Question about Acer Aspire 5749-6492 Intel Core i3 2350M 2.3GHz Notebook - 4GB RAM, 5
Clearing bois password - Acer Aspire 5749-6492 Intel Core i3 2350M 2.3GHz Notebook - 4GB RAM, 5
  • Acer Master
  • 27,725 Answers
Acer laptops are equipped with a BIOS utility.
The BIOS (which stands for "Basic Input Output System") acts as an interface between the hardware and software installed on the computer.
On some computers, a BIOS password may be required in order to boot the computer and make changes to the BIOS settings.
If you are unable to access the BIOS settings and do not know how to reset the BIOS password, you might be tempted to send the computer back to the manufacturer for repair.
Fortunately, that's not necessary as there is a simple way to do this on your own.
Go to "Start," then perform a search for "Command Prompt."
The Windows Start button is located in the lower-left corner of your computer screen.
Double-click on "Command Prompt" to open the application.
You will need to use MS-DOS commands to reset the BIOS password.
Type the following commands one by one in the order shown:
debug
o 70 2E
o 71 FF
quit
Make sure that you are typing the letter "o" and not a zero at the beginning of the second and third commands.
Reboot your computer by clicking "Start," "Shutdown," and then "Restart."
The BIOS password will now be reset to default.
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
http://www.tech-faq.com/reset-bios-password.html
At some stage you might need to press Ctrl+Enter rather than just Enter if on a Dell Latitude E5410
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
Posted on Jul 23, 2013
Power on bois password
There are a few sites that suggest backdoor passwords to overcome the Bios power on password, however, these rarely work, IF the laptop is yours, you should be able to contact Dell and get it cleared
Dec 29, 2010 | IBM ThinkPad T42 Notebook
Reset bios/cmos password
on the bottom of the vostro 1510 there is a large panel that covers the hard drive, wifi card, and cmos battery connector. remove the cover unplug the red and black wire connector and remove the battery. also make sure the system is unplugged from power. i waited about 5 mins and pushed and held the power button for about a min. after that plug the main battery in and test to see if your password has been removed
Jun 06, 2010 | Dell Vostro 1510 Laptop
When i start my computer it ask for a password for the bois
You can reset bios password with 2 method.
(1) open back cover of laptop then find motherboard .Pull cmos cell from motherboard for 15 minutes then again put it in it's position .then it not ask for password.
(2)You can clear password with jumper settings find jumper on motherboard named clear cmos it has 3 pin .1-2-3
Put jumper in 2-3 position then again put it in 1-2 position then check .
Let me know if you need more assistance.
Thanks.
Dec 25, 2009 | Dell Inspiron 1150 Notebook
Clear password
go into the bois and set the password off, restat the pc press delete or f2 yust read what they ask you, what happend is you cmos battery went low so it reseted the default cmos settings, replace the battery if you have to, it will work
Oct 08, 2009 | Intel Motherboard
Want to change XP to ubuntu it wont let me go into the bois to boot from a cd
You may have to enter a password to access the BIOS. If you don't have the password, you may need to reset ( clear ) the persistent settings. The owner's guide usually gives directions on how to do this.
Sep 08, 2009 | Toshiba 50H82 50" Rear Projection...
Dell XPS M1330 BOIS PASSWORD
BIOS passwords, if forgotten, mush be reset by calling Dell Technical Support, Verifying that you are an authorized user, then they can assist you in clearing the password
Sep 04, 2009 | Dell XPS M1330 Laptop
How can i remove a bois password from toshiba
clear cmos setting by replacing cmos battery
if problem not solve then
change bios on motherboard
Jul 18, 2009 | Computers & Internet
Bios password lost
Dear there are three pwd pin on motherboard first you set configration mode 12 then you start you system go into bois setup there is option clear password.click it.f10 save and exit. after doing this now put normal mode pin setting.
now your passward is broken.
enjoy your laptop.
thanks irshad
May 24, 2009 | Acer Aspire 5100 Notebook
Need to clear the power up password from bios
dear,open the casing and unplug the power cable
and also deattach the CMOS.
after 5 mint all the cables attach.
then all the bois password cleanup.
Apr 11, 2009 | HP Compaq nx5000 Notebook
Forgot password
which if bios u have to clear your bois setings.
for that iopen the case of cpu.
then u see cmos cell put back those cmos cell from its case for 20 minutes then resrt the pc.
set again its original space.
if ur prompt again for password u also set jumper which is nearly that cmos cell.
set in 2-3 position then restrt the pc then go to bios setup
clear your bios password.
then save settings
then again set the jumpoer in its position.,
Sep 29, 2008 | Computers & Internet
Acer Aspire 5749-6492 Intel Core i3 2350M 2.3GHz Notebook - 4GB RAM, 5 Logo
75 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
