Question about American Standard WCZ036F Air Conditioner
Blower motor never cycles off when in AC mode, even when the desired temp is reached
  • Durk Lee Jul 24, 2013
    We have had the entire cooling unit and thermostat replaced, but the blower problem (not shutting off) existed before the AC was replaced, so I don't think it's the thermostat. Even with the thermostat off, the blower continues; have to shut it off at the emergency power switch on the side of the unit.
    New Friend:
  • 20 Answers
Not sure if you ever figured it out. Or if someone figured it out for you. Shows no one answered you on here. So I thought I would ask you a question plus also say what I thought it was . When the unit and or the thermostat was replaced? Was the thermostat wire that is inbetween the unit and the blower ever replaced? A service tech should have checked if the tstat wires were touching or shorted together. If you go by color which you should never do. Red is usually 24 volts or power, green is fan, yellow is cooling, white is heat, orange is the reversing valve if its a heat pump, orange to O terminal if RV in cooling or orange to B terminal if RV in heat. O or B terminal depends on who the manufacturer of the unit is. Blue wire is usually the common. you should always check to see how it is wired at the board or relay in the unit. not everyone wires it by the colors. If your fans low voltage wires are touching the low voltage 24 volt power wires in the unit or if the wires are shorted or touching in the wire sleeve or at the thermostat. the blower motor will never shut off. Or if the blower motor is wired directly to line voltage it will never shut off and testing the low voltage wire wont matter.
Your question was from last summer. So I am assuming you had someone figure it out by now. If not then check my suggestions. Hope that helps you.
Posted on Apr 02, 2014
We just had a dometic rooftop ac b59516.711co installed 2 weeks ago and today, when the desired temp is reached the unit will cut off but not come back on when temp goes above desired temp.
That is normal. Typically a unit doesn't maintain the exact Set point temp. If set for 75 it cools to 74 and doesn't restart until 76. Obviously if getting too much higher than that there is a problem. Units also are programmed with maximum and minimum run times as well as how many times it can cycle per hour. Hope this helps!
Jun 09, 2017 | Dometic Heating & Cooling
My ac randomly turns off and when I restart it it does the same again
HOME A/C units are designed to shut off when the desired room temp is reached.it is called Cycling. when the temp control unit senses that the temprature is too high then it will turn the unit back on till it again reaches the temp it is set oto
Oct 01, 2015 | AC Cars & Trucks
AC will not shut off when desired temp is reached. Have replaced batteries.
thats simple. this is caused by weak power button of board. let me know if you dont know how to do this.
May 31, 2012 | Heating & Cooling
My Payne furnace is NOT producing the desired heat anymore. Any ideas?
Hello, it could be shutting down on it's high limit switch due to a dirty air filter, dirty blower wheel, weak blower motor. Usually this would cause the furnace to shut down before it reaches the desired temp.
Dec 30, 2011 | Heating & Cooling
Why does Blower in the inside unit continues to run non-stop? Thermostat set on Auto
Hi!!
If when the desired temp. is reached, the compressor and condenser motor (outside unit) will shut off but the blower in the inside unit will keep working when the thermostat is set to Auto, the problems could be 1 - thermostat unit defective, and 2 - blower motor starter relay defective.
Good Luck!! Don't forget to rate this post!!
Sep 21, 2010 | Heating & Cooling
My air stops running inside before it get to the temp. Its set for but the outside unit keeps running and after a minute or two the air will start blowing inside again but the outside unit never turns off...
you have a possible thermal overload problem in your furnace blower motor dirt will cause this problem when it doesnt allow air across the windings of the blower motor if not dirt the motors going bad and getting hot use a shop vac and eliminate dirt keep your filter changed and your evaperator a coil may also need checked for cleanliness this will require cutting into plenum my advice someone qualified and remember dirt kills
Jun 18, 2010 | Goodman CKL36AR36 Air Conditioner
AC turn off before it reaches the desired temp
Hi there. I assume the indoor fan runs continuously until the house has cooled down. Clean the condenser. (outside unit)
Another possibility is that the system is getting low on freon. Check for leaks with soapy water at all joints and fix them.
Thanks
Paul
Jul 13, 2009 | Ruud UAKA060 Air Conditioner
I have a comfort zone furnace. If it's 50 degrees in the house, and i set my thermostat to 70 or so,it takes at least 24 hours to reach 70 degrees. The furnace starts up and runs normally for about five...
When the thermostat calls for heat it should run until the room reaches the temperature setting then shut off. Is the blower motor running and can you feel air coming out of the vents? It sounds like the blower is either not running or putting out enough air to keep the furnace heating. The blower moves the heat from the heat exchanger to the room, if it can't remove enough heat from the heat exchanger there is a limit switch that will shut the burner off if it gets to hot and that's what it sounds like is happening.
Apr 25, 2009 | Heating & Cooling
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
American Standard WCZ036F Air Conditioner Logo
53 people viewed this question
Top American Standard Heating & Cooling Experts
Craig Butler
Craig Butler
Tim Whalen
Mack Baxter
Are you an American Standard Heating and Cooling Expert? Answer questions, earn points and help others
