Question about Cell Phones
My iphone 4 just ring once and stop - Cell Phones
I purchased a phone from someone and i dont know there icloud or itunes pass word . i need to swap all info from phone to other phone
There is software on the market available to do a complete back-up without the itunes/icloud password, however that is the recomended of doing it as you will recieve support from Apple if extremely nessasary, but i would only ring Apple if all else fails ($25 support charge) for help with resetting lost passwords or forgoten Apple ID then click this link https://iforgot.apple.com
Feb 25, 2015 | Apple iPhone4 4G iPhone 4
My iphone 4 is sending incoming calls direct to voice mail & not giving the callerto speak to me. how do i reset this?
I have had this issue with the iPhone 4 and 5. It all comes down to the carrier. I unfortunately have At&t and for that note the cell phone coverage is bad at my house. The iPhone 4 and 5 have a few glitches, in the sense that the antenna is only on top and side. The New iPhone 5c and 5s have three antennas and the call are almost never dropped. If they are it is due to At&t service. Call At&t or your service provider and ask them to rest the service on there end. They will reset your phone to their systems. Usually this works. If not ask them about the closets antenna and if it is down or being worked on.
That happened to be the case last year for me at my home. Once they fixed the antenna I got all my calls and never missed ever since. I hope this helps. Best of luck.
Sep 06, 2014 | Apple iPhone 4 Black Smartphone
I upgraded my iPhone 4 to ios 7 and it stopped ringing out. It only vibrates.
did you turn off the sound? it's a switch on the side of the iphone
Oct 03, 2013 | Apple iPhone Cell Phones
My iPhone stop ringing. It only vibrares. Also the keyboard does not sounds. However I can listen to the radio . What can I do? Thanks a lot. Dolores
Chances are, you turned ON the Silent switch on the side of the iPhone. You'll know that it's turned ON if you see a little red dot (for iPhone 3G & 3GS) or a red line (for iPhone 4). To locate it, refer to the image below: 16aae05.jpg
CLICK HERE if you don't see the image.
For more iPhone tips and tricks, CLICK HERE.
Did this helped you?
Jun 03, 2011 | Apple iPhone 3G
My iphone 3G has stopped ringing when a call is made. How do I reactivate the ringing?
maybe try looking on the side of the phone, there is a little silver button that puts it on silent ringing for meetings etc
Apr 09, 2011 | Apple iPhone 3G
How do I download a ringtone from my pc to my iphone 4
go to myxer.com and find a song you want then there should be a button that says download for iphone. You will then download the file. Once downloaded you click and drag that file onto iTunes on the top left where is says music, movies, ect. it will then make a ring tone category you can now sync you phone and the ring tone should me there :)
Jan 03, 2011 | Dell Computers & Internet
My iphone doesn't ring or vibrate, but does with earplugs on.
I would try a system restore, plug your iPhone into iTunes and click restore, it will delete everything but once its done it will restore it to when your last sync was.
Mar 29, 2010 | Apple iPhone Smartphone
Iphone 3g will not ring only vibrate. The Apple store said there was moisture, but it never was close to water. Tried to reset, and all the setting fixes. Nothing works. Apple said I would have to buy...
try going into the settings on your iphone. Then go to sounds. At the top of that page, it says vibrate and under it it says ring. Make sure that the slider next to the ring tap is on not off. I hope this helps!
Nov 29, 2009 | Apple iPhone Smartphone
Will not ring only vibrate
when you set the ringer to ring only will it ring?
on the side of your iphone there is a switch above the volume switch that is a ringer/vibrate switch
switch it and test
Jun 05, 2009 | Apple iPhone Smartphone
Cell Phones Logo
11 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
