Question about Dishwashers
Bosch shu43c02uc Hi, My shu43c02uc/40 bosch dishwasher does not drain water. The pump works well when I start it from the overflow mecanism. I mean, the pump evacuates water nicely. The dishwasher does not perform the draining activity for all the programs. The main control board is new. Is there any idea? Thanks.
  • zerka Jul 23, 2013
    "Thanks Ernesto, The pump and motor assembly are all correct and work when it's activeted manually(i.e. without the unit control). All the mecanism is clean(verified). It seems that when the draining cycle is executed, the draining pump is not activated. "
  • Silke Willibald
    Silke Willibald Aug 30, 2016
    Exact same problem here. Found any solution apart from replacing dishwasher??
    Top Expert:
  • Dishwashers Master
  • 12,223 Answers
Test this steps and fix it. God bless you
Belt, Water Pump
Although few dishwashers have a water pump belt, if the dishwasher won't drain there might be a worn or broken water pump belt. After removing the lower kick panel the motor can be seen in the front, the water pump belt is on the bottom of the motor.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Drain Pump
If the dishwasher won't drain, the drain pump might be defective. Test the pump motor with an Ohm meter. Drain pumps are not repairable, if it's defective it will need to be replaced.
Drain Impeller
The drain impeller is attached to the pump and pushes the water out of the dishwasher, through the drain tube and into the garbage disposer or drain line. If the dishwasher won't drain, the drain impeller might be broken or worn out. Replace both the impeller and seal at the same time.
Drain Solenoid Kit
If the dishwasher won't drain, the drain solenoid kit might need to be replaced. The drain solenoid is an actuator that opens a flap to allow the water to drain.
Drain Valve
The drain valve can get clogged with debris and should be cleaned out if the dishwasher won't drain. If it seems clear of debris but won't actuate, it will need to be replaced. The drain valve is not repairable.
Pump and Motor Assembly
If the dishwasher won't drain, the pump and motor assembly might be defective. If the motor runs during the drain cycle, check for a blockage in the drain line. If the motor won't run during the drain cycle or if it just hums when it should be running, the pump and motor assembly might need to be replaced.
Clogged or Improperly Installed Garbage Disposer
If the dishwasher won't drain and the garbage disposer was installed recently, the installer might have forgotten to knock out the drain plug from this disposer. All garbage disposers are sold with a solid plug in the drain tube for situations where a dishwasher isn't connected. However, if the dishwasher is connected, the plug will need to be removed. If the disposer wasn't replaced recently, remove the dishwasher drain hose from the disposer and clean out both the fitting on the disposer and the end of the drain hose. These are the most common places to find an obstruction if the dishwasher won't drain.
Drain Hose
If the dishwasher won't drain the drain hose might be clogged. Remove the drain hose from both the dishwasher and the sink drain to clean it out. The most common place for an obstruction is at the garbage disposer.
Check Valve
If the dishwasher won't drain the check valve might be stuck closed. The check valve is a device which prevents water from returning to the dishwasher after it has drained. If the valve gets stuck closed, it will prevent the water from draining. The check valve is located in or at the outlet of the pump that the drain hose attaches to. Sometimes the check valve is accessed from the inside of the unit depending on the model.
Check Ball
If the dishwasher won't drain the check ball might be stuck. The check ball is a small plastic ball in the check valve which prevents water from returning to the dishwasher after it has drained. If the ball gets stuck, it will prevent the water from draining also. The check valve is the device that the drain hose is attached to on the dishwasher.
Posted on Jul 23, 2013
Testimonial: "Thanks Ernesto, The pump and motor assembly are all correct and work when it's activeted manually(i.e. without the unit control). All the mecanism is clean(verified). It seems that when the draining cycle is executed, the draining pump is not activated. "
  • Justin Ray
    Justin Ray Mar 22, 2015
    I have this exact same problem, did you find the fault?
SOURCE: Bosch SHU43C02UC/47
How to loose up the circulation pump
Posted on Nov 03, 2007
  • 213 Answers
SOURCE: Dishwasher does not start.
remove kick plate from below the door. youll see a white tray behind the kick plate there is water in the tray activating a over flow switch. using a towel remove the water. this will solve the problem
Posted on Nov 20, 2007
IB4G2008
  • 3587 Answers
SOURCE: Bosch SHU9915 Does Not Drain
faulty controls..the signals are apparently getting there, but the machine is intepreting them oddly..may need a new control board behind panel
Posted on Mar 09, 2008
  • 116 Answers
SOURCE: Not starting wash cycle
Typically this means that there has been a water leak of some sort and there is water in the lower base pan. This is the large white plastic base that the dishwasher sits on.
If you remove the toe kick and look back past the fill valve on the extreme left side of the dishwasher about 6 to 8 inches from the front you will see a red stick that goes straight up and down. This is a mechanical linkage that activates the drain feature. Be careful as there are live connections here.
This stick rests on a round piece of Styrofoam that acts as a float. If there is water present it will cause the stick to lift and the dishwasher will go into drain. The source of the leak will have to be isolated and corrected. Most likely it is the fill float assembly as referenced at the end of this post.
If the stick is not in the upright position then there is possibly an issue with the switch mechanism itself.
You will have to pull the dishwasher out from beneath the cabinet and remove the panel covering the left hand side. If it is a full panel then there are a couple of screws holding it on from the front through side trim as viewed when the door is open if it is a half panel then it can be removed by removing the large torx screw on the lower right as seen when facing the panel.
If there is a problem with the switch then the entire mechanism should be replaced.
Try the following link to a picture for reference. It is upside down as compared to the installed one:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=935595&PPStack=1
Posted on Sep 17, 2008
ginko
  • 19396 Answers
SOURCE: Pump Runs On After Water Is All Drained Out?
