Question about Bosch Washing Machines
Class action lawsuit
I have a Bosch Nexxt 300. Smell bad and has mold, used bleach as recommended for cleaning tips by manufacturer. Purchased in 2007. Still molding and smells bad.
SOURCE: Mold & Smelly in Washer
Shepherd, Finkelman, Miller & Shah, LLC, is currently investigating defects and other problems in certain front-loading washing machines manufactured and/or sold by Whirlpool, Kenmore, and LG Electronics, including Kenmore Elite HE3 front load washers, Whirlpool Duet front load washers and LG Tromm, LG XL and other LG model front load washers, which result in the growth of mold/mildew in the machines and which can cause the staining of clothes and other problems.
On August 29, 2007, SFMS filed a Complaint against Sears Holding Corp. involving its Kenmore HE, HE2, HE3, HE4, HE5 and other front-loading automatic washers. If you own a front-loading washing machine that is manufactured by any of the above-mentioned companies and are experiencing the growth of mold/mildew in the machine, visit the following website: www.frontloadwasherclassaction.com
Posted on Dec 19, 2007
  • 1294 Answers
SOURCE: Mold smell
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too.
On some models the filter is located ‘inside’ the big hose from the bottom of the tub. This takes more time to clean.
Next run your washer with 2 cups of bleach, hot water. After it starts agitating stop the washer & let it remain for 2 hours. Then continue the wash.
Posted on Apr 08, 2009
  • 179 Answers
SOURCE: How best to remove mold from my Bosch Nexxt 300
any hard water remover hydocloric acid be careful dont breathe the vapors
Posted on Jun 08, 2009
dniro592006
  • 121 Answers
SOURCE: mold inside door gasket
Here is the solution! Keep Door open after use..
As you know wherever water may be mold will follow.. Easy solution!
Posted on Jun 09, 2009
  • 29 Answers
SOURCE: why do the machine have a mold and mildew smell
Because we are not told by the manufacturers that these machines have hidden drain plugs that need to be cleaned out when you starting getting the odor in order to stop the slow draining from burning up the pump.The drain should be behind an access panel that is held in place by several screws. Hope this helps
Posted on Jun 15, 2009
Mold in bosch nexxt 100 series- how to get rid of it?
yes bleach and a very hot wash. but remember mold grows in damp /wet so always leave door and soap draw open when machine is not in use this will dry out parts and cut down on mold growth ,
Sep 09, 2016 | Bosch Washing Machines
How do you get rid of mold smell in washing machine
Hello friend, thanks for your post!
I understand that you have a mold smell developing inside of your Frigidaire washer. I would normally recommend using a clean wash cycle with either one cup of bleach or one pouch of Tide Washing Machine Cleaner. If you do not have a clean wash cycle on your washer you could also use hot water and a regular cycle with a cup of bleach to clean out your washer.
You should also check over your gasket to assure there is no mold buildup, if you do locate mold inside of your gasket you can use bleach to help get rid of any residue. I hope this information is helpful. -Matt
Sep 25, 2014 | Frigidaire Washing Machines
How do you clean it. I think you run it with clorox, is that correct?
Front loaders are known for building up mold and the smell.
It's caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It's caused by using fabric softener. Dilute it 50/50 with water.
It's caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Pull the rubber door seal back and clean the mold off .
Affresh is recommended by some manufacturers. You run it through a wash cycle with it.
The bleach won't hurt anything. It will kill bacteria etc but it doesn't have any cleaning action.
Mar 09, 2011 | Maytag EPIC MFW9700S Front Load Washer
Door gasket has mildewed and need to remove it for cleaning.
This video will show you how to change a door seal on this Bosch front loader washing machine
May 14, 2010 | Bosch Nexxt 300 Series WFMC2201UC
The rubber seal at the front of the machine has gone mouldy. I have cleaned it before with bleach but the mould comes back all the time
It’s caused by using liquid detergent which is made from animal fat. Use powder. And use the minimum amount.
It’s caused by using fabric softener. Dilute it 50/50 with water.
It’s caused by the water remaining in the tub between washes. Leave the door open to allow it to dry. .
Oct 21, 2009 | Bosch Nexxt 700 Series WFMC6401UC Front...
Mold inside door gasket
Jun 09, 2009 | Bosch Nexxt Premium WFMC6400UC Front Load...
How best to remove mold from my Bosch Nexxt 300 washer
Jun 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Moldy smell in front load kenmore washer
Run an empty load with bleach and detergent and/or ammonia on hot.
Dec 21, 2008 | Washing Machines
Mold smell
Aug 23, 2008 | Bosch WFMC2100UC Nexxt Essence Washer
Nothing will get rid of black mold
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and move out the bad smell. Good luck!
Aug 21, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
43 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
