AEG Lavamat 72640 Front Load Washer
Problem for AEG Lavamat 72640 Front Load Washer
Washing machine AEG 72620 not functioning.
By Desparate on Aug 29, 2007
I put in a wash as normal, and only realized there was a problem as there was a noise of clicking on the right side,top part of the washing powder drawer which I then took it out and noticed when you take it out it is more loud, and there was no water coming through although it had sounded like the water was going to come through when it was started but realized that it is only the sound. I have cleaned and washed the black coloured pipe and screw top at the bottom of the washing machine. PLEASE HELP!!
Comments:
Sep 01, 2007
- You are absolutely correct there,my husband has positioned the lever to the correct position and removed the white free wheel so we can still carry on washing, without having to worry about the wheels getting stuck. We will order the part and change it so yet again PLEASE HELP!!! letting me know where to order the part--the company?
Much appreciated.
Same Problem
Sep 10, 2008
-   i've heard the same clicking sound from my machine when i put it on. no water is taken in. what could be wrong and which part may need replacing? sparkworld-   sparkworld
Jan 13, 2008
-   Hello,
I have identical problem to meenabix posted on 14th November.
How much do I need to purchase, just the cogs or the whole unit. Are the cogs an integral part of the unit ?
Also, where would I get it from.
Many thanks in advance.
Jackie-   Jackieblue
Nov 14, 2007
-   Hi...was having the same problem but mine looks as though it isn't working because some of the teeth on the pink cog are broken...can I just buy a cog? and is there a special layout I need to follow when putting the 3 cogs back together?
Many thanks-   Meenabix
Best Solution
posted on Sep 01, 2007
Helpful)
ferk
Rank: Apprentice
Rating: 90%, 1 votes
Having worked for AEG for over ten years, the fault is a faulty dispenser unit ( top of soap draw) only fix is to replace the unit ( cost approx £45)
Was this helpful?
Yes
No
Solution #2
posted on Aug 29, 2007
Somewhat Helpful)
dovi
Rank: Guru
Rating: 88%, 2494 votes
It sound like a detergent dispenser issue. The dispenser is located above the detergent drawer. A water pipe is connected to it and water entrance and distributed to drawer's cells (following the programmed cycle) by a lever's movement (part of the dispenser). The lever movement is controlled by two solenoids that received their power from the timer.
By opening upper machine's cover you will have an access to the dispenser.
Disconnect the power cable from the machine before moving to next test !!!!
Look first that they are not any disconnected wires.
Move manually dispenser's lever and see if water running to all cells (depend on your movement). In case it doesn't work properly remove the unit from the machine and try to clean it (I hope it will help, otherwise you should replace the unit).
In case it works properly (manually) - you should test by a multi-tester solenoid's resistance. the one that doesn't have a resistance measurement should be replaced.
Good luck !!
Was this helpful?
Yes
No
Solution #3
posted on Mar 08, 2009
Not Rated)
premm
Rank: Guru
Rating: 93%, 3318 votes
Sites for spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Was this helpful?
Yes
No
Popular Solutions for AEG Lavamat 72640 Front Load
Questions and Unsolved Problems for AEG Lavamat 72640 Front Load
Do you recommend AEG Lavamat 72640 Front Load Washer?
Answer
Answer
beko washing machine not takin fabric softener, still left in the drawer at end of cycle? cleaned... (More)
Answer
My AEG Lavamat 605.636.204 does not pump out water. Can you help, George Go
Answer
my aeg lavamat 72630 is coming up with e20 and wont finish a load i dont think its pumping out water... (More)
Answer
my aeg oko lavamat 72640 update keeps stopping in the middle of programmes. Sometimes the stop/pause... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For AEG Lavamat 72640 Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14846
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
