Where can I find a manual for a Carrier water source heat pump model 50HQ027310
2 Suggested Answers
  • 415 Answers
SOURCE: Carrier heat pump (basic model) runs at 0 or below
A basic model heat pump with an air handler with electric strip heat generally will continue to run with a call for heat regardless of the outdoor air temperature unless there was an outdoor thermostat (an accessory) installed. There is still heat in the outdoor even at temperatures of zero and below. Generally, there is a balance point of approx 30-35degF that allows the heat pump to heat your house to 68degF without the need for the electric heaters. Below that, the heat pump can still extract heat from outside and "pump" it into your house; however, it will need help from the electric heaters. In temperatures below the balance point, the heat pump will run non-stop. As the temperature in the house falls approx 1 - 2 degF below the setpoint, the electric heaters will energize. So it is not uncommon for the system to run non-stop with the temperature falling a few degrees below setpoint. The colder the outside temperature, the more often the strip heaters will cycle on/off. If your system is well-maintained and operating at proper performance, it is still cheaper to run your heat pump than it is to run on straight electric heat. If you live in a climate where below zero temperatures are normal during the winter months, you might want to research heat pump options that offer higher COP's and increased performance in colder temperature than the basic contractor's model. Start with initiating communication with a local contractor. You will need to consider initial cost and the pay-back period based on your local energy costs and your specific demands you want your system to meet.
Hope this helps!
Posted on Feb 14, 2010
My New A.O. Smith water heater is showing an ECC code what can I do
Hello, Frazell -
If your A. O. Smith water heater is new, it probably came with an owner's manual. Find where you put yours and check the manual to find out what the ECC code means.
From an owner's manual for a particular A. O. Smith Hybrid Heat Pump Water Heater, the code ECC means the heat pump compressor is not functioning.
Source:
https://www.manualslib.com/manual/755258/A-O-Smith-Hybrid-Electricheat-Pump-Water-Heater.html?page=17#manual
Best wishes.
Jan 19, 2018 | Water Water Heaters
Ptac unit wont cool
Check unit's ID#'s and add any hyphens, etc or separate letters, numbers, to be exactly what's on unit.
Inside sources might help. Popular Questions Answers Tips Manuals for Carrier 52CE215 Cool Electric...
Questions Answers for Carrier heating element
Feb 11, 2015 | Carrier 52CE215 Cool Electric Heat Air...
My ground source heat pump doesn't deliver the full power. (It is not a carrier model) I notice ice building up on the cold side of the refrigerant piping (heat exhanger inlet, liquid separator, until...
main reasons that cause ice on suction line
-low evap air flow
-low refrigerant
-low load
-liquid line restriction (possibly filter drier)
need a picture to further help
May 29, 2017 | Carrier New 5 Ton Ground Source Geothermal...
Auxiliary heat
Auxiliary heat is the heat pump. Nothing wrong if you're using a heat pump. That's how it works, unless the system has another primary heat source.
Nov 23, 2013 | Carrier Heating & Cooling
Carrier OEM to Honeywell Programmable Tstat - NEED HELP
you likely have a "two stage" system, but not a two stage heat pump. the first stage is probably the heat pump itself, and the second stage is the auxilliary resistance heat that suppliments the heat pump at lower temps. if i knew the terminals that are available on the new stat, i could advise you on the proper wiring.
Jan 27, 2013 | Carrier Heating & Cooling
No manual for a cool 438656
Recent Carrier Xhb123d Xy Series Heatcool Air Conditioner ...
domecrel.com/recent-carrier-xhb123d-xy-series-heatcool-air-conditioner/
Download Your Carrier Manual - Oge. Recent carrier xhb123d xy series heatcool air conditioner Heat ?^' enables the heating equipment to operate as needed.
Jan 05, 2012 | Carrier XHB123D X/Y Series Heat/Cool Air...
How serious is an e3 system error message on a carrier thermidastat control? the homeowner's manual says it means there is a problem with the outdoor temperature control reading.
Its more of a nusance. The temperature probe is not reading of has a broken wire. its two wires and reads the outdoor temperature. Its usually at the bottom of the electrical compartment or underneath the unit. Its a $20 part and you should be able to get it at heatcoolparts.com. It you have dual source system it tells the system when to switch from heat pump to the furnace. I believe you can jumper it out with a 10K ohm resistor to have the furnace run instead of the heat pump.
Jan 28, 2011 | Carrier XHC101D Air Conditioner
Hope this helps!
Feb 14, 2010 | Carrier 38CKC036 Air Conditioner
Pool and Spa Heaters pros and cons
An electric heat pump needs heat available to pump. If it is 30 degrees outside, heating a spa to 102 or so, may be impossible unless the heater has some type of alternative heat source. A properly sized, gas fired heater can take care of a larger range of heating needs. A combination heat pump and natural gas heater, probably with a controller, really makes the issue more difficult, expensive, and would require a lot of study for efficient, cost effective operation. Bottom line: In really mild climates a heat pump might do the job. In cooler climates the gas heater rules. And where a wide range of temperatures and high heat demand is wanted by the customer, a gas heater is the only way to go. A backup heat pump may take years to payout.
Aug 27, 2008 | Saunacore Special Edition Residential...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
