Question about Amana D530M Dehumidifier
Owners manual Doesn't drain
What diameter tubing is used with the Delonghi DE 500P pump
George, regular garden hose is what is generally used for continual drainage. Just don't exceed the maximum length of hose, that is listed in your Owners Manual.And, despite what they say about being able to pump water up thru abasement window, it really doesn't work that well. Unless the unit is right below the window,
Hope this helps you and thanks for choosing FixYa.
Sep 04, 2011 | DeLonghi DE500P Dehumidifier
How to set the dehumidityfier to drain through a hose than the bucket
As you're facing the rear of the unit, you will see a drain hose connection with a drain cap in place, don near floor level. Using a garden hose, no longer than 5 feet, remove the drain cap and save for future uses. Connect the garden hose section to the drain hose connection. Roll the dehumidifier to within 5 feet of a floor drain and place the hose at the inner edge of the floor drain. Be use the hose is sloped down and without bends or kinks. Plug the dehumidifier in, turn it ON and set the humidity extraction level at 35 - 40%. Monitor the hose to make sure its draining after 15 minutes of operation.
Keep in mind, the drain hose relies entirely on gravity to drain. It will not drain, if the hose is not sloped it's entire length down from the unit.
To assist you further, I have included a link to your Owner's Manual, that you can download and print for future reference. http://www.danby.com/cms/uploads/products/en_manual/DDR586R%20EFOM.pdf
I hope this helped you and thanks for choosing FixYa.
Aug 01, 2011 | Danby DDR586R Dehumidifier
How to attach drainage hose to drain automatically
Because your model dehumidifier has an unusual continuous drain hook up, as compared to other brands, I have included a link to the Owner's Manual for your model. You will find the information on page 3. You can downlaod and print the, manual for future reference.
http://www.appliancefactoryparts.com/content/pdfs/123922.pdf
One thing the Owner's Manual fails to mention is the length of the garden hose that can be attached to the unit. It should not exceed 5 feet. As drainage relies entirely on gravity to drain.
I hope this has helped you. Please let e know. Thanks.
Jul 20, 2011 | Maytag M7DH45B2A Dehumidifier
How do I hook this up to drain through a hose
The following link is to the Owner's Manual for your unit. Once the link opens, look to the right of the page and you will see Dehumidifiers Manual English. Click on that and the manual will download. Yours is a unique setup, so it's best you see not only the instructions, but also the pictures. Look at the section entitled Disposing of Collected Water, Page 12.
http://www.lg.com/us/appliances/dehumidifiers/LG-LD450EAL.jsp
Hope this helps you. Please let me know. Thanks.
Jul 06, 2011 | LG LHD459EL Dehumidifier
Condensate pump buzzes but does not remove water. have blown out discharge hose and clean check valve with changing symptons. Should I give up and put it on a box and buy a separate condensate pump or...
Edwin, according to the Owner's Manual, when this happens the drain hose is not connected properly. Turn the unit OFF and unplug it, then disconnect the hose and reconnect it. Plug the unit back in, Turn the Master ON/OFF Switch to ON and press the pump button. If the hose is connected properly, the pump should tunr on and pump the water out.
To help you further, I have included a link to the Owner's Manual for a Delonghi model like yours. Once you go to that page, click on the Acrobat Reader Icon and download the Owner's Manual. You may print it is you like.
http://www.delonghi.com/us_en/products/dd50p/
Hope this helped you. Please let me know. Thanks.
Jun 23, 2011 | DeLonghi DE500P Dehumidifier
E3 code...what to do? on dehumidifier
Unfortunately, Delongi doesn't list an Owner's/Operational Manual for your model dehumidifier. However, you can contact their Customer Support Dept at 800-322-3848. They can provide you with the Error Code solution, as well as email you an Owners Manual. Be sure you have the correct model number for your unit, before calling.
Jun 01, 2011 | DeLonghi DH40P Dehumidifier
Need an Operation Manual for Delonghi DN125 Dehumidifier
Unfortunately, Delongi doesn't list an Owner's/Operational Manual for your model dehumidifier. However, you can contact their Customer Support Dept at 800-322-3848. They can email you an Owners Manual. Be sure you have the correct model number for your unit, before calling.
Jun 01, 2011 | DeLonghi DN 125 Dehumidifier
Water draining onto floor not collecting in bucket. What could cause this?
First of all, here is the main ONLINE SUPPORT page for your model:
http://www.ajmadison.com/cgi-bin/ajmadison/AD35USS.html
And here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.ajmadison.com/ajmadison/itemdocs/1188927.pdf
To view the Support Page or the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents.
You can download this free at WWW.ADOBE.COM if necessary.
Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
Well, the first obvious thing to check is whether your collection bucket has a hole or a crack in it which is allowing the condensate to leak out onto the floor.
The other possibility is that you are missing your DRAIN CONNECTOR COVER which blocks up the drain hose connection on the side of the unit. This hose connection is used when you want to run the unit continuously with a drain hose attached and don't want to have to empty the bucket all the time. There shoud be a small screw in plug to cover this drain connector when not in use. See page 7 of the manual for detailed instructions and illustrations.
If your collection bucket is just overfilling and spilling onto the floor and the unit just keeps on running anyway, then you have a problem with the float level shut off switch which needs adjusting or replacement.
Please comment back here to this page if you have any details to add, have any questions, have difficulty accessing the links, or just require further general assistance and I will respond as soon as I see it.
I hope that was helpful to you, good luck.
If you choose to rate this solution using the Thumbs Up scale provided, I thank you very much for your time and consideration.
Joe.
May 24, 2011 | Whirlpool AD35USS Dehumidifier
Dehumidifier wont turn on or reset. code comes up as F2 and wont reset. Cleaned off filter. no help. any ideas you have would be appreciated.Just bought it last year. we have the hose connected to a...
To figure out what Code F2 is, I took a look at the Owners Manual for the Model # AD70USS, Strangely, the Owners Manual doesn't list an F2 Code or any codes for that matter. Because that model number humidifier, does not have an LED screen.
Never the less, to reset your unit using an alternate method. Turn the Master ON/OFF Switch to OFF and unplug the unit from the wall outlet. Wait 12 - 15 minutes before plugging it back in. Then turn the Master ON/OFF Switch to ON and the dehumidifier should have reset itself. If it doesn't check the positioning of the water bucket, to make sure it's contacting the safety switch. Eventhough, you're using a drain home, it's still important.
Hope this helps you solve the problem.
May 08, 2011 | Whirlpool AD70USS Dehumidifier
Amana D530M Dehumidifier Logo
Top Amana Dehumidifiers Experts
Gil Shultz
Tom Chichester
Are you an Amana Dehumidifier Expert? Answer questions, earn points and help others
