I have a Matag Centennial washer with ecoconserve automatic water level, my clothes do not come clean especially the whites. How can I increase the water level or any other solutions?
Bob Gemmell
  • 209 Answers
SOURCE: Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Posted on Sep 28, 2007
hotuna
  • 288 Answers
SOURCE: washer noy spining water out.....
I think that during all the rocking the lid switch has come off or broken. If you lift the lid look in the recess where the lid goes on top. There will be a small slot, if you press down on this slot with a screwdriver or something, it should make a clicking noise. Also check the lid and there should be a short prong that presses down this switch when the lid is shut. If the prong is missing or there is no clicking noise when pressed. The little clip that holds the switch has come off. This is a safety switch that protects people from the spin cycle when the lid is opened. If you are capable, remove the top panel on the washer, locate the bracket and switch. This is a small rectangular part with a button on the middle, with 1 wire attached to each end. Unplug the power, remove these 2 wires from the switch and connect them together. make sure everything is safe and plug the cord back in, turn the timer control to spin. If it spins, that it. Also, if it has an anti out of balance switch that is not working, you need to locate that too, while you have this apart. Check the literature that came with the washer to be sure it has this feature. Locate it on the machine and just replace it. Testing it may be hard to confirm. You will need a meter and may be some type of mercury switch inside. Did leveling the feet help the shaking?
Posted on Dec 28, 2007
huuum
  • 750 Answers
SOURCE: Clothes are not clean How can I take washer aprt to clean soap dispenser???
Dear carolesergy,
Welcome to fixya
You sad,My clothes get dingier ever week from using my washer especially the towels. They are now Grey and not white
1.Here are some ideas and INFO!
2.How old is your MAH5500B washer and did you buy it new?
3.Do you use HE High Efficient detergent?
4.Do you ONLY put the proper amount of detergent directed to be used by the manufacturer?
5.Using to much detergent will degrade the seal and eventually destroy the bearings.
Which will cause oil to leak out on your clothes and sometimes make gray stains on them !
6.Is there tiny gray oily pieces in the wash and on clothes?
7.Look closely at your rubber seal around the opening. Is this worn or deteriorating away slowly due to bleach or detergent? Is it a gray or black rubber?
Please have patients and bear with me, with all these questions I propose to you here!
I am searching with your eyes for things I have seen in the past about this model"
Here are some reasons this may also happen!
How large of a load can I wash in my Maytag Neptune washer?
* The tub can be loaded completely full with dry, unfolded clothes. However, do not pack the tub tightly. If the load is heavily
soiled it is very important not to overload the washer.
My whites are not as white as I’d like.What can I do?
* Wash white loads using the cotton/sturdy fabric selection. Select the hot wash/cold rinse temperature setting and put 3/4
cup of chlorine bleach in the bleach dispenser. The bleach will be dispensed in the final minutes of the wash providing for
optimal whitening. Maytag recommends a hot water wash temperature of 120-140° F (49°- 60° C).
Also:
*The lint filter in side the machine may be clogging with dirty lint!
*Which means you needed service!
I hope one of these solutions is the reason!
Let me know how you do!
Huuum
Please remember to leave a rating for me!
Posted on Oct 10, 2008
hiltonjug
  • 612 Answers
SOURCE: Washer wont fill with water/clothes dont get clean
Actually the machine is working like it is designed. When the correct soap is used, these machines clean clothes better than the old style. Try using a major brand of soap like Tide, Bold, or Cheer. Make sure it has the HE design on the bottle. This means that it is made just for the new High Efficiency machines. Also make sure you don't use to much. Read the directions. If this is done correctly, I'm sure you will find that it does clean great. I was like you when I first saw one of these new machines. "These is no way you can clean dirty and I mean dirty clothes without enough water to cover them. Well since, I have became a believer. They have put a lot of thought into designing these things. They had to of, for them to clean as good as they do.
Please rate solution
Posted on Aug 28, 2009
rickead1
  • 1998 Answers
SOURCE: Grey spots on our white clothes after wash
do you use affresh to clean your front loader? deposits of soap and other such things can be stuck around the inside tub of your washer. try this porduct out it works great on all front loaders use hot water with the affresh pellet with no clothes and run the machine through a cycle this also helps with any stagnant water smells also have you cleaned out your pump lately. * note remeber to put the pellet on the inside of the machine not in the soap dispenser
Posted on Apr 29, 2010
Can you adjust the water level if you want more water for your wash cycle?
it may be possible if the water level pressure sensor has an adjustment for the pressure setting
or you could simply select full wash each time
Jan 07, 2016 | Maytag Centennial EcoConserve Top Load...
Some white spots on clothes at the end of wash cycle?
Not sure if you use bleach but you could have bleach spots if you do.
Mar 18, 2015 | Maytag Centennial EcoConserve Top Load...
Maytag centennial washer
Hello there and welcome to fixya
Here is the specifications on this washer
and this should explain why it dosent take much water to get clothes clean
This high-efficiency Centennial Top Load Washer features the IntelliFill automatic water level sensor and 11 automatic wash cycles to give you plenty of options. Low Water Wash with EcoConserve helps you save energy, while its spacious capacity means plenty of room for your largest loads. Inside, the stainless steel wash basket resists chips, scratches, and odors, as well as maintaining a smooth surface so it won't snag or pill fabrics. You get all that and still use 70 percent less water and energy in a model that pays for itself in four years. This no-nonsense machine does what you want.
  • CLICK HERE to learn more about Maytag Appliances
  • 3.6 cu. ft. capacity easily handles large loads and bulky items such as comforters
  • Rear panel controls provide convenient access to all cycle and option selections
  • IntelliClean impeller continuously moves clothes through the water for a thorough cleaning
  • 11 automatic wash cycles including heavy duty, casual, bulky and delicate to provide washing options to handle a variety of fabrics
  • ENERGY STAR qualified with a CEE Tier III rating: this washer is among the most efficient washers in the industry
  • Stainless steel wash basket resists chips and scratches and helps to protect fabrics from snags and pilling
  • Automatic Temperature Control monitors and adjusts incoming water flow to maintain the selected temperature for more consistent cleaning results
  • Low water wash with EcoConserve: use less water and get better cleaning performance through concentrated wash action, Low Water Wash technology enables the detergent to penetrate better and pre-treat soils with a concentrated mix
  • The IntelliFill sensor regulates the amount of water being used, making automatic adjustments based on the size of the load and type of fabric
  • MaxExtract Extended Spin option accelerates the load's final spin to remove moisture and reduce drying time
  • Deep Clean option uses a additional cleaning action and a deep rinse to ensure load is clean the first time
  • Click Here for details on the services included with Delivery & Basic Hook-up and Installation options for Major Appliances
  • MFG Model # : MVWC400XW
  • MFG Part # : MVWC400XW
May 25, 2013 | Maytag Centennial 7.0 Cu. Ft. Super...
Maytag ecoconserve wont stop draining
something might block the drain valve that prevent it to fully close those cause the water to continue to drain...
Nov 18, 2012 | Maytag CentennialR EcoConserve Top Load...
Washer immediately goes into wash cycle when filling with water on initial start.At the end of the spin cycle ,washer dumps water back in to drum.Also,it's not getting the detergent out of clothes. Maytag...
The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
Jan 26, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
Can i adjust the water level on my Duet?
Sorry there is no way to adjust the water level. the washer decides how much water by how much clothes are in the washer .
Jan 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
