Question about Acer Aspire Computers & Internet
Shortcut keys I accidentally added some short cut keys on my main screen at the very top and they wont let me delete them how do I go about doing that?
  • Acer Master
  • 27,725 Answers
What have you tried ?
which operating system ?
You can use the System Configuration utility to perform a system restore.
There are three possible restore points: System checkpoints that Windows schedules
Manual restore points that you specify with the System Configuration utility
Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly.
This may also help determine the cause of the configuration error.
To perform a system restore, follow these steps
1.Click Start, click Run, type msconfig, and then click OK.
2.On the General tab, click Launch System Restore.
3.Select Restore my computer to an earlier time, and then click Next.
4.Calendar dates in bold are possible restore points.
Click the most recent one to view system restore information.
5.Select a system checkpoint or an installation restore point, and then click Next.
6.Close all other programs.
7.To start the system restore, click Next.
8.Your computer restarts.
Repeat steps 1 through 8 until you fix your configuration issue.
Posted on Jul 23, 2013
4 Suggested Answers
  • 10 Answers
SOURCE: Toshiba portege r500 keyboared short cut keys not working
drivers wont help it seems to me you might have a broken line sometimes common in second hand laptops where keyboards have been removed time after time its a plastic ribbon cable which slots into an interface socket on the mainboard,you could get somebody to check that the cable hasnt been pulled out of the slot,or if liquid was spilled then a replacement keyboard is then the way to go.
Posted on Dec 07, 2008
rajak2009
  • 527 Answers
SOURCE: i deleted my cyberlink youcam shortcut in my
Sir,
Right click at desktop go to New->shortcut->it ask the location of which the program is stored. click the location C:\ of that software. It will be created the shortcut
Thanks Good luck
Posted on Aug 10, 2009
gobindagogoi
  • 133 Answers
SOURCE: How to put short cut icon for Open Office on main screen
Start>All Programmes>Right click on "Open Office">Send to>Desktop
Then you will find the short cut icon on your Desktop.
Posted on Nov 02, 2012
How do I enable a compaq laptop's keys
Compaq Presario computers provide users with a row of function keys for added keyboard functionality. Function keys can serve a dual purpose as well.
Function keys are located at the top of Compaq Presario keyboards.
By learning how function keys work on a Compaq Presario you can take advantage of time saving keyboard shortcuts.Purpose
Use function keys to access menus, save changes and create shortcut keys.
Various applications, including Microsoft Office, allow you to select a function key as a shortcut key for running specific tasks. These settings are usually found under the Tools, Settings or File menu.
Each Compaq Presario computer has twelve function keys.
The most common used keys are "F2," "F8," "F10" and "F12."
The first three are used mainly to access and use the Compaq BIOS. "F12" is used to access a set of run from options during the boot process.
How to Access
Access function keys on a Compaq Presario by pressing any of the keys on the top row of the keyboard. Access the key's dual purpose by first pressing the "Fn" key located on the bottom row of keys.
Use function keys as shortcut keys by pressing them anytime while in the desired application. Remember, you must set them as shortcut keys first.
Note that some programs may already have certain function keys set as shortcuts.
Open menus and view the shortcut keys beside each menu item before setting your own shortcuts.
Dual Uses Each function key has a dual use. Press "Fn" plus the desired function key for the key's other use.
Below each function number is a small picture within a square or rectangle.
This dictates the dual use. "F1" opens help and support. "F2" serves as a printer shortcut.
Open your homepage by pressing "F3."
If you use dual monitors, switch between monitors by using "F4." "F5" puts your computer in stand-by mode.
Quickly lock your computer by pressing "F6." "F7" and "F8" adjust the screen's contrast.
Play and pause your music in Windows Media Player or other default media player by using "F9."
Press "F10" to stop playing media. Skip ahead or rewind media by using "F11" and "F12."
Other "Fn" Keys
In addition to function keys, the "Fn" key is also provides other keys with a dual use.
Any key with a small square on the key has a dual purpose such as the "scroll," "insert" and "delete" buttons.
Since laptop keyboards have no number pads, certain keys serve as the number pad by pressing the "Fn" key.
