Question about Furniture
How to unlock mote control for lift chair - Furniture
2 Suggested Answers
  • 118 Answers
SOURCE: Pride Lift Chair
Yes, jump, short, somehow bypass the switch and see if the chair moves. In 4 of 5 cases, I have had to replace the switch. Its the only part I carry with for "spares". Its an easy fix, and a lot cheaper than replacingt the whole hand control.
Posted on Feb 03, 2009
Lift chair will not go up or down
Here's the manufacturer's phone #
1-800-994-3390 Reviews state that the hand controllers fail a lot and the parts department is slow.
Jul 26, 2014 | Home Meridian Comfort Lift Recliner
Pronto m41 moves slow at all times
If you have a seat lift on your chair, you will have to lower the seat lift. This is call limp mode so the chair does not move to fast and tip over while the person is in the chair. If this is not the case, then your chair controller may be over heating and it will also cause the chair to go into limp mode. this is a better option than totally stopping. the way to correct this is to let the chair sit and "cool down" for a little while. It usually takes about 30 minutes, sometimes less in cooler environments to get the chair back to normal use. If neither are the solution, then you have a problem with the chair that causes the controller to reduce the output. You will need to get an authorized Tech to check the chair out to determine the root cause.
Oct 30, 2013 | Invacare Pronto M41 Power Wheelchair
Meridian lift chair recliner
Possibly controller has gone bad. Home Meridian for new one........
May 09, 2013 | Home Meridian Comfort Lift Recliner
My hand controler for lift chair is broken
hi all meridian phone number is (800) 994-3390 we had the same problem remember there is a 1 year warranty so your replacement remote could be free
Feb 05, 2013 | Home Meridian Comfort Lift Recliner
Jazzy 614HD will not move. Lights flash from right to left, then cuts off. Unlock instructions are not effective. Chair is fully charged.
If chair has a tilt, recline or lift seat on it it may be going into lock-out mode on its own due to a limit switch fault. If you don't have any of these options then I suggest you remove the joystick, controller and any wire harness between the two and send them to a shop like mine for repair.
The usual lock out light chase is from left to right - not right to left so this is suspect of a different issue.
Dec 28, 2012 | Pride Jazzy 614 Hd JAZZY 614HD
My Golden Technologies Comforter Series recliner/lift chair won't recline or lift. The buttons light up but nothing happens.
With Golden Technologies chairs, there is a self diagnostic system. There are LED lights at the transformer and the hand control. If you do have have lights at the transformer, it may be a power issue or a bad transformer. If you have lights at the transformer but not the hand control, it is the hand control. Since you state you ahve lights on the hand control, it is probably a motor issue.
The best thing you can do is call the store which sold you the chair or call Golden directly at 1-800-624-6374. While they do not sell directly to the public, they can point you to a local dealer who can help with the repair.
Sep 16, 2011 | Golden Technologies PR 501T 28D Comforter...
What would cause my lift chair to move extremely slowly and stop altogether?
I am going to say the motor or the control switch have gone bad. Most of these chairs are made without relays to control the motor. A switch will wear out due to the current goin across the contacts if a relay is not used. Check the switch in the control. If this is helpful, please leave feedback. Thanks,SnugglePants
Nov 03, 2009 | Pride Mobility Products Casual CL30KD Lift...
How do I remove the chair from my Pride Mobility Jet 3 power wheel chair? The manual just have one line of description! Do I need to remove the chair before getting by hands on the battery? My Jet 3 is of...
There's a lever on the side of the chair that you disengage to unlock it. First, make sure the chair is in gear and power is off, then unplug the Joystick from the base; just follow the cable coming out of the joystick to the rear of the chair where it plugs in and rock it back and forth to unplug.
Unlock the seat with the lever, and turn the seat slightly to the left or right and lift up. Usually, it will come right off. If it's been a while since it's been removed, or if a heavier person has been bouncing atop it, it may need more coaxing. Try squirting some WD-40 at the base of the seat where the pole connects and let it run down into the shaft of the pole. Wiggle seat back and forth a bit and try lifting at the same time.
Now you can access the batteries by lifting up on the corners of the cover called the shroud. These are held on by Velcro strips so just pull up and they will give way. You will see the two batteries inside. Replace them with sealed, gel-acid deep-cycle batteried, about 32-34 amp-hour rating. Fully charge for two or three hours before using. On first uses, let the batteries discharge almost to the red zone before charging overnight. After a week, they will be well broken in. Good luck.
Jun 30, 2009 | Jet 3 Ultra Power Chair
Pride Lift Chair
Feb 02, 2009 | Pride Mobility Products Casual CL30KD Lift...
Furniture Logo
46 people viewed this question
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
