Question about Sony UP-25MD
OPERATING manuals WANNA PRINT 2IMAGES AND 4IMAGES WITH SONY UP25MD AND SONY UPD25MD PRINTER.. WHAT WILL BE THE SETTINGS FOR THE SAME.. CAN ANYONE PROVDE ME WITH THE OPERATING MANUAL AT EARLIEST...
    New Friend:
  • 30 Answers
1-800-538-7550
Posted on Mar 03, 2015
    New Friend:
    Problem Solver:
  • 8 Answers
Operating system service pack 3
Posted on Jul 22, 2013
I have a lexmark x6570 printer it will not print on both sides of the paper anymore it use to print on one side then pull the paper back in as use the other side
Please follow steps below on how to print 2-sided on your printer:
Printing on both sides of the paper (duplexing) automatically:
  1. Press printmastert_76.jpg.
  2. With a document open, click File > Print.
  3. Click Properties, Preferences, Options, or Setup.
  4. Click the Print Layout tab
  5. From the Duplexing area, select Use Printer Settings from the drop-down box.
  6. Make sure the printmastert_77.jpg light is on.
  7. Click OK to close any printer software dialogs that are open.
Printing on both sides of the paper (duplexing) manually:
  1. With a document open, click File > Print.
  2. Click Properties, Preferences, Options or Setup.
  3. Click the Print Layout tab.
  4. From the Duplexing area, select Manual from the drop-down box.
  5. Select the Print manual duplex instructions check box.
  6. Press Start.
  7. The printer prints the odd-numbered pages and the instruction sheet, which describes how to flip and reload the paper.
  8. Following the instruction sheet, flip and reload the paper with the printed side facing away from you.
  9. The printer then prints the even-numbered pages on the reverse sides of the odd-numbered pages, completing the two-sided sheets.
Note:
  • printmastert_78.jpg button is not functional with a Macintosh operating system. You can print two-sided documents with a Macintosh operating system by using the settings in the Two-Sided menu of the Print dialog.
  • Automatic two-sided printing (duplexing) works only with plain paper in letter and A4 sizes. If you want to print two-sided documents on another size or type of paper, use the manual duplexing method.
  • To return to single-sided printing, make sure the printmastert_79.jpg light is not on.
Aug 31, 2011 | Lexmark X6570 InkJet Printer
I have a HPC7280 all in one. it is asking to insert a memory card for copies. why? how do i get around that.
It sounds to me like you have selected an option to print directly from a memory card at one time. Here are excerpts from the user manual for your machine to change printer settings:
Change the print settings
You can customize the print settings of the HP All-in-One to handle nearly any print
task.
Windows users
Before you change print settings, you should decide if you want to change the settings
for the current print job only, or if you want to make the settings the defaults for all
future print jobs. How you display print settings depends on whether or not you want
to apply the change to all future print jobs or just to the current print job.
To change the print settings for all future jobs
1. In the HP Director, click Settings, point to Print Settings, and then click Printer
Settings.
2. Make changes to the print settings, and click OK.
To change the print settings for the current job
1. On the File menu in your software application, click Print.
2. Make sure the HP All-in-One is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Make changes to the print settings, and click OK.
5. Click Print or OK in the Print dialog box to print the job.
I believe that this should help you get around your issue. Here is a link to the entire user manual for future reference.
http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf
Dec 22, 2010 | HP PSC 1610 All-In-One InkJet Printer
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Epson ACULASER CX11NF paper Jam error every time I print
you may wanna check if the paper that your using is a laser paper, check the mp tray, reload the paper and check the settings on your computer using thicker needs to match the setting on your driver you may also wanna check if your printer can do a stand alone copy so that we can identify if this a hardware issue or a driver issue.
hope this will help u
May 10, 2010 | Epson ACULASER CX11NF All-In-One Printer
Vista 64 cannot print using USR5461 print server
sir chuck, try NETWORK MAGIC it can fix your problem from PRINTER & file sharing and others. It fix network problems regardless of Operating System , windows, linux, mac etc.
May 04, 2009 | U.S. Robotics USRobotics USR5461 Wireless...
I have a Hp Laserjet p1505 printer. I installed and configured a StarTech USB wireless Print Server. Everything seems fine. The printer shows on the print server config page and it seems working, but when...
Using the Settings Feature on your operating system; you need to make certain the printer is listed and it the main printer to send data to. Check all settings and make certain, if using a wireless connection that the wireless settings are managed correctly. Generally, this is covered in the printer manual. For best results, get the FREE updates, and diagnostic programs from HP.COM.
Feb 09, 2018 | StarTech.com Computers & Internet
Brother MFC 8440 Automatic Feed Malfunction
you need to reset it from the printer setup menu
Nov 05, 2008 | Brother MFC-8440 All-In-One Laser Printer
Manual required C4280
Hi Go to www.hp.com enter model number into search box, follow links through to manuals, check its the one you require, if so download
Nov 03, 2008 | HP Photosmart C4280 Aio Printer
Sony Printer DPP-fp90
You may use your memory stick option to print. I means you shall copy your pictures to a memory stick card. Insert in into the printer. And print directly without your MAC. I use Sony DPP-FP70. It works.
Nov 01, 2008 | Sony Picture Station DPP-FP70 4x6 Photo...
Can't color balance 2605
well, the density is actually a combination of two aspects. The original document settings, especially in color transforms. Usually, the software will have a transform specific for the printer. In my experiences, trying to tweak the printer for each print job, can cause extreme frustration. Check the software manual for settings for your printer, and perhaps you'll get closer to this solution.
Got backup?
Feb 07, 2008 | HP Color LaserJet 2600n Printer
Sony UP-25MD Logo
143 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
