Question about Vehicle Parts & Accessories
Burning odor after replacing blower motor resistor
2001 dodge dakota
    New Friend:
This is my own question and I wanted to share the solution in case others may have the same problem. I replaced the Interlock Module. Found the part at Sears for about $35. The part is right behind the seat on the right hand side if you are seated. There is a wiring harness coming through the rear wall - some of the wires go to this guy. Maybe this would have been answered if it had not been in the CD category?
Posted on Jul 22, 2013
2003 Dodge Dakota is stuck on defrost, only blowing hot air. A/C will not turn in, mirror defrost will not turn on. Just replaced blower motor resistor to fix fan not coming on. Fan is working.
Can you measure and VOLTAGE across the resistor?
Here is a GREAT Link (in my estimation):
How To Test The Blower Motor Resistor 2001 2004 Dakota Durango
Yes it's for a DURANGO but the process may help you!
Joe, have you seen THIS link?
2003 dodge dakota heater schematic Google Search
And THIS YOUTUBE?
Dodge Dakota Durango Blower Motor Resistor Wiring Diagram
Also there is this possibility:
burnt-gkhd23p0qwnavtoilob1hbhw-1-0.jpg That link is here (yes ~ again it's for a DURANGO, but the help may be here)!
Connector to blower resistor DodgeForum com
Anthony
Apr 17, 2018 | Dodge Cars & Trucks
A//c unit works only on high speed/
blower motor resistor...it cuts power to lower settings...easy fix usually under passenger side glovebox two screws and harness looks like a metal card with plastic bottom...
Jan 28, 2016 | 2004 Dodge Dakota
Where is the heater resistor on a 2005 dodge dakota? Behind glove box?
should be just above the blower motor. You will need to remove the glove box door to gain access.
I’m happy to assist further over the phone at https://www.6ya.com/expert/jeremy_d728a59f986299fa
Dec 12, 2015 | 2005 Dodge Dakota Club
2001 dodge dakota keeps burning up blower motor resistors and I have changed the blower motor would it be a bad ground and where do I look? Truck has a few other electrical problems
Check the alternator output voltage. It sounds like the voltage regulator is bad. A bad ground would not complete the circuit so no fan at all or a slow turning fan due to no or low voltage. A bad ground will not burn up the speed resistor
Nov 15, 2015 | Dodge Cars & Trucks
87 dodge dakota heater blower stopped workng
The blower resistor will burn and smell without blowing a fuse
Feb 04, 2010 | 1987 Dodge Dakota
Blower motor wont come on
Replace the blower resistor. The control head provides a ground circuit through the resistor block which reduces current flow to the blower motor which in turn gives you the different blower speeds.
Aug 29, 2009 | 2001 Dodge Durango
Blower motor resistor on '04 Dakota 4.7L V8. Second time this has happened, short out? Blower only works on lower levels, not on high.
Has the blower motor been replaced as well. If you put one resistor on, and it goes bad again, the motor is pulling too many amps and burning it up.
Jun 29, 2009 | 2004 Dodge Dakota
Fan switch works on only one speed
  1. Disconnect and isolate the battery negative cable.
  2. From the passenger foot well area, remove the two hex screws used to secure the blower motor resistor.
  3. Unplug the front blower motor resistor from the wire harness connector.
  4. Pull the front blower motor resistor and its wire harness out of the plenum panel and through the cowl plenum access hole far enough to access the wire harness connector.
  5. Remove the front blower motor resistor from the cowl plenum.
INSTALLATION
  1. Plug the blower motor resistor into the wire harness connector.
  2. Install the blower motor resistor to the cowl plenum panel by feeding the resistor and wire harness back through the cowl plenum access hole.
  3. Install and tighten the two screws that secure the resistor to the HVAC unit Tighten the screws to 2.2 Nm (20 in. lbs.) .
  4. Connect the battery negative cable
May 27, 2009 | 2001 Dodge Dakota
Heater won't turn on
replace your blower motor resistor its about 20 bucks and i could only find one at the dealer i had the same problem 4 months ago if that doesnt work your next option is the blower motor but im 90% sure its the resistor 04 dodges have alot of problems with that resistor burning out it is located on the passenger side beside the blower motor two bolts holding it in it will be a rectangle shaped piece of plastic just un clip it and clip the new 1 in
Mar 24, 2009 | 2004 Dodge Dakota
Heater blower switch broken
mine was doing the same, then just quit all together. I went and got a resistor and everything is working again. Pretty easy to replace as well.
Dec 29, 2008 | 2001 Dodge Dakota
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
