Question about Cameras
Red light blinks during buffering - Cameras
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Cameras Master
  • 102,366 Answers
What make and model camera? With some cameras this is perfectly normal, a blinking light indicates that the camera is still buffering.
Posted on Jul 22, 2013
Standby light is light red when the power button is pressed. The power light turns blue and flashes 7 times on the seventh time stays solid blue. The panel doesn't light up or anything. I can hear the...
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Jun 16, 2015 | Televison & Video
Blinking blue power light
check buffer boards for blown chips but before check main board for puffed up capacitors need to replace bad capacitors on main board usually 3300/100v ones bigger ones on board then check buffer boards for blown chips usually bottom buffer board
Aug 05, 2013 | Hitachi P50H401 50 in. Plasma HDTV
Power on difficulties.
Either the power supply has an issue , or you have a bad buffer board and Ysus scan board or both.red light indicating may mean power supply , 7 blinks the buffers and y board.
It could be just a few bad capacitors on the Power Supply, there could be a bad capacitor on the Y board if its bad it needs to be replaced with the buffers together
If you want to attempt the repair yourself you can do a visual of the power board caps will appear swollen on top.
The ones you are looking for are located almost center bottom of the power board,Usually I can see them clearly with the back on simply shining a light into the back through the holes
With the back removed you will see a few circuit boards the upper one (ac cord runs to it through a small board) is the power supply, it has a lot of capacitors on it (cylindrical standing straight up soldered in and marked on the sides with the positive/negative sides and uf and Volts values)
Philips uses 2200uf or 3300uf at 35Volts rating capacitors, they cost about $1-$2 each
The power board and back unscrew with a torx bit and screwdriver size 10 and 15 , if you do not know how to desolder and resolder then do not attempt this as you may damage the TV more than fix it.
We do not recommend do it yourself, but depending on your knowledge and technical ability you may be able to.
You can replace the whole power supply, .
If there is a blinking red light on the TV count the blinks,if it still blinks after replacing the swollen cap this would indicate a bad buffer board ,
check the capacitors by looking for the swollen tops .
I hope that will helpout.....
May 18, 2011 | Philips 50PFP5332D 50 in. Plasma...
Tv won't turn on. It blinks green then red.
Question shows tv is Sony KDF-60WF655.
Green light blinks when tv gets prepare to fire up lamp, check internal circuits then show picture on front screen.
Red light blinking shows some kind of internal problem during circuit check and protection got activated upon some failure.
Count the red light blink as you will see 3 second long pause and post it here to diagnose what section of tv got problem.
Did you replaced its lamp in last 2-3 years?
Thanks.
Jun 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
My tv just stopped working, and the red light just blinks. whats wrong?
COUNT THE BLINKS----this set has a built in error buffer--if you have to unplug it and plug it back in-when it does not come on count the power light blinks.
3, a pause and 3 is the most common.
Let me know the error code and I will try to help you.
SD TECH
Dec 03, 2009 | Panasonic PT-47WX49 47" Rear Projection...
Philips 42pf9630/37a, Blink red LED 7 times, No Picture No Sound
7 blinks indicates a bad buffer board, usually I replaced the Y board and the buffer/s about $500-600 in parts. but before you buy anything open the set and look at the power supply if you see two capacitors that look swollen , bulging on top they need to be changed and may solve the issue. the power supply is middle top . If you are not wanting to repair it yourself then know that you do have some circuit board repairs needed.
thanks
Eric
Aug 17, 2009 | Philips 42PF7320 42 in. EDTV-Ready Plasma...
I have a 50" philips plasma , shuts off and blinks red light 2 and 7 times Y main board module problem?
this web site has a philips service manual that might help. I have to say, you have to be somewhat technically inclind to understand it. http://www.scribd.com/doc/6528782/Philips-42pf7320
Nov 07, 2008 | Philips Magnavox 42MF521D/37 Television
Red light flashes & times
7 blink error is 8.6 volt error usually tied to y main board. would advise to disconnect y main from power supply and verify vs voltage. if vs is present replace y main and general protocol is to replace y upper and lower buffers as well as they complete circuit
Aug 10, 2008 | Philips 42PF7320A 42 in. Plasma HDTV
Blinking red indicator light
Hey pollyannac,
The red blinking light probably means either the flash is recharging, or the camera buffer is full and it is writing files to your memory card which the lcd monitor should read Busy while the camera is writing the files. If it is the flash recharging then you could try using more powerful batteries such as the Canon NiMH AA batteries. If the problem ends up being the camera is writing images to the memory card you could try getting a memory card that has a high write speed. These memory card are usually more expensive, but in my opinion well worth it. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 04, 2008 | Canon PowerShot A720 IS Digital Camera
Cameras Logo
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
