Question about Garden
Lesco sprayer copper wand replacement
I need to purchase the entire copper wand replacement except for rubber hose that goes with Lesco Model 003075-2 gallon sprayer. Can you tell me where I can order this part?
SOURCE: instructions for using ortho tree sprayette
The Ortho Tree and Shrub Sprayette has a fixed mixing jet set to a 24:1 ratio. 5.3 ounces of spray concentrate in the jar will mix to produce 1 gallon of diluted spray. The jar has a capacity of 42.7 ounces, so you can spray up to 8 gallons with 1 filling. If you look at the side of the jar, you will see two filling scales. On the left is the diluted spray capacity, and on the right is the concentrate scale. So you will see 8 gallons opposite 32 ounces, for instance.
You must dilute concentrates to the 24:1 mixing concentration. So if your concentrate says 1 ounce/gallon, and you want to spray 6 gallons, put in 6 ounces and add water to the jar to the 32 ounce level.
Posted on Jun 25, 2009
  • 3 Answers
SOURCE: I have the 2 gallon sprayer the tip of the spray
generic parts can be purchased from Home Depot or Lowes. I do it all the time. Might have to modify and "make them fit" but usuallt it isn't too tough. Or, just keep an eye out this time of year for people throwing defective sprayers away. Might be able to use parst from their sprayer to fix yours.
Posted on Apr 27, 2010
  • 3 Answers
SOURCE: I have a solo 425 sprayer. When I attempt to pump
I think you need to remove the pressure cylinder. I've had the same problem with my 425 and there is a screen on the cylinder that must be cleaned. To remove the cylinder, do all the disassembly in the owners manual. Then get a short piece of 2x4 or 2x2. Place the end of the 2x4 on the pressure cylinder through the top of the tank. Give it a good whack with the hammer. It may take more than one good whack to free it, but it will come loose. Then inspect/clean the screen. You are going to have to use some force to get it back in. Turn the sprayer upside down, insert the pressure cylinder, lay the 2x4 across the bottom of the pressure cylinder and use even force to tap it back in. Stop when you get to the O ring collar and do the rest by hand being careful not to pinch the O ring. It may help to lube the O ring with vaseline.
Posted on Jun 28, 2010
  • 65 Answers
SOURCE: I need a replacement wand
You can contact the Fountainhead group at 800-311-9903 or visit their website at http://www.thefountainheadgroup.com for replacement parts for your tank sprayer.
Hilary @ Scotts
Posted on Jun 09, 2011
  • 961 Answers
SOURCE: I have the follwoing R.L.Flowmaster products: R.L.
They sell the sprayers and parts at Home Depot, Walmart and other places. I am providing a link for you to look at:
http://www.rlflomaster.com/wherebuy.htm
You can click on the store logos and pick out what you want and, they have an 800 number to check stock.
Posted on Jun 12, 2011
My sprayer is new, but does not keep the pressure, any idea's? It's a 2 gal, pump up type sprayer.
Check under the lid/cover for a rubber gasket. This may have gotten unseated when putting the sprayer top on. It must form a tight seal around the lip of the sprayer top in order to keep the pressure. Alternative: Put water in the sprayer leaving some air on top to build pressure. Put a few drops of dish soap inside and gently stir. Put the cover on, and tilt the sprayer to coat all areas at the top. Start pumping and see where the bubbles come out---there is your leak. If it is near where the sprayer hose enters, and it is a permanent mount, you may have a bad seal. If the sprayer hose unscrews, you may need a new rubber washer inside. If bubbles come out of the wand, or other plastic seams, you may have a crack in the plastic. Depending on the location, you could epoxy over the crack to seal it permanently. Good luck.
Aug 11, 2011 | Roundup 2 Gallon Pro Garden Poly Tank Pump...
When I attatch it to any hose the water spays out around the connection to the hose.
It should have a rubber washer,just like a garden hose.I would take the wand to a local hard ware store and just get a new washer that fits it.
May 13, 2011 | Aqua Cannon Adjustable Power Sprayer
I have a B&K kitchen faucet (LM#203120) in my 2005 Newmar motor home. The spray wand has recently broken. The spray wand is approximately 6.5 inchs long and is connected to the water line by means...
If you are talking about the standard spray nozzel with trigger type control than replacement sprayers are reaidily available. You should be able to unscrew flex hose from nozzel at the base of nozzel where sprayer goes into holder on sink.There should be ribbed section on sprayer where flex hose goes in. Grip that section and turn upper section of sprayer counterclockwise to remove. Most hardware stores will have replacement nozzels for under ten dollars. Hope this helps. Thanks
Nov 12, 2010 | B&K Plumbing
Leaking at valve handle for broadcast
This happens a lot. Sometimes it's just the hose connection to the wand. If that appears to be the leaking spot, remove the band clamp, take off the hose, and cut off the last 1" of the rubber hose so you get a fresh end. Push the freshly cut end onto the wand, and tighten the band clamp. Did that fix it? If not, you'll need to replace the wand, but they aren't too costly. You'll find some on this page . Good luck! Please rate my solution if helpful, thanks.
Jul 17, 2010 | Northstar ATV Spot Sprayer 26 Gallon, 2.2...
Looking to replace triger (leaks)
NorthStar brand equipment comes from Northern Tool. You can't replace the trigger, but they sell the replacement spray wand here and it's only $11.99. There are other wands, some longer, etc. They are pretty universal -- you just slide them onto the hose and tighten the band clamp. Good luck! If this is helpful, please rate my answer, thanks!
Jun 02, 2010 | Northstar ATV Tree Sprayer 16 Gallon, 1...
Need replacement part for 16-gal sprayer. It's the part that connects the hose to the gun -- hose end is broken off. What is this called and where can I get one?
The spray wand has a short plastic tube that the rubber hose slides over. Here's what it should look like, if it's not broken: 4bc420c.jpg
A 'band clamp' goes over the rubber hose to tighten it onto that little tube. If the band clamp is missing, you can get one at a hardware store - just find the size that fits over the rubber hose. If the rubber hose end is torn or cracked, just make a new clean cut with a knife.
But if the plastic tube has broken off the wand, you need to get a new wand. Good news - it's not expensive. This one's only 8 bucks.
Hope that helps you, if so please rate my solution, thanks and good luck!
Jun 02, 2010 | Northstar Garden
Pump is presurized but no spray
Most weed killers and fertilisers either crystalise or turn to gel when left unused. Pull sprayer wand to pieces and run hot water through the hose and wand, they especially clog up at the spray tip and at the on'off control.
May 14, 2010 | H.D. Hudson 1 Gal Poly Deck Sprayer
Sprayer valve is clogged
I've had some success by removeing the entire trigger mechanism and soaking it in solvent for a few hours.
Mar 23, 2010 | Rl Flomaster Acid-Resistant Sprayer...
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Garden Logo
105 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