If the cycle does not stop draining that is usually because of a faulty water level switch that controls the water level in your appliance.
The faulty sensor cause the machine to think that there is still water inside, even when water has drained completely.
Check if the floating sensor is stuck or faulty.
Some machine may use a membrane switch instead of a floater.
Posted on May 21, 2009
I'm getting an E:15 on my new Bosch dishwasher and nothing works, how do I fix it?
E15 means that water has gotten into the base pan below the dishwasher and it is now in flood mode. You've probably noticed that the drain pump will run all the time now as well. What that means is that water has worked it's way down into the base pan below the dishwasher tub causing the unit to do nothing but drain. This is normally caused by the drain being clogged or too many suds in the tub causing the tub to overflow a bit. Either way, you'll need to uninstall the dishwasher and tip it forward at a 45 degree angle to drain the water out of the base pan. Be sure to put a towel under the dishwasher first so that the water is soaked up in the towel instead of going all over the floor. Once you've drained all the water out of the base pan, reinstall the dishwasher and pour a gallon of water in the dishwasher. If it drains it out right away and doesn't wash or refill, you still have water left in the base pan to try again, otherwise you're good to go.
Now if you don't want to do all this work just to get your dishwasher working again and you have time, let the dishwasher just sit unused for a week and the water in the base pan will evaporate as time goes on and the dishwasher will start working again after a week.
Sep 23, 2017 | Bosch Dishwashers
My bosch shu43c02uc wont work at all and i think i need to reset it, how would you reset it and can you think of anything else that will help with the problem?
Hello
Welcome to Fixya.
Based on your post,"my bosch shu43c02uc wont work at all..."
This is the most common reason for these Bosch dishwashers not having power.
I would start by first shutting off the breaker. Then removing the kick plate ( access panel at the bottom ) and checking the wiring at the junction box for the dishwasher 120vac supply line.
Remove the murret's and visually inspect the wire for "resistance burn" and strip the wires back and install new fastener's if necessary to repair.
i.e.
This is actually quite common to find a wire connector come loose due to improper fastening and once the unit is in use for a while the connections heat
Sep 25, 2010 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Bosch SGS5332GB dishwasher. drain pump runs all the time
There is a float under the machine that tells the pump to shut off. If the float is stuck or bad, the machine will keep draining. I am including a web site that might help. Bosch Dishwasher That Will Not Stop Draining Hunker
Nov 06, 2017 | Bosch Dishwashers
Dishwasher never cleans, glasses gritty dirty -- Bosch terrible s
you obviously need to check and make sure that you've cleaned your filter system. it needs to be cleaned every couple of months. and also make sure that your washing fans, the ones that spray water, aren't clogged. they need to be washed out and de-clogged regularly as well... i had this same problem.. but it worked fine once i cleaned the system.
Sep 06, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwasher: BOSCH SHE43 - pump keeps draining
Your dishwasher is stuck in flood mode. Bosch dishwashers are built with flood switches located in the bottom base pan of the dishwasher. The flood switch is connected to a rod that activates a small interlock switch. When water enters the base pan on a Bosch dishwasher, a Styrofoam puck lifts the rod, activating the flood switch.
When the flood switch is activated, the dishwasher will go into a no-fill, only-drain mode. The drain motor may also run with the door open to the unit. This is definitely a sign there is water in the base pan. This can be caused by the drain being clogged. There are two ways to fix:
1. You can uninstall the dishwasher and tip it forward to about a 45 degree angle to drain the water out of the base pan. (This is probably why Ian Bint's solution fixed the problem.) Be sure to put a towel under the dishwasher first so that the water is soaked up in the towel instead of going all over the floor. Once you've drained all the water out of the base pan, reinstall the dishwasher and begin a cycle. If it fills and runs, you are good to go.
2. You can also unplug the unit, then remove the kick panel at the bottom in the front. (It's attached with two screws.) Then get some old washcloths or small towels and reach into the base pan below the dishwasher to soak up the water. The pan is directly behind the plastic base panel rim. Once the pan is empty and dry, your dishwasher will no longer be in "flood mode" and will run properly.
If the base pan keeps refilling with water and the no-fill problem returns, there is definitely another issue, such as a clogged drain. At this point, you need to decide whether to invest in an expert evaluation by a certified Bosch repairman and make the necessary repairs, or buy a new dishwasher.
Jun 28, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Bosch Dishwasher pump keeps emptying
Disconnect the power to the unit. Remove the lower access panels and check the tray under the dishwasher. You will probably find it is full of water. Use a towel or a sponge to remove the water. There is a float that will stop the operation of the unit and run the pump if water is in this tray. Test the unit. If there are no leaks, check the drain hose under the sink. THE DRAIN HOSE MUST RUN UP TO ABOVE THE TOP OF THE MACHINE THEN TO THE DRAIN. If the hose is not set up like this, water from the sink drain will flow into the dishwasher and overflow into the tray under it.
If there is no water in the pan under the dishwasher there may be a problem with the pressure switch at the side of the pump housing but the only way to know for sure is to do some electrical testing with a volt/ohm meter and the wiring diagram located within the appliance.
Go here for Bosch Dishwasher Parts: http://www.repairclinic.com/Bosch-Dishwasher-Parts
www.RepairClinic.com
Feb 11, 2009 | Bosch 24 in. SHU53 Built-in Dishwasher
Bosch SHU43C02UC/47
Oct 22, 2007 | Bosch 24 in. SHU43 Built-in Dishwasher
Dishwashers Logo
220 people viewed this question
Top Dishwashers Experts
