Question about Dishwashers
Whirlpool quiet partner iii pots & PANS LIGHT flashing
    Top Expert:
  • Dishwashers Master
  • 12,223 Answers
Test the steps and fix it. God bless you
Heating Element
If lights are flashing on the control panel, the heating element might have burned out. The heating element heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element can be checked for continuity with an Ohm meter.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Heating Element Assembly
If lights are flashing on the control panel, the heating element assembly might have burned out. The heating element assembly heats the water up to operating temperature. After a set amount of time if the temperature isn't reached a light on the control panel might start flashing. The heating element assembly can be checked for continuity with an Ohm meter.
Check Fault Codes
If the display lights are flashing and there is an error code in the display window, check the wiring diagram and tech sheet in the dishwasher that will provide information on the fault.
Drain Pump
If lights are flashing on the control panel, the drain pump might not be working properly. For two-wire drain pump motors check them for continuity using an Ohm meter. If it's defective You'll need to replace it. Drain pumps are not repairable.
Touchpad and Control Panel
If the lights are flashing on the display the entire touchpad and control panel assembly might be defective. If the display works but the dishwasher functions are all out of synch, or some of the buttons don't respond properly the entire touchpad and control panel might need to be replaced.
Touchpad
If the display lights are flickering for no reason, the touchpad might need to be replaced. Sometimes when the touchpad is defective the display lights are flashing randomly.
Posted on Jul 23, 2013
IFIXALL
  • 868 Answers
SOURCE: Whirlpool Quiet Partner 980
Bad control board ,replace it.
Posted on May 26, 2008
SOURCE: whirlpool gold- quiet partner III
An angel of mercy on another blog posted this solution and it worked for me as well. My Whirlpool Quiet Partner Dishwasher would not work due to the CLEAN light flashing in 7 interval sequences. I followed these steps and my dishwasher is not working perfectly...hope it works for you:
"Well for mine which is a Whirlpool Gold Model # GU2400XTPS3, I found the seq of buttons that I had to push to reset the curcuit board. I think it may of been in this forum somewhere. But I had to push - Sani Rinse, Heated Dry, Sani Rinse, Heated Dry, and then the dishwasher went through it's diagnostic cycle and then after that the light stopped blinking and the dishwasher works great. Supposily, there is a Product Tech Sheet behide the kick panel of every dishwasher, but mine was gone so I had to find the information on the internet. You might want to do a serach for the correct seq of buttons you have to push to reset the curcuit board. If you know for sure that the heating element is bad, you will have to order one. "
Posted on Oct 13, 2008
WRMtech
  • 70 Answers
SOURCE: RUN TIME ON NORMAL WASH IS ABOUT 3 HOURS
common failures on that usually are the heating element. Look at the botton and see if it is broken anywhere.
Posted on Mar 22, 2009
BIKER T
  • 909 Answers
SOURCE: I have a Whirlpool Quiet Partner dishwasher that stopped working
that is a typical indication of a faulty board. once replaced, i suggest a surge plug to be installed. it will protect the unit from future power fluctuations.
Posted on Sep 15, 2009
SOURCE: whirlpool quiet partner III. Clean light keeps flashing clean.
Had the same problem. Press the sani-rinse and heated dry button back and forth and it should reset.
Posted on Dec 29, 2009
My whirlpool quiet partner II imperial series Dishwasher will only work on light wash mode. Normal wash, heavy wash or pots and pans cycle will not work at all.
This is ordinarily a problem with the touchpad. Can you give me the specific model number of yours (ordinarily on a sticker on the inside edge of the door or on the door opening)?
Mar 06, 2016 | Whirlpool Dishwashers
Quiet Partner IV. Why is the pots and pans light blinking and it won't run?
Its normal for the drain pump to run for 5 to 15 seconds and then your washer should fill and you wash pump should run if your was pump is not running and just makes a humming sound then your start capacitor may need changing see the link below this is a simple task and not expensive. When ordering a new capacitor make sure it is the same size in ?F.
Washer Motor Capacitor part 8572717 How To Replace
May 28, 2015 | Whirlpool Dishwashers
Sep 15, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Whirlpool quiet partner III. Clean light keeps flashing clean.
Aug 29, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
The only number on the nameplate of my Costco-purchased "Quiet Partner IV" built-in Whirlpool dishwasher (steel insides) is 8575637. This dishwasher does not clean spoons right-they always have dirt left...
Yes, you almost certainly have a Whirlpool Gold Quiet Partner III Model #8575637
Of course the great news with buying from Costco is the ability to return products you are dissatisfied with. Check with the customer service desk.
Please reply if you want to to get into repairing it and we will get under way.
Mar 31, 2009 | Whirlpool Gold 24" Tall Tub Built-In...
GU2500XTPS3 QUIET PARTNER - NO START.
23310532.jpg The dishwasher will not start. The following things have occurred;
1. The Cycle option light is flashing.
The model is GU2500XTPS3
Can anyone please assist if they have seen this problem before?
Oct 22, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
May 26, 2008 | Dishwashers
Dishwashers Logo
99 people viewed this question
Top Dishwashers Experts
Owen Barnes
