Question about Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1
Scott 17/42 riding mower. Briggs 17 hp engine.
Have a Scott 17/42 riding mower. Briggs 17 hp engine. (Model 311777 type 0143-E1 Code 990120ZE) When I start the engine it will miss and sometimes backfire thru the carb. at high rpm (mowing speed) I can feel a miss. Pulls good and cuts good. I have opened the carberator and all is clean inside. This has me puzzled any help is appriciated.
rockitman187
  • 2559 Answers
SOURCE: Honda IZY engine hunts. I mean the speed pulses rhythmically!
Just adjust the idle speed control/Fuel air screw located pointing downward on the bowl of the carb,Just start the engine,idle up high and turn the screw until it levels out and runs smooth.
Posted on Jun 03, 2009
carlsbiz
  • 1124 Answers
SOURCE: My Sears riding mower chokes itself out after warmed up,
Careful with the high octane.. That can burn a hole in the piston..
It might be fludding.. At the bottom of the carb should be a bowl.. One bolt at the bottom.. Take it off and clean it.. Spray some carb cleaner up in there where the float is..
If that dont do it --
Maybe the float is bad & taking in fluid..
If it has sat for long piriods of time - the carb might need to be cleaned & rebuilt..
When gass sits in there for a long time it shalacks and wont work correctly..
Pop off the carb & take to your local small eng shop. Shouldnt cost to much..
Posted on Jul 09, 2009
  • 10 Answers
SOURCE: 20 hp briggs and stratton revs up and down
the govenor gear shaft at the cam gear has come lose in the block. the only fix is a new block , short block or engine
Posted on Jul 24, 2009
  • 3 Answers
SOURCE: Describe your Briggs & Stratton
check fuel flow from the tank out of the fuel fuel pipe allso check the float level sounds like its running out of fuel then its needing fuel .at idle it can get some fuel but at fast no fuel try that mate
Posted on Sep 02, 2009
bargainbin2
  • 123 Answers
SOURCE: Engine seems to flood out when increasing speed and dies
If it starts lightly smoking black smoke at high RPM it is flooding or getting too much fuel. The float is leaking you may have not set the float height correctly when you put that carb back together. Or the needle and set could be bad.
Posted on Sep 12, 2009
How do i fix my engine smokes oil when i start it up
perhaps a complete motor overhaul . oil rings may be broke .
Oct 06, 2016 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
I have a 19.5 briggs and stratton engine on a craftsman model #917.270910. The starter turns engine then the engine hangs up not turning completely. briggs ans stratton mod#461707 type#0145 E1 code #
The decompressor is a valve lifter usually on the exhaust valve, the only adjustment is to correctly set the the valve clearances, if they are too slack the lifter will not activate.
Apr 21, 2013 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Need to know the weight of the motor oil
sae 30 in winter sae 40 in summer i preffer rotela
Aug 20, 2012 | Briggs & Stratton Briggs Stratton Intek V...
My Briggs and Stratton powered (17.5hp Intek model 311777) Troy Bilt riding mower idled down slowly and died. It was a very hot day after about an hour of mowing. I don't appear to be getting an
Hi, armature is for spark and you stator is only for charging the battery. Check for spark again after disconnecting the single small wire from the armature incase its a safety switch issue, regards Phil.
Jun 06, 2012 | Garden
Does a briggs 18 hp twin 2 have a oil filter its a late 90's model mtd riding mower
Most likely yes. It will look like a car oil filter. It looks like a round can that is screwed to the engine.
Mar 17, 2011 | Briggs & Stratton Briggs Stratton Intek V...
20.0 HP 502CC B&S engine, riding mower - stopped going full speed, black smoke from muffler, "misses" ALOT - model number looks like a backwards E followed by 1P977
Carb flooded or extremely out of adjustment and or completely malfunctioning.
Disassemble carb and inspect Float and needle valve.
Hope this provided some ideas for your repair.
r/
David
Jan 13, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Briggs & Stratton Briggs Stratton Intek V - Twin Vertical Ohv Engine with Electric Start 22 Hp, 1" X 3 5/32" Shaft, ModelNo. 44K777 - 0027 - E1 Logo
54 people viewed this question
Top Briggs & Stratton Measuring Tools & Sensors Experts
Bill Boyd
Richard Warren
Richard Warren
Mike Squire
Are you a Briggs & Stratton Measuring Tool and Sensor Expert? Answer questions, earn points and help others
