold one if it is just cold fill!
Sorry but it needs replacing and a service call ;-0(
Good luck,
John C
Mar 19, 2011 | Kenmore Elite 45986 Front Load Washer
My Elite washer fills up with water during the wash cycle even with a minimum amount of clothes then cancels and drains and gives me an 'overload' code????????
More then likely the soleniod valve has dirt stuck undr the seat and it cannot close....
When a washer just keeps on filling with water it is
Kind of the opposite of this problem that I wrote about in these tips...
Washing Machine Problems No Water
http://www.fixya.com/support/r3880845-washing_machine_problems_no_water
Washing Machine Fix Washing Machine No Water
http://www.fixya.com/support/r3880533-washing_machine_fix_washing_machine_no
heatman101
Aug 19, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My Kenmore Elite washer will not fill.
yes there is a water inlet valve . it is the blue valve your water hoses connect to on the rear of the washer, they get sediment built up inside and get stuck , cost $26.50 from Repairclinic.com just go to site .find parts,then type in your model#
Jan 21, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Hi, I'm house sitting for a friend and he has a kenmore elite washing machine. Which slot do i put the liquid clothing detergent in? softener? or
The LEFT slot is for detergent. Do not overfill, or you may experience a "SUDS" error. It is recommended that only HE detergent is used. The RIGHT front slot is where you put the fabric softener. Again, only fill to the fill line.
These washers are engineered to use very little water, so you only need a little detergent. If you have questions, please let me know. I hope this helps you.
Sep 03, 2009 | Kenmore Elite 45986 Front Load Washer
I have a kenmore elite 3t that fills with water when not in use
sounds like you have a bad fill valve it should only let water into the machine when the fill valve is energized. If water is coming in when unit is not in use change the valve.
Dec 17, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite Calypso washer won't fill with water!
i assume that the warer is turn on at the warer valves if so then do you have voltage at the water valve if not then water pressure switch could be bad or main control board could be bad
Apr 24, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore Elite HE3 washer keeps filling with water
The inlet valve will need to be replaced. Its a fairly simple procedure and a pretty inexpensive part.
Nov 15, 2007 | Kenmore Elite 45986 Front Load Washer
set the washer to fill. open the lid and depress the lid switch. might be in the rear of the cover or on the side. watch to see where the water level comes to. once the tub is filled, the water height switch operates the timer motor for the different cycles.
Sep 10, 2007 | Kenmore Elite 45986 Front Load Washer
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
