How do you reset your ac unit a6y12f2a-e - Heating & Cooling
What is the code for EE on display
EE is the thermistor is bad or pulled off at the terminals on the circuit board, more often it means it is defective and requires replacement.
Jun 06, 2014 | Fedders Y Chassis A6Y12F2A Air Conditioner
How do i add freon to my fredders service # a6y12f2a-a
Hello, wimdow air conditioners do not come with service acsess fittings, so you must add a piercing valve to the unit to add refrigerant.
Jul 16, 2012 | Fedders AEQ07FBG Air Conditioner
The menu no longer displays in-coming call history; the window no longer displays the name or phone number of the person calling in the moment. Sometimes when the phone rings all you hear are beeps. ...
I will advice you try reset the unit, once the unit is reset, the problem should be fix. Follow this steps to reset the unit,
Turn off the phone, remove the AC adapter, press and hold the page/call button that is on the phone and plug back your Ac adapter, this will fix the problem.
Take care.
Sep 22, 2010 | Panasonic Lands Phones
AC unit LWHD 1800R won't turn on & test/reset does not respond.
Reverse the wires in the receptacle ,not the ground,this is most likely the problem the way the circuit is set up in the ac unit.Let me know if this helps.
Jul 05, 2010 | LG LWHD1500ER Wall/Window Air Conditioner
Where to connect three wires
You should have:
one wire from the compressor that will hook to "HERM".
one wire from the fan motor that will hook to "FAN"
one wire from the relay ("hot" wire") will hook to "C".
Apr 14, 2010 | Fedders Y Chassis A6Y12F2A Air Conditioner
RUUD Acheivers Series AC unit
The reset is two pins on the defrost board. Put a flat scredriver across them to reset the board.
Aug 15, 2009 | Ruud UBHC Air Conditioner
Reset base unit of Uniden TRU9485
Uniden TRU9485 (This didn’t work for me but this was the first instruction from Uniden Tech Support)
TO RESET THE BASE UNIT:
Unplug the base unit AC adapter.
Hold down for 15 seconds the DND, * and “menu” soft key (the middle silver soft key under the LCD) while plugging the base unit AC adapter back in.
All the settings should be reset.
Uniden TRU9485 (Worked for me)
ALTERNATE WAY TO RESET THE BASE UNIT:
Hold down for 15 seconds the DELETE KEY (zero with a line through it) while plugging base unit AC adapter back in.
May 28, 2009 | Uniden Lands Phones
Cannot engage RESET Button on plug to power the 220v AC unit
The reset button is a voltage leak detector it is possible the unit has a short in it or the cord has a short
Apr 28, 2009 | Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
