Question about Garden
I Have my Granfathers 1863 mid 90s Cub Cadet Lawn Tractor. It starts right up and runs great, however when colling down and shutting it off it spits and sputters 10 to 20 seconds. Then if u try to restart in a short time it will wind and finally will start but again it will spit and sputter slowly starting to smooth out and run great again. Can you help w any advice for me? Thank you Robert A.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 2,069 Answers
Check the gap on the Points
Posted on Jul 24, 2013
5 Suggested Answers
SOURCE: Cub cadet RZT 42 shuts down after about 30 min of mowing.
Check your magneto. I have had them cease to function whenever they would get hot. When cooled down, they would work.
Posted on Jul 26, 2010
  • 640 Answers
SOURCE: the 12.5 murray 38 in
The problem is in the carb. First try using some bottled fuel system cleaner at a heavier dose than for a car, but be aware that too much may damage the carb. Then run the fuel out and fill with fresh and try again. When you engage blades and it sputters try to throttle down until it runs smooth and then slowly bring engine back up to mowing speed. You should be able bring it up and mow. Run out the fuel tank. If unable to do this trick and get the fuel system cleaner through you will need to have the carb. taken apart and cleaned thoroughly.
Posted on Jul 07, 2011
  • 6468 Answers
SOURCE: my cub cadet 2146 tractor wont stay running and is spitting gas out of the carbrator
the new fuel we now have damages the needle and seat in the carb replace them both change the oil and add a fuel shut off valve inline with the fuel line and shut it off when not in use
Posted on Aug 02, 2012
wadingriver
  • 2069 Answers
SOURCE: Steiner lawn mower
Might be Coil Breaking down under heat. Not sure best way to diagnose other the cross your fingers and buy a new coil. Sounds like you did everything you could do Fuel -wise.
Posted on Oct 03, 2012
My cub cadet lt1050 lawn tractor mower starts when cold fine, but wont even turn over when hot.
you have bad valves it needs a valve job this is because the hatter it get it looses power and will shut down when to hot
May 25, 2014 | Cub Cadet Lawn Mower PTO Clutch Replaces...
Cub Cadet LT1042 PTO keeps shutting off after mowing several feet, will turn right back on but keeps shutting off
I have a Cub Cadet 1605 and it does the same exact thing. Try the PTO switch on the dash. I replaced mine and it works fine. Hope this helps.
Oct 12, 2013 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet shuts down, oil full but blinking light, runs like a champ til then
oil light says on for about 2 hrs from when it due to be serviced by the hr metre not when you have serviced
Apr 08, 2013 | Cub Cadet Riding Lawn Garden Zero Turn...
I have a cub cadet rzt 50 with a kawasaki 22hp engine it cranks and runs fine for a while and then sounds like its running out of gas, I shut the pto off and it eventually quits running, I pull the choke...
PDF]OPERATORLS MANUAL - Cub Cadet
https://www.cubcadet.com/.../CubCadetCatalogAssetStore/.../own...Cub CadetRZT Series Tractor - Model RZT50VT. Form No. 769-04647 ... Please read this entiremanual prior to operating the equipment. It instructs you how to safely and ...
Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline ...
cubcadet.custhelp.com/.../basic-troubleshooting---zero-turn-riding-mowe...
Scripting must be enabled to use this site. Support Center. Cub Cadet Website ... Basic Troubleshooting - Zero Turn Riding Mowers (Gasoline Powered). Answer ID 10646 ' Published 01/22/2014 11:27 AM ' Updated 01/22/2015 02:50 AM
May 23, 2011 | Cub Cadet Street Sign- tractor lawn riding...
I have an old Cub Cadet lawn tractor model 2155, where the PTO clutch stops working after about 15 minutes of mowing. It will re-engage after it stops, but will only mow for a couple hunder feet before it...
I have a Cub Cadet 2155 lawn tractor that mows great, purchase in 1999, however it started heating up about an hour into mowing and then I have to shut it down until cools. I have replaced the air filter & that did not work ?
Help.......Thanks
Aug 10, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Need manual for 1863 cub cadet
Go to agriconmanuals.com, They are priced at 17.00 there.
Jan 05, 2010 | Cub Cadet Street Sign- tractor lawn riding...
I have a cub cadet zforce 48 zero turn. It starts right up, but when I take the brake off it shuts off.
Can't get my Cub Cadet started. We've replaced the battery, checked the seat sensor all is good. Any advise would be appreciated!!
Thanks
Angie
Apr 07, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
56 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
