Question about Dell 1320c Laser Printer
B&W Printing w/o Yellow Toner
Can I print a black & white document if the yellow toner cartridge is empty?
    New Friend:
Yes, on most printers. just have to set preference to black and white in printer control panel
Posted on Jul 22, 2013
Corysf62
  • 188 Answers
SOURCE: Yellow toner will not print
If you let the yellow toner get to the point where the toner cartridge was totally empty, there is one thing you can try which may help. From the "menu", select "maintenance", then go to "clean developer" and choose the yellow. The machine will then churn for a few minutes. What happens is there is a tube that moves the toner from the toner cartridge down to the developer unit ( which is behind the imaging drum). If the toner was allowed to totally run out, there is an area of the tube which may have little or no toner in it. Each time you print, there is a spring auger within the tube that draws the toner to the developer. By running the "clean Developer" it turns the auger and re primes the tube.
If this does not fix the issue, and you have replaced the imaging unit, then the yellow developer is defective and would need to be replaced. This involves quite a bit of work and is not considered user replaceable.
Posted on Oct 01, 2008
SOURCE: printing in grayscale
yes u can use it with black and white
Posted on Nov 01, 2008
Just_Bobz
  • 448 Answers
SOURCE: excess toner after ?overfilling cartridge w/ bulk toner
Did you refill the toner yourself or put a new one in or.......
Posted on Jan 01, 2009
  • 13 Answers
SOURCE: My yellow toner is empty but I would like to print
in the menu options on the printer screen the will be one that says "maintenance" in that menu there will be another that says "non-dell toner" set your printer in the non-dell toner mode. this will deactivate the toner level reading and allow you to print what ever you want.
Posted on Nov 24, 2009
  • 166 Answers
SOURCE: Black Toner is printing very light - more grey
take out toner drum and shake it. put back in. try again. also, try running a cleaner
Posted on Dec 01, 2009
I replaced the K cartridge and i get this caution. I-Unit End Replace K
If "[Color name] Toner Empty. Replace with a new toner cartridge." is displayed and printing stops, replace with a new toner cartridge.
([Color name] indicates one of the following: C or Cyan, M or Magenta, Y or Yellow, K or Black.)
Jan 10, 2017 | The Office Equipment & Supplies
Have a bizhub c550 printer and when printing a plain white document i get a yellow background, What could be the problem?
Sir/Mam, have you replaced the yellow image unit ? Not the yellow toner cartridge. There two seperate units. Also there are on each image unit blue/white nubs that you can pull out and push back in to clean interal image unit parts do that you do not have to pull the image units out just ensure that when done cleaning they are pushed all the way back in. Once the image units are not toner cartridge and there are four of them located below each toner cartridge .
Jan 08, 2015 | Konica Minolta Bizhub C550
Magneta Color (Toner) and when I print, the Magneta color does not print. Even on supplies status page, the yellow color section at the bottom is blank where the yellow color should be printed. How c
The Magenta or RED toner cartridge should be removed and double check that you have indeed removed the pull tab located on the side of the cartridge which will remove the sealing tape off the new toner cartridge.
The YELLOW toner cartridge on the other hand if it is not new then it is perhaps empty and needs to be replaced. Another option is to remove the YELLOW toner cartridge from the machine, Tap it and shake it side to side to loosen the toner that is in it, and replace it back into the machine, this will usually make it start to work again!
Good Luck!
Rich Lilja
Aug 31, 2014 | HP LaserJet 2840 Printer
I can't print in black and white though I have black toner
Hi, when the printer finished warming up. it will prompt Toner Empty - Stop, use the arrow key changed to continue and you can start printing. remember you must always do that whenever this msg appears.
Oct 09, 2013 | Samsung CLX-3175FN Color Laser All-in-One...
Just wondering: my printer's yellow and black toner are both empty and need replacing. Would this cause the printer to calibrate for minutes at a time? After calibrating, I tried printing a document with...
If your going to print in color may it be just red or blue. You really need all of the cartridges for it to work. Because for the printer to come up with those colors. It would need all three colors Cyan, Magenta and Yellow to come up with the any color, in your problem, Blue and Red.
Feb 04, 2011 | Dell 3100cn Laser Printer
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
Konika Minolta 2430 DL won't let me print
Look through the menus on the printer for a setting for "Low Toner" -- the choices of what to do are usually either "continue" or "stop" or something similar (my 2430DL has this option setting) -- set this option to "Continue".
My 15 year old HPs also have a similar setting. However, this will keep it printing when the black runs out, so you will need to check your print production run visually as you go along to make sure the quality is what you need
Jun 22, 2009 | Konica Minolta Magicolor 2530 DL Laser...
Printing in grayscale
Nov 01, 2008 | Dell 3010cn Laser Printer
Yellow toner empty
You will need to use the menu on the printer itself to change a setting Press "Menu Select" button to get the menu function Use the right arrow twice to select "Engine", then press the down arrow to the "Replace Toner" menu Press the right arrow for the "Toner Empty" menu Press the down arrow to get the Toner Empty settings Press the right arrow to change the Toner Empty setting to "Continue" Press the "Menu Select" button to confirm the setting. You should be able to print, you just won't have any yellow toner. When you get your toner cartridge, follow these instructions to reset the 'Toner Empty' setting to Stop so you will know when a toner is out.
Aug 23, 2007 | Konica Minolta magicolor 2430 DL Laser...
Dell 1320c Laser Printer Logo
66 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
