Question about Poulan Garden
Poulan Leaf Blower
I've had this leaf blower for 4 years and have not had any problems. 3 weeks ago it would not start, so I replaced the spark plug, cleaned the air filter and it ran with no problems. 2 weeks ago, I while in use, the motor started to stall out, I played with the gas and it ran ok for a minute or two before starting to stall again. I looked down and notice the muffler was cherry red (hot). After it cooled down I took the muffler off to see if it was clogged, but it looks ok. I've been using the same gas mixture since I bought it. Any suggestions?
  • 906 Answers
You may need to turn the Hi screw on the carb in 1/4 of a turn. Make sure the gas and mix are fresh.
Posted on Jan 25, 2015
3 Suggested Answers
  • 640 Answers
SOURCE: Poulan model: PPB430VS leaf blower. Won't start.
I think that those are suppose to be caps over the screw to discourage inadvertant tinkering with it. That way it is a deliberate act to get to them, if it is what I think it is.
Posted on Aug 09, 2011
  • 2239 Answers
SOURCE: I have a Craftsman 794774 leaf blower/vac w/25cc engine that won't start.
Many of these small blowers have an alloy key moulded into the flywheel, if this has sheared it will knock the ignition timing out, and will never run.
Posted on Feb 24, 2013
I have a blower/vac made by McCulloch that won't start! I tore the carb apart & cleaned it! Got it started but w n rev up! Turned I&H screws all t w in & bk out now won't start! help!
McCulloch 2 cycle leaf blower vac - YouTube
? 3:40
https://www.youtube.com/watch?v=skwugvObHtU
Dec 1, 2013 - Uploaded by Alan Marshall
McCulloch 2 cycle leaf blower vac. ... Your brand new leaf blower won't start? Try this ... starting contest echo pb251 vsmcculloch leaf blower.
cold start of my mcculloch leaf blower. - YouTube
? 4:24
https://www.youtube.com/watch?v=MgfmIezh65c
Mar 13, 2010 - Uploaded by keepin'itcountry
cold start of my mcculloch leaf blower. ... Your brand new leaf blower won't start? ... starting contest echo pb251 vs mcculloch leaf blower.
McCulloch won t start Leaf Blowers Questions & Answers ...
www.fixya.com > Forum > Tags > won t start > Leaf Blowers
McCulloch leaf blowers won t start related questions and answers. Ask your McCulloch questions. Get free help from leaf blower experts.
Nov 07, 2015 | McCulloch Garden
Poulan Leaf Blower red hot muffler
you need to turn the Hi screw on the carb in 1/4 of a turn.
Jul 22, 2013 | Poulan Garden
Feb 23, 2013 | Garden
Is anyone having a problem with the rubber spacers that keep breaking? We have had to replace 6 in one year and now two more broke.
This is a very common problem. I recommend calling the manufacturer and dealing with them directly. I can't begin to tell you how many of these I've sold.
Aug 30, 2011 | Poulan 30cc 2cycle Backpack Blower
POULAN FEATHERLITE LEAF BLOWER WILL ONLY RUN AT 1/2 CHOKE
Sounds like you will need to clean your carburetor, or rebuild it. Could be some debris in the jets of the carburetor. If the blower is over a couple years old, then I also recommend that you buy and install a new carburetor repair kit, because the diaphragm will get hard and that will cause it to be hard to crank and not run at full speed. Hint: When you clean your carburetor and remove the jet screws, count the number of turns it takes to seat the jets from their original position. That way when you go to put the jets back in, you know how many turns they were in/out. Please rate me, Thanks Good Luck, I hope this helped
Jan 05, 2010 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Poulan leaf blower won't start
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Sep 26, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Poulan pro leaf blower doesn't start
As long as it has fire, all you need to do is:
Check the fuel lines for cracks/breaks. If this is o.k., then you will need to disassemble the carburetor and spray with carb. cleaner. Use a Den Tek Brush,
(http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Make sure the small screen in carb. is free of debris.
If you still have trouble after this, then you will need to buy a carb. kit and replace all appropriate parts.
Jim
Jun 06, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Garden Logo
154 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