Jan 08, 2012 | Compaq Computers & Internet
Tip
Shortcut keys
Some of the advanced features of windows allows shortcut keys these keys allow you to open applications faster this is a list of key combination and what they do the first set of shortcut keys and mostly designed for text applications such as notepad Microsoft word wordpad and any other text input application the first set of combinations keys are CTRL key and the letter C at the same time this allows you to copy highlighted text the next combination of keys are CTRL key and the letter V this allows you to paste that copy text you copy using CTRL C into text application or any application that uses keyboard input the next set of combination keys are CTRL P this allows you to print the current text document just as you would if you went file print the next set of keys are more designed for windows application shortcuts if you're on your desktop and you want to open the run dialog box that holds the windows key and press the letter R and you'll see the run dialog box here you can type in locations of files and open them through the run dialog box the next short cut key the allows you to open explore not to be confused with Internet explorer, that explore application is what opens up when you click on my computer my documents and the anything else to view folders files hard drives pictures movies and music or anything else that's inside a folder that the shortcut key to access this is the windows key and E at the same time it should open my computer because this is the main explore application the next key combination of more for advanced users CTRL+ Alt+delete this key combination accesses the task manager program which shows the process list the CPU usage and programs that are open and network activity this program allows you to end processes and programs that are frozen and do not recommend ending any processes that you're on not familiar with this may cause a computer crash or you lose data but ending application from the application view is OK if the applications is frozen because the computer will automatically end the applications processed for you safely as Microsoft has updated to windows Vista and windows 7 they'v added a new feature called the Arua effect if your computer is new or you have a compatible graphics card by pressing the windows key and the tab key at the same time will allow you to scroll through all the open applications in a 3D window this next set is mostly for laptops on laptops on the keyboard there's a key labeled FN which is short for function each laptop is different but in small print on the main keys you should notice little letters symbols or numbers are holding the function key and pressing one of these keys that have one of the symbols letters or numbers will allow you to access the secondary feature the keyboard as soon as you let go of the function key the keyboard returns to normal for example most computers will have a sun symbol on the up and down arrow keys this allows you to adjust the laptops brightness all you have to do is hold the FN key and press one of the arrow keys and you can turn the brightness of your screen up or down these are some of the few shortcut keys and you can do with windows there are many more hope this tutorial helps
on Jan 23, 2010 | Computers & Internet
How can i delete an application on my main menu that i accidentally added?
if u have touch screen, touch the app until it vibtqtes and drg it to the trash can> to completly remove go to downoads touch the application and you will be prompted if you wish to delete app, if yes then confirm deletio
Nov 21, 2011 | Samsung Corby 2 GT S3850
Short cut key of MS OFFICE and MS EXCEL Plz provide me short cut key
try doing this:
click on start then go to all programs.. highlight the program you wish to have a shortcut to your desktop.. right click your mouse then select send to desktop shortcut
Feb 22, 2011 | Microsoft Computers & Internet
Hi wat is the shortcut to turning the blue tooth
hey brian
in this model there is no short cut for blue tooth as such but you can set a short cut by personalising your short cut keys like your joystick keys or even your selection keys.
hope it helps
Oct 03, 2010 | Sony Ericsson W350A Cell Phone
I can't figure out how to remove shortcuts from the home screen of my LG Chocolate Touch. I can drag shortcuts such as calendar or calculator to my home screen so that I can simply open them in one touch....
go to your main menu, go to settings. go to displays. scroll down to "short cut bin" snd make sure it is turned on. a faded arrow will now appear on the right side of your display screen. drag the icon you want to get rid of to the arrow which will turn into a trash can.
Nov 12, 2009 | LG CHOCOLATE VX8500 Cellular Phone
I need to know how to delete messages on the Verizon LG Envy2
Open your phone and hit the top left key (this would be the short cut to send a message). Then hit the top right key (options). Hit the down arrow 4 times, hit ok twice and this will delete all but the unread messages.
May 03, 2009 | LG enV VX9900 Cellular Phone
Samsung Omnia - Main Menu Function key gives a shortcut error.
Assign the key to another function. And then reassign it back to the main menu short cut. It worked for me.
Dec 09, 2008 | Samsung SGH-i900 Omnia Unlocked Cellular...
Lg Dare phone
Leslie,
I had purchased and am currently using the LG dare. The issue that I had with the icons apprearing on my main screen was that I was accidentally holding down and dragging the icons from my shortcut menu to the main screen. The easiest way to get rid of the icons from the main screen is to hold down the icon and drag it to the little arrow for the shortcut menu, and it should dissapear.( I just did it on mine so it should wok for you).
If that doesn't work, open you shortcuts menu, hit the set button and remove the icon from the shorcut menu (this should remove it from the main screen as well.)
good luck!
Nov 16, 2008 | LG RUMOR Cellular Phone
Want to remove short cut keys from my screen
how to remove 2 shortcut i have same pro
Aug 13, 2008 | LG KU990 Viewty
Computers & Internet Logo
51 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
