Question about Sewing Machines
Baby lock bl4 428
Can adjust the stitch length adjustment
SewTechWayne
  • 186 Answers
SOURCE: Needle Thread breaking after about 30 seconds of quilting
Make sure the feed dogs are dropped (or feed dog cover is on - I can't remember which way this machine works). The stitch length on the machine has no function so ignore it. (I set it to zero so the machine doesn't have to work as hard). Hopefully this is all that's wrong. If not, use a shorter setting for the stitch length on the regulator, oil the hook and move slowly and smoothly.
Posted on Jan 31, 2009
  • 3 Answers
SOURCE: How do you adjust the stitch length on Consew 226 R-1?
if it is like the other industrial machines I've used, here is the general principle:
On the machine there is a button with no label. Hold button while turning the handwheel toward you. When you feel the button depressl you can adjust the length. Hold the button in the machine and crank the hand wheel back to decrease the length of ths titch and foward to increase it. I usually put a notch on the fly wheel for my standard length with some nailpolish. Release the button and sew to test the length.
Posted on Jun 16, 2009
SOURCE: how to adjust tension on bottom stitch?
There are tow places where the thread tension is adjusted.
One is bobbin. This is not routinely adjusted. Just once and it is good for long time. This is done by turning the only screw on bobbin by about 1/4 turn or so at a time. Try several settings until you find he best.
the other place is the conventionally on body of the machine.
Tension of bottom stitch or top stitch are very confusing words. meaning difft things to difft pple.
All i can say is this. If u see bottom stitch run straight through loops of top thread. then either top tension is too loose or bottom too tight. and vise versa.
With top tension set to middle position adjust the bobbin to get correct stitch. Then later on all u need is to adjust only the top setting according to stitch and cloth
Posted on Oct 17, 2009
SOURCE: Pfaff 463 Industrial Sewing Machine needs Hook & Needle Re-Timing
ne sece konac
Posted on Dec 20, 2009
madelinesalo
  • 59 Answers
SOURCE: Juki DDL-553 and adusting stitch length
to adjust your stitch, just move the wheel there is #. change the number.
Posted on Mar 26, 2010
Baby lock BL4-736d the feed dogs will not move forward
Make sure the stitch length is set long enough to actually advance the fabric. If set too short, the fabric movement will be very minimal. Also check that the presser foot pressure adjustment is set for the type of fabric you are sewing. The adjustment can be made for light- or heavy-weight fabric. If the presser foot pressure is too tight or too loose, it will have difficulty pulling the fabric.
Mar 16, 2016 | Baby Lock Sewing Machines
Baby Lock Serger 5360ED
when the feed dogs aren't moving like they should, then the machine needs to be serviced to see why,
May 29, 2012 | Baby Lock Sewing Machines
I have a Baby Lock 5280E. Can you tell me how to set the machine for rolled hem?
Assuming you mean a narrow rolled edge:
  1. Remove the left needle and thread.
  2. Open both the front and side covers.
  3. Raise the presser foot and the upper knife to the highest position.
  4. Clear the stitch fingers.
  5. Push the stitch with former release lever and remove the stitch former from the lower knife base. (Don't lose it!)
  6. Turn the stitch with adjusting dial until the "M" on the dial matches the red indicator on the needle plate.
  7. Set the stitch width length to "M".
  8. Close the covers, lower the presser foot and the upper knife.
This gives you a narrow edge. To roll the edge, increase the tension of the lower looper (the green knob) about three numbers higher than normal.
Nov 03, 2010 | Baby Lock Evolve
I am trying to figure out how to monogram. I keep having trouble adjusting my machine.
For doing a manual monogram (by hand, not using embroidery unit) Follow these steps.
1. Put on the "N" foot ( This is your open toe foot, so you can see easier)
2. Select the zig zag stitch (Should be #4, right next to the straight stitch)
3. Hit the stitch adjustment button on the screen ( Lower left)
4. Set the width (Will have a zig zag "/\/\/\/" icon) to whatever size you would like (Usually 4.0mm to7mm)
5. Set the length (will have a line "---------" icon) to a very short setting
You're now setup for a monogram. You might like this video too for using your embroidery unit.
Let me know if you have any more questions,
Chris
Jun 07, 2010 | Baby Lock Ellure
How to adjust stitch width on babyloc eclipse lx serger
Here is the info about this serger from the baby lock's website. It says the stitch length is a dial. I couldn't find the manual for download, but they say they stand behind their products with support. I would follow the customer support link at the bottom of the page and request a user manual. It looks like they sell an instuctional video and optional workbook too. Might be worth the price to help you get the most out of your seger. Hope this helps!
http://www.babylock.com/sergers/previous-models/eclipse-lx/
Feb 04, 2010 | Baby Lock Eclipse Serger
Feed dogs on serger don't advance
I use my BLSE200 all the time and ran into the same problem just last week. After pulling out my hair in frustration, I finally realized it had to do with the stitch length. Something wasn't connecting after I adjusted the stitch length, so when I re-set the stitch length, it popped things back into alignment and the feed dogs started working again. *whew* Hope that helps!
Jan 18, 2009 | Baby Lock Eclipse Serger
I need to satin stitch around the edge of a project
Try using the zig-zag setting, but adjust the stitch length to .3 or .4 (very small).
good luck!
Dec 08, 2008 | Baby Lock Esante
Baby Lock Imagine
Here are rhe directions from the manual of "Image" model BLE1AT: 3 Thread Rollled Edge
With the stitch selector set on "D", a narrow edge can become a rolled edge. Remove the left needle and the corresponding thread. Clear the stitch fingers. Turn the stitch length adjusting dial clockwise into the rolled hem range and set the dail at 1.5 Set the stitch width to 3.5
Hope this will be of some help. Good luck and have a great day! Lisa
Oct 06, 2008 | Baby Lock Imagine
Sewing Machines Logo
37 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
