Question about Home
Using metal snake to clear a clog scratched some areas of rhe bowl.How can I covere it?
    Master:
  • 966 Answers
Might be difficult but try bleach over the scratches. Ask hardware store if they have a solution.
Posted on Jul 30, 2013
The tub is clogged with hair
Few plumbing issues such as Dripping faucets. Running toilets. Leaky valves. Clogged bathtubs can be solved by our own trying few things.
1)Firstly lookout for what is causing blockage such as soap or hair inside the pipeline blocking water just pull it out from pipes.
2)Secondly use a plunger(Tool used by plumber to clear clog) pour some water in bathtub to cover the plunger block the overflow of water with rag.Place the plunger over drain pull up & down 5 to 6 times.
3)Lastly if still the clog is not cleared try out with snake a long flexible steel cable wound on a handle In a sink you just feed the snake down the drain, but on a bathtub you need to feed the snake down through the overflow plate opening. Start by feeding about 3 feet of the snake into the opening, turning it as you push it forward. You will feel some resistance as you work the snake through the trap under the drain, and the turning helps to move the head through the trap. The snake should either break up the clog by pushing its way through it, or your turning will hook the end of the snake onto the clog and you can pull it out.
After trying with above if still there is plumbing issue call sewer line repair services for help.
Grease Trap Services
May 03, 2015 | Maax Home
How can I unclog a tub with an old Trap Drain without using harsh chemicals?
go to hardware store like lowes or homedepo and go to plumbing isle and look for a plumbing snake get the small one witch usaly 20 to 25 ft long its real easy to use,all you do is put end of snake in tub and start cranking or turning handle alloying snake to go down pipes it will turn around in circles freely until it hits clog then you pull and push it into clogged pipe until it cleares out
Jul 06, 2011 | Plumbing
Water over flowing from the toilet
It must be clogged. Try using a plunger first. If thayt doesn't work, consider using a "toilet snake". Simply place the end of the flexible cable into the toilet bowl and begin unwinding. The cable will extend round the bends in your trap way dislodging any clogs as it goes. If you come to the point where you feel some resistance, you will need to rewind the cable back into the bowl and remove anything that comes up with it. Repeat this process until your toilet runs clear.
May 18, 2011 | Home
My truck want start the pump is working but still not starting only when u put gas in carborator. i can blow through both sides of the filter to. what should i do
Recommend you loosen the fuel line at the carburetor to see if there is pressure there. If yes, take the float bowl cover off to see if the bowl is filling. If the bowl is not filling, there is a clog between the line and the float needle--use a wire to clear out the clog. If the bowl is filling, remove the carburetor and rebuild it or replace with a rebuilt one. Rebuilding a carburetor is not hard, but in the case of a clogged carb, you need to clear all the passages well. Please let me know if you have questions and thanks for using FixYa.
Dec 27, 2010 | 1987 Chevrolet S-10 Pickup
My husband dropped Q Tips (around 20) in the toilet and instead of taking them out, flushed them! Now when you flush, the water fills instead of draining then initially has the correct amount of water in...
If the snake won't reach, it is not the toilet, but rather in the wasteline. if the qtips were the sort with paper stems and not plastic, you can use a bacterial enzyme drain opener to clear the clog over a few days. qtips should not have clogged the line. You likely have some buildup on the inside of your wastelines that will be cleaned out by the bacterial treatment. The chemical solutions are not as thorough as the bacterial and they are quite hard on sewer and septic systems.
Oct 01, 2010 | Toto Drake ADA Compliant Toilet with...
Bissell 35962 Cleanview Bagless Revolution Upright Vacuum hose is clogged with sock where hose meets handle attachment. Attempted to use broom handle to push back through suction opening. Sock is...
If you have access to a small sink "snake" used to clear clogs in sinks, you might be able to use it to "snag" the sock and pull it out. Needs to be a metal sewer snake so that you can tug on it if and when it snags the sock.
Sep 05, 2010 | Bissell 35962 Cleanview Bagless Revolution...
Our Kohler K3402 suddenly stopped flushing. When you pull the handle and the flapper comes up, all that happens is the tank begins draining into the bowl and the bowl level rises, almost to the rim. The...
If there is a shower in the same bath is it also draining slowly?
If so check that drain systems air vent, (on the roof).
Find the pipe coming out of the roof nearest the bathroom with the problem and when a second person flushes the toilet you should be able to feel
air moving in and out of the pipe with your hand covering the end. If not the vent could be blocked by leaves or animals etc., this vent has to be clear in order for water to drain properly.
May 20, 2010 | Home
Water won't go down the bowl..Seems to flush fine except water wont go down...Nothing is obstructing it..it is not clogged
If water won't go down, you have an obstruction. It might be up inside the trap of the toilet. Use a closet auger to try to remove it. If the toilet trap is clear, you either have a clogged stack or vent.
Dec 02, 2009 | Toto Home
The water in the bowl does not evacuate properly. Seems only half of dirty toilet water leaves the bowl leaving other half of dirty toilet water to mix with clean water coming in from bowl. Secon, third...
what you need first is to check to see if your bowl is out of level then use a snake rotor to clean any mess in the bowl then flush this should solve your flushing problem
Oct 25, 2009 | American Standard 735083-400.178 Tank...
Home Logo
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
