Question about ASUS Computers & Internet
Computer doesn t detect
Can't detect tmp
    Champion:
  • 241 Answers
If ur telling about tmp extension file then
tmp file is actually temporary file that is generated after opening file.
so u should used open with like word, pdf etc depends upon lind of file
Posted on Jul 23, 2013
Hard disk is not detecting
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Nov 08, 2012 | Computers & Internet
NR serise wont detect hdd in bios
Nov 04, 2012 | Sony VAIO NR Notebook VGNNR460ES
Can't detect TMP device
hold the delete key down when you power up or press it repeatedly until bios appears...pressing once often isn't enough.
Oct 15, 2012 | ASUS M2N68AM Plus Motherboard
DELL 300M
Easy Way --- Note that this doesn't always work.
When you are booting your system, press the F8 key during the start of the bootup sequence, meaning after it does the Power On Self Test.
Once you press the F8 key, you will be taken to a Menu. Select "Boot Using Last Known Good Configuration".
It will now attempt to load Windows XP using a past set of configuration files.
If that doesn't work, there is the next step....the hard way.
Hard Way
Boot your system with the Windows XP Install CD, let the system boot into the Setup. Once in the Setup, choose to run the Recovery Console.
You will now be presented with a screen similar to good old DOS.
First, we will recover the System Hive.
Now, type in the following commands with pressing Enter after each line.
md tmp
copy C:\windows\system32\config\system C:\windows\tmp\system.bak
delete C:\windows\system32\config\system
copy C:\windows\repair\system C:\windows\system32\config\system
Be very careful when you are typing in these commands, one wrong move, and you have, broken Windows XP.
Also, change the C in the commands to whatever your Windows XP drive letter is.
Attempt to boot the system, if it doesn't boot, get back into the Recovery Console and do the following commands.
md tmp
copy C:\windows\system32\config\software C:\windows\tmp\software.bak
delete C:\windows\system32\config\software
copy C:\windows\repair\software C:\windows\system32\config\software
Sep 08, 2012 | Dell Inspiron 300M Notebook
My computer shows the message unmountable_boot_volume and doesn't start properly how can i fix it?
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.
Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Jul 12, 2012 | Acer Aspire 5551 Notebook
Setup has detected that the file 'C:\DOCUME~1\Jennifer\LOCALS~1\Temp\VSD335.tmp\SQL Server Compact Edition\SSCERuntime-ENU.msi' has changed since it was initially published.
Hi Remove you Temp file and installation again, now you did not get this error.
How to Remove Temp file
1) Go to Run and Type %temp% and press enter
2) Temp window will open select all and press the delete
Thanks
May 24, 2012 | NEAT Receipts Mobile Scanner
Computer doesn't detect my webcam at all
type of computer most any compiuter u may access the start menu divices and printers and make sure u can find your cam there if not try reinstalling it
Mar 27, 2012 | Logitech Webcam
Toshiba l450 h.d.d unable to detect from bios
First - re-seat the harddisk and reboot the computer. If the computer does not boot up then reboot andgo into the BIOS configuration to see if the BIOS detects the hard drive. If itdoesn't detect the hard drive then it could be faulty.Then the hard drive needsto be replaced in the computer/laptop, Windows installed and the computer orlaptop's device drivers plus your programs etc. to get a functioningcomputer/laptop again.
Mar 23, 2012 | Toshiba Computers & Internet
Problems installing Neat Receipts
You need to install Microsoft SQL Server Compact 3.5 Service Pack 2 from MS web site:
http://www.microsoft.com/en-us/download/details.aspx?id=5783
Steps:
1. Download installation package from above link and save them to the desktop or other folder
2. Start that .exe and unpack to some folder on your PC (or that same folder)3. Open that folder and run BOTH installations for Windoxs x64 PC - first start:
SSCERuntime_x86-ENU.msi and then
SSCERuntime_x64-ENU.msi
4. This would install necessary SW and then you could re-insert Neat CD to start the installation which would proceed now.
Mar 06, 2012 | NEAT Receipts Mobile Scanner
Money has detected that you did not close the file
Have you tried renaming the file and creating a new mbfB.tmp file? Have you tried looking in your process list to see if mbfB.tmp is mentioned. You may have to manually end that process. Do a search for the mbfB.tmp and right click it and find out the actual size. if it reaches 1 Giga-byte it may not close or open properly anymore.
Let me know if you need further assistance =)
Jun 08, 2009 | Microsoft Money 2007 Home & Business for...
Computers & Internet Logo
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
