Question about Cisco (WIC-1AM=) Modem
Cisco 2950 series
Hello, J ' have a switch 2950 and not boot normally, the led system is orange and it blinking Help me please
    Sergeant:
  • 457 Answers
Go here http://www.cisco.com/en/US/products/hw/switches/ps628/ They have a wide range of ideas about this product. More than likely built it.?
Posted on Sep 09, 2007
SOURCE:
I forgot a password and i cant access a catalyst 2960 24-port 10/10
You can only reset password this way:
1.
Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch.
Use the following terminal settings:
  • Bits per second (baud): 9600
  • Data bits: 8
  • Parity: None
  • Stop bits: 1
  • Flow Control: Xon/Xoff
2.Unplug the power cable.
3. Hold down the mode button located on the left side of the front panel, while you reconnect the power cable to the switch
4. Release the Mode button when the SYST LED blinks amber and then turns solid green. When you release the Mode button, the SYST LED blinks green.
5. switch: flash_init
6. switch: load_helper
7. switch: dir flash:
8. switch: rename flash:config.text flash:config.old
Rename config.text to config.old. In that file the password is stored.
9. switch: boot
10. Enter "n" at the prompt to abort the initial configuration dialog
11. Type en to enable
12. Switch#rename flash:config.old flash:config.text
13. Switch#copy flash:config.text system:running-config
14. Overwrite the current passwords:
conf term
enable secret <new pass>
enable password <new pass>
line vty 0 15
password <new pass>
login
line con 0
password <new pass>
15. write memory
16. copy run start
Sep 25, 2013 | Cisco Catalyst Computers & Internet
My computer can't boot at all after switching it of for some days now. the power led just blinks orange and that is it...please what do i do?
Replace the jumper back into it's original position. Remove the power cable & hold down the power button for 15 seconds to reset the board. replace the power cable & attempt to boot.
Jul 16, 2012 | Computers & Internet
I like to store some files in a switch is it possible to do so, if possible can anyone please help me with the procedure any suggestions are greatly appretiated and thankful for the suggestions. Thank you...
hello
modems,routers (switches,hubs) are all used for connecting a network together these are not used for storing files
just used in transfer of data , sorry
July
rate me please
Apr 08, 2009 | Cisco Catalyst 2950 24x10/100 Mbps...
Trunking problems
  1. u may need to check first internal network broad casting. if any system is giving too much packeting
  2. connectors of cables which is properly crimp
  3. quality of cable
  4. cable which is comes in ur premises through area junk box is properly connected.
  5. u may need to check load balancing of network from your authorised vendor
Apr 06, 2009 | Cisco Catalyst 2950SX-48-SI 48-Port...
I had forgotten the password of my Cisco Catalyst 3550 Switch
password recovery procedure 3550 catalyst cisco switch
1>Attach a terminal or PC with terminal emulation (for example, Hyper Terminal) to the console port of the switch. Use the following terminal settings: ¨ Bits per second (baud): 9600 ¨ Data bits: 8 ¨ Parity: None ¨ Stop bits: 1 2>Unplug the power cable. 3>Power the switch and bring it to the switch: prompt 4>Issue the flash_init command 5>Issue the load_helper command. switch: load_helper switch: 6>Issue the dir flash: command. Note: Make sure to type a colon ":" after the dir flash.
7>Type rename flash:config.text flash:config.old to rename the configuration file. 8>Issue the boot command to boot the system. switch: boot Loading "flash:c3500xl−c3h2s−mz.120−5.WC7.bin"...############################### ################################################################################ ###################################################################### 9>Enter "n" at the prompt to abort the initial configuration dialog. −−− System Configuration Dialog −−− At any point you may enter a question mark '?' for help. Use ctrl−c to abort configuration dialog at any prompt. Default settings are in square brackets '[]'. Continue with configuration dialog? [yes/no]: n !−−− Type "n" for no. Press RETURN to get started. !−−− Press Return or Enter. Switch> !−−− The Switch> prompt is displayed. 10>At the switch prompt, type en to enter enable mode. Switch>en Switch# 11>Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#Type rename flash:config.old flash:config.text to rename the configuration file with its original name. Switch#rename flash:config.old flash:config.text Destination filename [config.text] !−−− Press Return or Enter. Switch# 11. Copy the configuration file into memory. Switch#copy flash:config.text system:running−config Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded.
Destination filename [running−config]? !−−− Press Return or Enter. 1131 bytes copied in 0.760 secs Sw1# The configuration file is now reloaded. 12>Overwrite the current passwords that you do not know. Choose a strong password with at least one capital letter, one number, and one special character. Note: Overwrite the passwords which are necessary. You need not overwrite all of the mentioned passwords. Sw1# conf t !−−− To overwrite existing secret password Sw1(config)#enable secret <new_secret_password> 13>!−−− To overwrite existing enable password Sw1(config)#enable password <new_enable_password> !−−− To overwrite existing vty password Sw1(config)#line vty 0 15 Sw1(config−line)#password <new_vty_password> Sw1(config−line)#login !−−− To overwrite existing console password Sw1(config−line)#line con 0 Sw1(config−line)#password <new_console_password> Write the running configuration to the configuration file with the write memory command. Sw1#write memory Building configuration... [OK]
Mar 24, 2009 | Cisco Catalyst 3550-24 24-Port Ethernet...
CISCO 2600 Router Troubleshooting
This is the indicator configuration for the 2600, if the lights are yellow there is a problem.
The following indicator LEDs provide power, activity, and status information:
POWER (green)—Lit when power is on
RPS (green)
Off—No redundant power supply (RPS) is present
Blinking—System is booted, RPS is present, RPS failure
Continuous on—System is booted, RPS is present, no RPS failure
ACTIVITY (green)
Slow, steady blinking—System is booting
Blinks during system activity, such as interrupts and packet transfers
I suggest going to Cisco.com for full documentation on this product.
Feb 19, 2009 | Cisco RPS 22/18 (cab-rps-2218)
Cisoc 2950 with odd Problem
I recently had a client switch do this to me. The only way to get it working was to manually put the NIC on my laptop to 10 Mb and Half duplex. After calling Cisco and opening a TAC case, it was deemed faulty hardware.
If you have SmartNet (anyone buying Cisco should always buy SmartNet) on the switch, call TAC and open a case. It's probably faulty hardware.
Good Luck!
Feb 02, 2009 | Cisco Catalyst 2950 24x10/100 Mbps...
Switch 2950 24 ports with problems
yellow light on ports means the port is not working or was shutdown due to port security
Nov 20, 2008 | Cisco Catalyst 2950 24x10/100 Mbps...
Switch port
switch setting
int f0/1
speed 100
dup full
and lan card shuld be shud be more then 100mbps or 1gb
then it will conect to full duplex means
u have to to any device shud have same duplex
Aug 11, 2007 | Cisco Catalyst 2950 24x10/100 Mbps...
Cisco (WIC-1AM=) Modem Logo
293 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
