Question about 3Com Computers & Internet
Packet light not blinking - 3Com Computers & Internet
All lights on wireless router blinks what is the problem
The LEDs will blink when working properly, It is tramsmitting and receiving data packets to and from your computers and devices. If it stops blinking you may have a problem. Even with all device turned off, the ISP moden and the Linksys still transmit and receive data. It's a constant communication of, "are you there", "yes I'm here", 'are you ok", "yes i'm ok", you get the idea.
Dec 22, 2012 | Linksys WRT310N Wireless Router
CG814WG V2 Downstream Failure on video games?
Hi, from what you are saying it appears the router is hanging, maybe it can't handle the traffic, try upgrading the firmware from the configuration utility of the router.
PS: In games is NORMAL to have more traffic on the "upstream" side because it's refreshing what you are doing, and when you are browsing you only send little packets and you receive a lot of packets.
I hope it helps.
Jul 27, 2010 | NetGear CG814M (pn-3201155) Modem
Ethernet light is green but continuously blinks is there a problem with modem or ethernet cable?
no, a green light means there is a connection with the network and dns server (gateway to the internet) information is sent allow this network in bundles called packets. Each time a packet is sent the green light blinks.....sometimes when many packets are being sent in succession the light will appear solid. so i wouldnt worry, the green lights on your router and computer are normal and you should become concerned if these lights turn yellow or stop blinking completely.
Good Luck and Please Rate This Post!!!! :D
Oct 14, 2009 | 2wire (1000-000057-000) Modem
Internet issues i have a seemingly similar problem. when playing a multiplayer network game, i can go only about 1 minute or two before i get disconnected from the server. seems like i'm losing packets...
Sounds like your exceed your bandwidth when you play online. Like you said you having packet loss cause you are not transmitting and receiving all the info due to your connection. And if you play more than one, two, or three pc at one time then you just cut your bandwidth severely. I recommend you check on your upload speed. If you have 128k up and playing multiple pc it will bottleneck.
Go do a speed test-- www.speakeasy.net post back your results
May 31, 2009 | Arris SURFboard SB5120 Modem
USB Keyboard not working
the lan light will obviously keep blinking bcoz of the data packets keep on transferring.......thats normal.....thats not a problem.
for ur key board switch off the num lock
Feb 28, 2009 | Intel D945GCCR Motherboard
CISCO 2600 Router Troubleshooting
This is the indicator configuration for the 2600, if the lights are yellow there is a problem.
The following indicator LEDs provide power, activity, and status information:
POWER (green)—Lit when power is on
RPS (green)
Off—No redundant power supply (RPS) is present
Blinking—System is booted, RPS is present, RPS failure
Continuous on—System is booted, RPS is present, no RPS failure
ACTIVITY (green)
Slow, steady blinking—System is booting
Blinks during system activity, such as interrupts and packet transfers
I suggest going to Cisco.com for full documentation on this product.
Feb 19, 2009 | Cisco RPS 22/18 (cab-rps-2218)
Signal lights
Do u have plug in style bulb, or push in and twists type? Whichever it is, did u check for corrosion where the bulb makes contact? If it's white, powdery, etc, it might not be making contact, and it won't work. Clean up any corrosion, and get a small packet of 'dielectric grease' , put a dab on the contact area, this will prevent future corrosion. Do u have a blinking side marker light? If u do check that also. Let me know what u find. good luck! countrycurt0
Sep 20, 2008 | 1994 Ford Ranger Supercab
MSI wireless G RG60G fast bliking wan.
hello!
fast blinking wan light may indicates that it receiving or sending data. try the ff and see if this may work:
Step 1: Shutdown the computer.
Step 2: Unplug the router’s power cable.
Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds.
Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable.
Step 5: Plug in the router's power cable once the modem’s lights appear stable.
Step 6: Power on the computer on and test the Internet connection.
Apr 24, 2008 | MSI Wireless-G RG54G3 Router
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Cannot find print server at all
How this works: Restoring the PocketPrintServer to Factory Defaults In most cases, the best way to restore the PocketPrintServer to factory defaults is through "telnet". However, if you are unable to connect to the device because of a configuration error, use the following method which does not require a network connection. To restore the PocketPrintServer to factory defaults, complete the following steps: 1. Disconnect the PocketPrintServer from the network and power cycle it. When it powers up, the LED will rapidly blink orange for five seconds. 2. Power down the device during the rapid orange blink period. Power up the device and power it down during that orange blink period two more times. 3. Reconnect the network cable and power up the PocketPrintServer. It will have restored itself to factory defaults and will rapidly blink green as it searches for a RARP or BOOTP server to find an IP address. Gleaning If an IP address has not been permanently assigned when the PocketPrintServer is powered on or reset, it will look for a "ping" packet on the network. If the PocketPrintServer receives a "ping" packet within two minutes, it will accept the IP address in the "ping" packet as its own address. To use Gleaning, you must have super-user privileges on a UNIX system. Gleaning also works under Windows 95 and Windows NT. 1. Add an entry in the ARP table that assigns an IP address to the Ethernet address of the PocketPrintServer. To do this, use the "arp" command. arp -s temp Example: arp -s 192.168.42.24 00:02:16:00:00:01 temp 2. Start a continuous "ping" to the PocketPrintServer. ping Example: ping 192.168.42.24 On some systems, this may require an additional parameter. Some implementations of "ping" only send out one "ping" packet which could get lost in transit. Check your system documentation for more information. 3. Connect power to the PocketPrintServer. The PocketPrintServer will "glean" its IP address from the "ping" packet. This IP address will remain in effect until the PocketPrintServer is power cycled or reset. Therefore, a permanent IP address should be assigned by running the ExtendView TCP/IP utility or via "telnet".
Jan 30, 2007 | Extended Systems Pocket Print Server
Computers & Internet Logo
19 people viewed this question
Top 3Com Computers & Internet Experts
steve morris
steve morris
micky dee
Are you a 3Com Computer and Internet Expert? Answer questions, earn points and help others
