Question about Ricoh Aficio MP C4500 Copier with Print, Scan, Fax, Finisher
Richo c4500 error sc552
Error code sc552
My copier machine comes up with functional error code sc672. can anyone help
That error code appears to indicate 'Op panel to controller problem' see here http://multifunctionalcopier.blogspot.co.uk/2012/06/ricoh-error-code-list.html
Sep 05, 2015 | Ricoh Richo KR-5 with 35-70mm f3.5-4.5...
I have a copier ricoh aficio 2550 and presents me code SC552. As the unlocking?
I have a copier ricoh aficio120 and presents me code SC552. As the unlocking?
Feb 13, 2013 | Office Equipment & Supplies
What's your problem?error code SC552 on ricoh savin c4540
fusing thermistor error, clean, replace the thermistor
Oct 31, 2011 | Savin Office Equipment & Supplies
Operating problem for copier machine
SC552 is a fusing thermistor error. Thermistor is in the fuser section. This code is for the END thermistor. You can also try to just reset the code. Enter the SP mode (service program) by entering the following keys.
CLEAR MODES, 1 0 7 and hold the CLEAR STOP key down till the maintenance screen appears. Press COPY SP on the touch panel then turn OFF the MAIN POWER SWITCH then turn it back on and see if it clears. NOTE: The "MAIN POWER SWITCH" is of the left side of the machine, NOT the top right side.
Sep 14, 2009 | Gestetner DSm660 Copier
Function sc:552 problem RICOH AFICIO 2018d
To reset error, enter SP mode by pressing: Clear (yellow) button, 1 0 7, and press and hold the Stop (orange) button for 3 seconds then switch off and on the copier.
If the error is still there, please check the following in the fuser unit;
  • Check and clean or replace the possible defective thermistors or out of position.
  • Fusing heaters open circuit.
  • Thermostats for open circuit.
  • Power supply unit.
Good luck and please rate me, thanks.
Mar 02, 2009 | Ricoh Aficio AP3800C Laser Printer
Desperate!!! Ricoh AP3800C Error SC552 fixed last week now back
SC552 means that the pressure roller (Lower roller in the fusing unit located in the left hand door of the machine) is not warming up correctly. Is the copier installed somewhere cold? i.e. a garage? If conditions are ok and damp is not a problem, either the thermistor that controls the pressure temperature is defective, or the lamp that warms it up is defective. They are the two more common problems, might be worth looking for one on ebay. However they are approx 250 pounds so if you can find a second hand one thats cheap for spares I would recommend that. Email me if you have to do this and I will talk you through changing the parts.
Dec 23, 2008 | Ricoh Aficio AP3800C Laser Printer
Power problem code sc552 lanier
What is the error code? Many of the codes refer to a general electrical problem, and often turning the machine off, resetting the circuit board connectors and harnesses and memory sticks, and turning the machine back on will clear the error code and allow the machine to boot up normally.
Oct 27, 2008 | Lanier 1205 Copier
Solve my problum
I have a richo 2018d all in one copier machine it can be a error code SC541.
what is its solution ....
Sep 16, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Functional problem sc552
I take it this is for a Ricoh?
SC552 is a pressure roller warm up error. It didn't detect the right temperature when it was turned on.
Turn the copier off for 30 seconds and then turn it back on again. If the error message returns, a technician should look at the fuser section to see whats causing the problem.
Aug 01, 2008 | Office Equipment & Supplies
Ricoh Aficio MP C4500 Copier with Print, Scan, Fax, Finisher Logo
57 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
