Question about Blenders
Kitchen aid kgsc308lsso
Bake button and the 1, 2, and 3 buttons don't work.
    New Friend:
It is a ninja blender cannot get the lid off
Posted on Jul 22, 2013
Blender won't start
Test motor for continuity, if open circuit locate thermal fuse in windings and replace it. If not open circuit check cable for continuity, if that is ok you are likely looking at a new button control assembly.
Mar 12, 2014 | KitchenAid Kitchen Aid KSB560 5 Speed...
Why the lights on my kitchen aid baking not coming on
Check for loose connections from mains cable to PCB and from PCB to motor. Check motor for circuit continuity, it may need a new motor, it is rarely the PCB.
Jul 26, 2013 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Why wont my kitchenaid foodprocessor start?
Take the bowl off, turn it on in the centre at the front where the base of the handle would normally be there is a light coloured button/plastic piece. Push it in with a matchstick. If the motor now starts then you have a problem with the safety switching mechanism in either the bowl or the lid. It is more often the lid. The only solution is to replace the faulty part. Easiest is go to a service agent and buy whichever part solves the problem.
Feb 26, 2013 | KitchenAid Kitchen Aid KFP715OB - Food...
Food processor won't turn off
Probably going to require a new 3 button switch panel, they are not hard to fit.
Feb 17, 2013 | KitchenAid Kitchen Aid KFPW760WH - 12 Cup...
My wave maker blender from Hamilton beach doesn't work... What do i do? I bought it a few weeks ago and have used it about a dozen times now. I saw a solution saying the GFI button has to be checked....
the GFI is the receptacle in your kitchen, not on the unit itself,, the reset is the small red button in the middle of the receptacle ( sometimes gray) you just push that in to reset it,, newer homes have these in restrooms and kitchens for safety issues , however, back to your problem, try plugging the unit in to a receptacle without a GFI ,, if it works, its due to the high amps needed to start your blender and it trips the circuit. if it doesn't work,, Just take it back where you bought it , so you don't void any warranty on the unit and just get another one
Jul 03, 2011 | Blenders
When I turn my blender on, it runs for only a few seconds, then stops and all the lights on the panel flash on and off.
More often than not it will need the motor to be replaced, only Kitchen Aid parts will do, motors are usually unique to brands and models. Sometimes it can be the control/button panel but normally the motor.
Mar 21, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Kitchenaid Blender Classic
Same thing happened to me. Opened it up and along the red wire to the motor is a bass fuse. Went to the hardware store and then I replaced it. Works fine.
Apr 12, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Kitchen Aid blender
to see if its the Triac or just the off button perform this: connect the blender,while pressing the off button press the on button; if the blender stays on and you dont hear the relay function (Light ticky sound) maybe the off button get a broken solder point. But if the relay is functioning and there is no way to change the speed the problen is the TRIAC. This is a small piece on PCB with a heat sink
Aug 30, 2008 | KitchenAid KSB3 Classic Work Top Blender
Blenders Logo
50 people viewed this question
Top Blenders Experts
eyecam
Ross Keen
Are you a Blender Expert? Answer questions, earn points and help others
