Question about Microwave Ovens
My son cooked a container with a wire on it. It burned the microwave how to fix it
    Top Expert:
  • Microwave Ovens Master
  • 12,223 Answers
I do not know what do you mean burned the microwave? It is completely damaged? If it is , you must to buy a new one, to due the leak of radiation, for healt prevention.
God bless you
Posted on Jul 23, 2013
2 Suggested Answers
  • 7 Answers
SOURCE: Microwave Model # JVM1650,51,JVM1660 The
Sounds like a fan motor is bad probly cheaper to get new one than fix
Posted on Jan 22, 2009
Food in microwave is burning on edge and cold in the center
you may find the old unit was lower watts so took longer & cooked/heated better all the way through. a way to fix this is lower temp settings or pause and stir the food to help heat it up more even.
Dec 29, 2013 | KitchenAid KHMS2040BSS Stainless Steel...
WHEN I USED MICROWAVE HAD BURNING SMELL & BLACK SOOT APPEARED. STILL HAVE POWER BUT DOESN'T COOK
Just had the same problem. It was an electrical short and the repairman said that it could have burned the kitchen wall and been a catastrophy. Get rid of it immediately!
Mar 02, 2013 | Microwave Ovens
MIcrowave emits an electrical smell while cooking. It still cooks, but has started emitting an odor recently when in use.
Is the smell ionized (the outside smell of a cold winter morning air) or more of an electronic component burning??? if it's more of an ionized smell it could be normal, (if the smell is strong) it could be a leaking high voltage cable (electric arching) bad insulator, if it's more of an electronic component burning smell, it could be a overheating component, in both cases you should have it checked by a professional technician...
Cheers!
Jun 25, 2011 | Sharp KB-6024MS Stainless Steel 1000 Watts...
My microwave is completely dead. I have checked the fuse in the plug and it is fine. Any suggestions?
What you are to do to solve the problem is to do a general troubleshooting on your oven below are instruction to follow.
The Microwave is a counter top model with a variety of preset cooking options, including timed cooking at a variety of power levels and sensor-cooking settings for popcorn, rice, beverages and single-serving reheating.
The sensor cooking and reheating features detect increasing humidity levels inside the microwave and automatically adjust cooking time for various types and amounts of food. This microwave also includes a turntable and an electronic control panel.
Instructions below are step by step solution for your oven
  1. Check to see if the microwave will start. If it will not start and the display panel is blank, you may have a power problem. Unplug the microwave and then plug it back in, making sure that all three prongs of the power cord are fully inserted into the wall outlet. If this doesn't work, check your home's fuse box. Reset the circuit breaker to restore if necessary.
  2. Ensure that the microwave door is fully closed. Press the Clear/Off button to cancel any previous cooking instructions. Re-enter your cooking program, including cooking time and food weight if necessary, and press Start.
  3. If "Err" appears on the microwave display, press the Clear/Off button and reenter your cooking program. The "Err" message will appear during the sensor-controlled programs (Popcorn, Rice, Beverage or Reheat) if the door is opened before steam is detected or if no steam was detected within the maximum amount of time allowed by the microwave. Be sure to leave the door closed during these programs, at least until time is shown counting down on the display panel.
  4. If your control panel will not work or if an "L" is displayed on the screen, press and hold the Clear/Off button for a full three seconds to unlock the control panel.
  5. If your sensor reheat program is resulting in under- or overcooked food, first try decreasing the amount of food in the microwave; the sensor programs are designed for single servings of food. The sensor reheat function works by measuring humidity inside the microwave--do not use a tightly-covered dish with this setting because no moisture will be able to escape and the food will overcook. Be sure that cooking containers are dry; moist containers will increase the humidity in the microwave and mislead the sensor, resulting in undercooked food.
  6. If your turntable is not rotating, first check to ensure that your food container is positioned so that it can freely rotate without hitting the microwave's interior walls; using a smaller food container can fix this problem. If the turntable still will not rotate, lift the turntable from its support and replace it carefully, ensuring that it rests evenly on its support.
Good luck.
Thank you and thanks for using fixya.
Nov 23, 2010 | Neff H5470N0GB Microwave Oven
Our dgs61st DeLonghi gas oven was installed on Wed. 3rd Nov. We gave it the recommended 'burn off', today we have put a chicken in and started cooking it on heat 140/155, after 20 minutes the oven is...
Could it perhaps be the chicken fat burning?
I take it you are using convection only and not microwave power because if you use microwave power and do not contain the fat in with the chicken, the fat will be heated to its flash point by the microwaves and smoke heavilly.
Hope this explained it for you.
Nov 07, 2010 | Microwave Ovens
TURNTABLE AND LIGHT NOT WORKING
It will cook entirely different ... you will want to turn the food occasionally to assure complete cooking.
You probably have a burned out lamp ... look inside for an access panel. If none, you will have to remove the cover. There are probably 8 to 10 screws and they may be Torx - Torx is a star shape, available at auto parts store of Sears (K-mart).
Once inside - DO NOT TOUCH THE SILVER CAN - LETHAL.
Find the lamp, check it out. If burned, get a replacement at your hardware or appliance store or maybe at a Big Box store.
I hope this helps you.
a
Sep 26, 2009 | Magic Chef MCD990W Microwave Oven
Sparks and Flames in my Kenmore 66561652100 Microwave
usually the only thing i'm aware of that will do that is if there is some kind of metal object in the microwave when you cook... even plates with thin painted metalic bands on the cause that affect.
remove the hook... place a container filled with water inside the microwave for about a minute to aid in cleaning... and examine the hook for any metal.
Mar 23, 2009 | Kenmore Microwave Ovens
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
