Question about Epson WXGA 3LCD Projector EX7210
Flash drive can I use a flash drive with the projector
White pixels nec np100
Your DLP chip is damage or getting to been damage.
** To make it sure you can do it your self by getting some basic tools such as proper screw drive, and open your projector for parts.
And you can physically observe the Chip.
Please check by side angle on the chip surface. **
Feb 14, 2014 | Optoma DLP Projector Multimedia Projector
Optoma lamp led flashing
the are a few reasons for this but the most two common ones are the intermitant lamp failure or colour wheel tracking rotation sensor when you startup the projector the lamp should drive half brightness approx then you should hear the colour wheel drive if it is at this point the projector goes off and restarts the chances are it is dust on the colour wheel sensor.Rmove sensor this has three wires going to it supply and pulse wire it is mounted on a small pcb board with one screw remove the screw and board complete with sensor and clean the sensor with a cotton bud dipped in spirits then wipe over with clean cotton bud.This usually solves the problem.
john www.jvsvisual.com
Apr 17, 2013 | Optoma EP774 Projector
Can i play any video format directly on projector saved in USB Flash Drive???
not directly on to the projector. It dsoes just that...projects an image. you need a device or interface that will actually read and play the video. As for as video format there, the are a couple of apect ratio options available. I believe you are referring to the stored format of the video itself though. for that you can refer to my previous statement in this thread.
Jan 23, 2013 | NEC LT380 LCD Projector
The projector would not turn on and had a flashing red light for the lamp. Knowing it was an older projector when we rented the building I purchased a new bulb for this projector. When I put the new bulb...
PROBLEM :-The power supply of the projector is faulty there is a transistor witch is switch 15 volts for the lamp drive board.
SOLUTION: Remove the upper cover with 6 screws back side of the projector.
remove main board and lamp cover with 7 screws.(show in the picture)
remove upper cover of the power supply and lamp drive unit with 3 screws.
remove power supply unit with 4 screws and 3 connectors and put face down on the table.
now you find the transistor no Q107 and replace with the transistor no 2SB710 is and surface mounted compunent(show in the picture)
fix it all as you open.
power ON the projector and enjoy
(doing very carefully This is a technical job)
Feb 05, 2011 | Panasonic PT-LB10SVU Multimedia Projector
I have a problem with our projector. The model is: PT-D3500E and the serial number is: SH5530059. When you switch on the projector the power light goes green after 25 seconds the power light goes...
If the LAMP INDICATOR flashing red then.
Problem: Lamp circuit failure
Sulution: your two lamps are ok you need to repair the lamp drive circuit this is repairable and if you don't want to repair you buy a new one lamp circuit and install it.
Jan 19, 2011 | Panasonic PT-D3500U Multimedia Projector
Firmware flash Proxima X350
Make sure the projector is in flash more before connecting. (read flash instructions)
When it prompts for drivers show the uncompressed flasher program catalogue. It should find the drivers for 'Infocus Projector Flash'.
After this you can run the program and continue normal flashing procedure.
Good luck.
Jun 15, 2009 | InFocus Proxima UltraLight X350 Multimedia...
Viewsonic Projector PJ557D "Screen Flip"
Check the power settings o nthe laptop, go to control panel, power options. see if its set to turn off the screen if theres no activity. I doubt this is your problem but worth a try. Going back to the viewsonic picture means its not getting a signal. So either the cable may be faulty which is less likely, or it is a software problem. Does the screen flicker on the laptop when doing the same thing (if the projector is not connected)?
Jun 12, 2009 | ViewSonic Lenovo Viewsonic PJ557D Portable...
Projector with a flashdrive
Adapt projectors can do that, they are little nice jewels that can play multimedia files from USB stick or cameras with good professional quality.
You can find it at retail price of about $300.
Here the projector: Aiptek PJV11X PocketCinema V10 Portable
See also the guide below:
Adapt Pocket Projector Quick Guide.pdf
I will be grateful if you can rate my solution according.
Many thanks.
Feb 24, 2009 | Sanyo PLC XU30 Multimedia Projector
Using a Sanyo PLC WXU30 Multiverse Projector
should be able to download manual online, you cant just use a flash drive must be connected to laptop via vga cable, also I am not too sure about the mac, as i use a cheaper type laptop, but the display must be set for dual.
on windows this is done by right click, properties, advanced menu
Dec 16, 2008 | Sanyo PLC-WXU30 Projector
Epson WXGA 3LCD Projector EX7210 Logo
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
