Canon c9060 stack bypass size not detecting - Office Equipment & Supplies
  • Lakshmi Narasimhan Aug 21, 2013
    solved the problem by entering the paper size value in CST adj before it will be zero thanks for all.
5 Suggested Answers
  • 37 Answers
SOURCE: Canon Imagerunner 330s - Stack Bypass
you can select for tray (letter size ) as default in paper settings
the stack bypass paper sensor may be broken and is active all the time
Posted on Feb 05, 2008
checkitright
  • 1362 Answers
SOURCE: STACK BYPASS option causes LOAD PAPER message & no print
1-did you change to bypass instead of trays in the menu?
2-the sensor (black lever in the bypass that triggers the sensor) is missing or bad
Posted on Oct 09, 2008
FixinFax
  • 3085 Answers
SOURCE: I want to print free size paper in the stak bypass.
Set the bypass guides for the largest size paper in the document. Bypass feeders are dumb, they don't care what size the paper is.
Posted on Mar 14, 2010
babaprithi
  • 372 Answers
SOURCE: I am using a canon
in the copy settings in additional functions there is standard bypass settings.change it from there
Posted on May 24, 2011
Canon Image Runner C9060 E000023-0202 hatas? ??z?me yard?mc? olabilmisiniz?
This is an error code for the IRA-C9065PRo. I"m not familiar with the IR-C9060. These may be close enough to help. An E023-0202 is occurring at power on. The error code E023-0202 points to a fault in the developing stirring motor. In this case, the magenta toner bottle was stuck in the hopper assembly causing the code. The bottle was removed from the hopper and then the hopper was reset by manually rotating it from behind with the hopper tool. This resolved the code Hope this helps
Jun 04, 2017 | Canon Office Equipment & Supplies
I need copy A3 with Canon iR 2016j Black and White Copier
Press aditional function, slect copy setting, then stack bypass, then select paper size A3.
Apr 04, 2013 | Canon iR 2016i Black and White Copier
My Canon IR1610 is giving wrong paper size message when i used legal size paper(8 1/2 x 13) but it does work on letter size.I did change the value by pressing additional function and set it to LegalR.It...
u have to choose freesize from the bypass tray and then measure ur paper and enter the size in XY.then only u can use it and that too from bypass tray only
Jul 11, 2011 | Canon Office Equipment & Supplies
I want to print envelops on my office canon imagerunner 5570. i cant? help.
use the stack bypass for envelope printing.there u can choose the paper size as envelope depending on the size and also u can set ur own XY size for the envelope
Jun 03, 2011 | Canon imageRUNNER 5570 Copier
On a Image Runner 1023iF trying to print letter envelopes loaded in the Stack Bypass. Machine once it received the print job just beeps and flashes.
Hy,
did you select the correct paper size on machine display? When you put paper in baypass the copier ask you for paper size and type.
Sep 02, 2010 | Canon imageRUNNER 1023iF Black and White...
Canon DR-5010C when settings are changed to Auto Detection for page size gets an error message stating that "Scanning parameters are incorrect." I want to be able to scan stacks of paper of various sizes....
If you are using CapturePerfect 3, select page size as Auto-detection, detect size by Image width, Deskew by roller & Image, then you will get images exactly as that of the scanned image.
If you ae using CP2, then you can select Auto-detection AND page detection. The problem with CP2 is if the image is less than that of the guide-plate, you will get black background. You can clean this through software.
If you had select B&W scanning and chosen to save file in JPG format, the scanner will report error. JPG is only for Color/ Grey scale.
With CP2, I have observed that sometimes, the changes are not retained, unless you select 'default' first and alter the parameters. This is not found in CP3.
S. Mohan, Chennai, India.
Apr 28, 2010 | Canon DR-5010C Scanner
Mar 14, 2010 | Canon Office Equipment & Supplies
Oct 09, 2008 | Canon imageRUNNER 400S Copier
Jan 29, 2008 | Canon ImageRUNNER 330s Copier
23 people viewed this question
k24674
